67sash Samba Member
Joined: December 14, 2012 Posts: 176 Location: Minnesota
Posted: Thu Feb 15, 2018 1:20 pm Post subject: 1968 - Brake Warning Light, B light on dash |
So I am in the middle of rewiring the dash of a May, 1968 bus. I have almost everything working. I have researched, read, and tried wiring the Brake System Warning Light, K9 on the VW TYPE 2 - From August 1967 (1968 and 1969 models) of the Bentley manual.
I have come across some key information below that expands on the Bentley Manual.
I have wired the system as stated:
Switches on Master cylinder to K
Fuse block (joined with BLK/R wire) in fuse #1
Bulb to Ground
ISSUE:
The light turns on when ignition moves to accessory and stays on when motor starts. When I push the brake peddle the light goes out. When I remove pressure from brake peddle the light comes back on. SO, the light is on continuously except when brake is applied.
Question:
1) Does it matter which prong on the 2 switches on the MC I connect the wires to? They are all copies of each other currently, if that makes sense.
2) Is my ground shitty? Checked it a dozen times already
3) WTF am I doing wrong?
Any ideas or thoughts are welcome! THX in advance - Sash |
coolerthanelvis Samba Member
Joined: June 30, 2003 Posts: 924 Location: San Diego, CA
Posted: Thu Feb 15, 2018 1:51 pm Post subject: Re: 1968 - Brake Warning Light, B light on dash |
My early '68 has the two brake light switches and a third switch strictly for the warning light. The diagram you posted is for 3-prong brake light switches and the brake warning lights are connected to terminal 81a on each switch. There should be numbers molded into the plastic on each switch.
Aside from that, have you tried reversing the connections at the light/button on the dash? I had mine hooked up backwards and had similar indications. _________________ Shawn
SV2s member #420
'68 Westy
"Do or do not, there is no try."
-Silent Bob |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Thu Feb 15, 2018 4:18 pm Post subject: Re: 1968 - Brake Warning Light, B light on dash |
Here's the schematic for a '68:
Note that the brake fail switch (J4) is different than the two main brake light switches (J1). The two J1 switches are wired in parallel with each other, thus either switch will light the brake lights. J4 is (most likely) a different switch type than the other two, but I don't have any here to look at to be sure.
Bulb to Ground |
It should be wired as follows:
- terminal 15 to switched 12 volts (same as that which feeds the brake switches). This power is used to light the indicator when you press on it (press to test).
- terminal 81a ("K" on later indicators) to brake check switch. This switch only closes on a hydraulic failure, at which time it sends 12 volts to terminal 81a, lighting the indicator.
- bulb center to ground. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST)
Last edited by telford dorr on Thu Feb 15, 2018 4:52 pm; edited 5 times in total |
busdaddy Samba Member
Posted: Thu Feb 15, 2018 4:39 pm Post subject: Re: 1968 - Brake Warning Light, B light on dash |
Yes, the switch on a 68 (J4) is a pushbutton like a reverse light switch opposed to a pressure switch, the master cylinder had a separate spring centered piston on the side that each hydraulic circuit pushed on from opposite ends, if one failed it moved the piston and the switch was activated.
If 67sash has the black (#15) wires on the 82a terminals, the red wires to the warning light on 81a and the black/red brake light wires on 81 it should work, as Elvis mentions terminal numbers matter. Also consider the dismal quality of new switches, it's not impossible one is NFG right out of the box. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Feb 15, 2018 6:16 pm Post subject: Re: 1968 - Brake Warning Light, B light on dash |
Oh it's a pushbutton alright, the piston that activates it has a Vee in the middle (narrowed section) that the switch sits in, when the piston moves the plunger slides up the ramp of the Vee and is depressed.
That switch would likely work, but now you'll need the super rare bus master cylinder to use it. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
67sash Samba Member
Posted: Fri Feb 16, 2018 9:40 am Post subject: Re: 1968 - Brake Warning Light, B light on dash |
Mine is a push button, not sure but was told that feature changes in later late bays. I would have to go check, but believe my 73 is not a push button.
I found the issue. It was connected to 81A on both switches, but due to the amazing soldering job from the PO it was contacting the other connection on the switch. fixed, shrink wrapped, and bam...it works AS I HAD IT WIRED. I thank you for the quick responses. I really try and research the information to death before posting so the same questions are not asked over and over again.
Now to wire in the emergency flasher relay....and possible the door buzzer.
THX, Ryan |
