Fuel pump
plimthing
plimthing is offline
PostPosted: Wed Feb 14, 2018 12:16 pm    Post subject: Fuel pump Reply with quote
Will the stock fuel pump (mechanical) be able to supply twin weber 40's?
It will be for a 1776cc
asiab3
Air-Schooled
asiab3 is offline
PostPosted: Wed Feb 14, 2018 12:49 pm    Post subject: Re: Fuel pump Reply with quote
More than likely, yes. Brian on here has a 2L being fed by a rebuilt stock pump.
Good luck,
Robbie
www.airschooled.com
Three rules of troubleshooting:
1. Do the easiest thing first.
2. Don't rely on the guy before you. He was not able to fix the problem.
3. 90% of problems are between the driver's seat and the steering wheel.
SGKent Premium Member
SGKent is offline
PostPosted: Wed Feb 14, 2018 1:25 pm    Post subject: Re: Fuel pump Reply with quote
yes unless you plan to push it until it glows
You can do it right the first time, or do it over, the choice is yours. It is a free country. As to brakes, steering, tires, axles etc. - you may only get one chance at doing it right.
