Masta Shake Samba Member
Joined: October 29, 2010 Posts: 198 Location: San Diego, CA
Posted: Tue Feb 13, 2018 1:42 am Post subject: Fantastic explanation of Secondary Air Injection system |
I think I have a bad combi valve but I may have missed something. Have had terrible fuel economy lately. When the van starts and is cold it sputters at the exhaust which has been blamed on the combi. Before I just replaced it I wanted to see how it works and found this video. Now I have a few other things to check first.
_________________ As a good friend told me when I got the Syncro: "Welcome to the an intense love/hate relationship". |
mkscott2 Samba Member
Joined: February 16, 2017 Posts: 90 Location: Cincinnati
Posted: Tue Feb 13, 2018 5:57 am Post subject: Re: Fantastic explanation of Secondary Air Injection system |
Uncanny timing. When evaluating for ease of access to the oil pressure switch, I noticed that two of the mounts on this pump were completely sheared off. Ordered replacements from GAP. Not sure how common a problem, but for other's reference, they are part # 06A133567A. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Wed Feb 14, 2018 7:44 am Post subject: Re: Fantastic explanation of Secondary Air Injection system |
I want to hire this guy for all auto videos - great explanations, keeping concise, good tidbits on how to repair things. Well done.
I tell people the whine when I start up is my aftermarket APU/Supercharger _________________ .ssS! |
AlexandMary Samba Member
Posted: Sun Aug 28, 2022 6:48 am Post subject: Re: Fantastic explanation of Secondary Air Injection system |
My question is how do we simulate the circuit to satisfy the ECU?
or what makes the ECU throw a code if the pump doesn't work? |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2796 Location: North Carolina
Posted: Sun Aug 28, 2022 7:35 am Post subject: Re: Fantastic explanation of Secondary Air Injection system |
First check to make sure your relay works. You can do this with VCDS on a 1995, if you’ve got that.
Then there seem to be two answers to this cat skinning. One is to replace with a later model pump etc that is not NLA like our 1995s. I’ve read about this on VWvortex. You have to modify the wiring harness. You might be able to us a SAI system from another car, same era,same digifant- like a Jetta or cabriolet. Not sure about that.
The other answer is to trick the ECU with a resistor. Again, VWvortex has info on this albeit on different models.
This is all on my to do list but not until winter, I just want my check engine light to not be on all the time so I don’t have to keep checking for new codes. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
Posted: Sun Aug 28, 2022 3:02 pm Post subject: Re: Fantastic explanation of Secondary Air Injection system |
It probably looks for a voltage drop on the OXS to sense the extra air, in which case you want a diode, not a resistor _________________ .ssS! |
