original BIG logo 47-49 caps
sled
sled is offline
PostPosted: Tue Feb 13, 2018 6:43 pm    Post subject: original BIG logo 47-49 caps Reply with quote
are these original hubcaps? I was under the impression originals only had one drain hole. Also it looks like there might be chrome on the inside under the primer/oil?
https://www.thesamba.com/vw/classifieds/detail.php?id=2146156
drive your split.
janerick3
janerick3 is offline
PostPosted: Wed Feb 14, 2018 11:55 pm    Post subject: Re: original BIG logo 47-49 caps Reply with quote
There are heavyweight, German repros from the 1970s, with a single puller hole, that are often advertised as originals. These are found in both primed and chromed versions.
Thanks,
Jan K.
RareAir
RareAir is offline
PostPosted: Thu Feb 15, 2018 12:12 am    Post subject: Re: original BIG logo 47-49 caps Reply with quote
I’ve found that original German hubcaps, the “puller holes” were always located at the 12 & 6 o’clock positions
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
sled
sled is offline
PostPosted: Thu Feb 15, 2018 1:09 pm    Post subject: Re: original BIG logo 47-49 caps Reply with quote
how does one identify original hubcaps then?
drive your split.
Standardfahrer
Standardfahrer is offline
PostPosted: Thu Feb 22, 2018 8:40 am    Post subject: Re: original BIG logo 47-49 caps Reply with quote
Interesting information, I was always wonderring how ro identify original ones.
I have a set of good, alls repros and likely a set of original ones, I'll check them according your information.
Thanks
aa390392
aa390392 is offline
PostPosted: Thu Feb 22, 2018 11:28 am    Post subject: Re: original BIG logo 47-49 caps Reply with quote
If I don't learn anything else in 1 day, I always learn something here on theSamba..thx for that rareair.
Thomas
1956 Oval Prairie Beige
1956 Oval Inca Red Kab.
Always looking for another something.
WTB Alpine motors /Ashville NC License plate frame
virtanen
virtanen is offline
PostPosted: Sat Mar 03, 2018 8:04 am    Post subject: Re: original BIG logo 47-49 caps Reply with quote
I bought the caps, and I would like to know what I got.
Could someone who has for sure original early hub caps weight them and measure the width of the logo stamp?
These are 465 g each, and the width is approx 7.6 mm.
And yes, they were chromed and sprayed over.
And have tiny extra holes on the inner egde:
Mika
Split beetle restoration panels
Oval beetle restoration panels
sled
sled is offline
PostPosted: Sat Mar 03, 2018 10:55 am    Post subject: Re: original BIG logo 47-49 caps Reply with quote
Mika, here are some photos of my, what I believe to be original paint, big logo caps (set of four)
pressing seems to be about 8mm although it varies ever-so-slightly.
weight is right around 554g +/-
drive your split.
ovals4ever
ovals4ever is offline
PostPosted: Sat Mar 03, 2018 4:48 pm    Post subject: Re: original BIG logo 47-49 caps Reply with quote
The black one is definitely an original. Needs to have one hole. Weight above 500g and the part where it fits the wheel should have a 90 degrees angle.
The ones from Virtanen are unfortunately repro.
March '49 Split
Always on the hunt for pre 1950 literature and other rarities!
sled
sled is offline
PostPosted: Sat Mar 03, 2018 5:07 pm    Post subject: Re: original BIG logo 47-49 caps Reply with quote
would you be kind enough to remove one from your march 49 beetle and take some photos for us?
yes, on mine the flange that is hidden when installed is almost 90 degrees and taller than the angled flange on Mika's
drive your split.
janerick3
PostPosted: Mon Mar 05, 2018 9:42 pm    Post subject: Re: original BIG logo 47-49 caps Reply with quote
Mika's repros have the same shape of the Taiwanese 356 repro hubcaps from the 1980s.
Thanks,
Jan K.
