Bailey75 Samba Member
Joined: November 12, 2017 Posts: 7 Location: Australia
Posted: Wed Feb 14, 2018 7:36 pm Post subject: Super Beetle Problems - Need Help Fast |
Hey guys,
I drive a 1975 Super Beetle. It's perfect. Apart from one very worrying big problem.
9/10 times that I shift into second gear, it doesn't go in, and makes a horrible crunching noise. I have to try sometimes 3 times to get it into second. That 1/10 time that it does, I really have to "force" it in. If it doesn't go in, I have to come to a complete stop and then shift into first and start again. I don't have any issues shifting into second going up through the gears, only shifting down. I tried block shifting from fourth down to second, and there is no issue. Only going from third to second.
I did a full oil change the other day, and am getting my transmission fluid changed this afternoon.
Hoping this isn't going to cost me heaps to fix
Any other help would be great!
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Wed Feb 14, 2018 7:48 pm Post subject: Re: NEED URGENT HELP |
Sounds like worn synchros. Can you try double clutching. Push the clutch in, then let it come back up then push it again. Then shift. Any improvement?
Also, second gear is a highly used gear in these cars. It would not surprise me if the tranny has seen its better years with another driver. It may be time for a rebuild. But try double clutching first. If that changes things for the better, it may be worth a shot at replacing the pressure plate, clutch disc and throw out bearing.
Good luck and report back in after trying the double clutching. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51148 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Feb 14, 2018 7:51 pm Post subject: Re: NEED URGENT HELP |
First of all edit your title to something like "Transmission questions" in normal small case type, what you have used now is usually reserved for when you are broken down in BF nowhere with a mean looking biker gang circling you, remember the story of the boy who cried wolf?.
Sounds to me like you need another transmission if your clutch is adjusted properly, that sounds dire, but far from URGENT!!!@*% _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Feb 14, 2018 7:58 pm Post subject: Re: NEED URGENT HELP |
busdaddy wrote: |
Sounds to me like you need another transmission if your clutch is adjusted properly, that sounds dire, but far from URGENT!!!@*% |
Yeah cheers mate. |
Posted: Wed Feb 14, 2018 7:59 pm Post subject: Re: NEED URGENT HELP |
VW_Jimbo wrote: |
Good luck and report back in after trying the double clutching. |
You're a legend. Going to try this this afternoon. Thanks so much for your help |
Posted: Wed Feb 14, 2018 8:01 pm Post subject: Re: NEED URGENT HELP |
Don't get too happy. If those synchros are worn, that means a tranny rebuild.
Post back what you discover. Cheers! _________________ Jimbo
TDCTDI wrote: |
Posted: Wed Feb 14, 2018 8:12 pm Post subject: Re: NEED URGENT HELP |
VW_Jimbo wrote: |
Post back what you discover. Cheers! |
Just took it for a drive around the block, still doing it even when double clutching. I'm taking it to a mechanic this afternoon |
KKiley Samba Member
Joined: March 08, 2016 Posts: 662 Location: Aruba, Jamica, nope, Kokomo
Posted: Wed Feb 14, 2018 8:41 pm Post subject: Re: Super Beetle Problems - Need Help Fast |
I wondered what the crisis was. Got me to look, lol _________________ 1978 Super Beetle convertible
Click to view image |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Wed Feb 14, 2018 9:22 pm Post subject: Re: Super Beetle Problems - Need Help Fast |
So, you have no issues when shifting from first to second, correct? This “crunching” only occurs when downshifting to second from a higher gear (third gear, I assume). And you’re not racing around corners when downshifting, I assume.
It’s possible that when downshifting from third to second, you’re actually grinding “crunching” reverse gear. This can happen if there’s a problem with your reverse lock-out plate. While trying to get second, you’re actually attempting to get reverse.
Do you have a stock shifter?
Check the position and possible wear of your lock-out plate. Is it placed on the wrong side, upside down, or worn?
I had issues similar to yours when I replaced my shift housing with an aftermarket keyed shifter lock. The shift lock-out plate sat too high, so that when I downshifted to second, I would move into reverse gear. Naturally, I only ground reverse, due to my speed, but I quickly replaced the shift lock back to the stock setup. In your case, you may simply need to replace the lock-out plate, or possibly just re-adjust it. Either way, take it apart and see what’s what.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
JuggButt Samba Member
Joined: June 07, 2009 Posts: 140 Location: St. Augustine, FL
Posted: Thu Feb 15, 2018 8:23 am Post subject: Re: NEED URGENT HELP |
VW_Jimbo wrote: |
I have the same issue going from third to second. I double-clutch and GENTLY slide the stick into second gear. I sometimes goes right in and sometimes it takes a second or two. But I NEVER force it. _________________ (o\_!_/o) |
Posted: Thu Feb 15, 2018 8:25 am Post subject: Re: NEED URGENT HELP |
JuggButt wrote: |
VW_Jimbo wrote: |
I have the same issue going from third to second. I double-clutch and GENTLY slide the stick into second gear. I sometimes goes right in and sometimes it takes a second or two. But I NEVER force it. |
Time for a tranny rebuild. _________________ Jimbo
TDCTDI wrote: |
David Miskov Samba Member
Joined: December 29, 2003 Posts: 189 Location: New Jersey
Posted: Thu Feb 15, 2018 2:32 pm Post subject: Re: Super Beetle Problems - Need Help Fast |
I agree with Tim on this. Definitely check the lock out plate. I had the same problem years ago and it got to the point where I hated downshifting into second. Finally changed the lock out plate and have been using the trans (I thought was bad) for the past 20 years. |
HippyTom Samba Member
Joined: December 18, 2013 Posts: 676 Location: Florida, West Pasco
Posted: Thu Feb 15, 2018 2:50 pm Post subject: Re: Super Beetle Problems - Need Help Fast |
Have you tried revving your rpms up slightly before going from neutral into second?
I broke my clutch cable 2 hours from home once and used that to synchronize my speed shifts up and down. If it works without a clutch at all it may help in this situation. |
Starbucket Samba Member
If you are double clutching down a gear, you put the clutch in, shift out of third, let the clutch out, then REV the engine a little, putting the clutch in again and shift into second gear, usually a worn clutch disc or burned/glazed pressure plate or flywheel if it goes into second without grinding. Check the position of shifter, is the throw from natural to 1st and 3rd the same distance as from natural to 2nd and 4th?, if not adjust it until the same. |
