bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
Posted: Wed Feb 14, 2018 11:11 pm Post subject: Help With Piston/Cylinder Clearance |
I'm running 96mm hypereutectics in a T1. The 94mm AAs run around .0028" to .003". I used the percentage from the 94s to figure that I need .0032" clearance. Is .0032" adequate clearance? |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Wed Feb 14, 2018 11:30 pm Post subject: Re: Help With Piston/Cylinder Clearance |
Sorry I did not get to your question in my PM. EMW is one of the firat aircooled groups that Keith Black made HE pistons for. They have a lot of experience.
Here is an interesting resource:
http://www.hughesengines.com/TechArticles/2clearancerequirementsforhypereutecticpistons.php
Note if you scroll down that they recommend around .003"+....but that is for....I interpret.....a sand rail application.
The HE pistons have less expansion.....supposedly. I would have a serious chat with EMW. They have a lot of experience. Ask them for exactly what application they think their tighter piston to cylinder clearance is best for. Ray |
modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Wed Feb 14, 2018 11:41 pm Post subject: Re: Help With Piston/Cylinder Clearance |
Yeah .003 sounds about right.
Or.... I'd say, at least .0015 more than the minimum, if you are adapting it from watercooled normalish engine.
With any piston the clearance will depend on the design of the piston, and cam grind on it, so.....hard to say for sure.
What is the piston supposed to fit? |
Posted: Thu Feb 15, 2018 7:22 am Post subject: Re: Help With Piston/Cylinder Clearance |
It's either a domestic piston, and he paid Silvolite to machine them for a different pin size or a completely custom piston. I found a piston with the same specs, but with a larger pin, so that's my guess.
Ray, I actually walked-in and spoke with him. He mentioned that he runs .002" in Buses, and they should run hotter than my T1. I measured .778" halfway up the skirt, and he has his T4 barrels machined for .780".
It is possible that his pistons don't expand as much as an AA, but I feel like I want to err on the side of caution and do .003".
Oh, btw the skirts are uncoated. Should I use some sort of friction coating? |
modok Samba Member
Posted: Thu Feb 15, 2018 5:37 pm Post subject: Re: Help With Piston/Cylinder Clearance |
Sounds good.
IMO, don't bother with coating the skirts. |
Posted: Thu Feb 15, 2018 7:20 pm Post subject: Re: Help With Piston/Cylinder Clearance |
Great! Thanks! I called today to ask for an extra thou. |
