128vw Samba Member
Joined: April 05, 2006 Posts: 222 Location: Western Massachusetts
Posted: Wed Feb 14, 2018 3:32 pm Post subject: 40 hp push rods |
I am building a 40 hp engine from parts that I have around. I am using a set of long rocker stud heads and when I put on the rockers I have to back the adjuster screws almost all the way out to set the valves. Are there different length push rods or can I shim the rocker stands up, this looks good. _________________ 56 Jungle green restored w/orig interior
65 Ruby red w/ 1600 single port
building 66vert on 69pan w/ 2332 |
Slow 1200 Samba Member
Posted: Thu Feb 15, 2018 1:54 am Post subject: Re: 40 hp push rods |
there's like 3 different lengths of 40hp at least, so yeah, when you mix and match heads, lifters and rockers you'll probably have to improvise a little |
128vw Samba Member
Posted: Thu Feb 15, 2018 8:44 am Post subject: Re: 40 hp push rods |
So can I just shim the rocker stands to make the geometry close. Not a performance engine, just around town. Thanks _________________ 56 Jungle green restored w/orig interior
mukluk Samba Member
Joined: October 18, 2012 Posts: 6985 Location: Clyde, TX
Posted: Thu Feb 15, 2018 12:57 pm Post subject: Re: 40 hp push rods |
You can shim the rockers, but if you don't get the geometry correct and only "close" you're looking at accelerated wear on the valvetrain. Just a hunch, but it sounds like you might have 1300-1600 pushrods installed instead of 40hp ones. Have you measured their length? _________________ 1960 Ragtop w/Semaphores "Inga" |
glutamodo The Android
Joined: July 13, 2004 Posts: 26297 Location: Douglas, WY
Posted: Thu Feb 15, 2018 2:21 pm Post subject: Re: 40 hp push rods |
Well, as far as what was sold in the USA there were two lengths. I guess there was another change to just very slightly longer ones during model year 1967 but that's nothing. The major change was here:
_________________ Andy T.
128vw Samba Member
Posted: Fri Feb 16, 2018 5:53 am Post subject: Re: 40 hp push rods |
It looks like I have the early push rods like the top ones in the picture. I need to check the stands are marked top. Does anybody have the length of the 2 early push rods? _________________ 56 Jungle green restored w/orig interior
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Fri Feb 16, 2018 8:34 am Post subject: Re: 40 hp push rods |
128vw wrote: |
Does anybody have the length of the 2 early push rods? |
https://www.thesamba.com/vw/forum/viewtopic.php?p=8616831#8616831 _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
creideahm Samba Member
Joined: March 30, 2014 Posts: 134 Location: Pittsburgh
Posted: Fri Feb 23, 2018 5:47 am Post subject: Re: 40 hp push rods |
I have NOS both sizes. Pm what you need. _________________ Stay calm and Bug-on |
