firula Samba Member
Joined: March 24, 2010 Posts: 181 Location: Argentina, Prov Bs As
Posted: Mon Feb 12, 2018 7:41 pm Post subject: Input shaft play [video] |
Seal is in really bad condition, I'll replace it.
But I wonder if is this input shaft play is normal?
_________________ Restoring "La Macarena"! |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24671 Location: Olympia Wash Rinse & Repeat
Posted: Mon Feb 12, 2018 8:02 pm Post subject: Re: Input shaft play [video] |
Without the support of the needle bearings in the FW gland nut, then yes.
Polish up the tip of that shaft where it engages the needle bearings and lightly coat it with grease.
Do same to the clutch disc splines. Make sure the CD slides on the splines smoothly. _________________ In Stereo, Where Available! |
firula Samba Member
Posted: Tue Feb 13, 2018 5:07 pm Post subject: Re: Input shaft play [video] |
Eric&Barb wrote: |
Do same to the clutch disc splines. Make sure the CD slides on the splines smoothly. |
Excellent! Thank you very much! _________________ Restoring "La Macarena"! |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14218 Location: Casa de Oro, California
Posted: Tue Feb 13, 2018 7:26 pm Post subject: Re: Input shaft play [video] |
If your little finger is small enough, put a little grease on your finger tip and twirl it inside the gland nut needle bearing pilot bearing, too. |
firula Samba Member
Posted: Tue Feb 13, 2018 10:15 pm Post subject: Re: Input shaft play [video] |
BarryL wrote: |
Yes, will do!! _________________ Restoring "La Macarena"! |
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
