alaskadan Samba Member
Joined: January 09, 2013 Posts: 1858 Location: anchor pt. alaska
Posted: Sun Feb 18, 2018 8:46 am Post subject: Re: Lower ball joint hurting steering Knuckle. Really need help |
Sorry not the case here. I have a syncro, and I should've thought about that. It's a bushing that goes into the bottom of the upright that the ball joint goes into. . |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Sun Feb 18, 2018 12:44 pm Post subject: Re: Lower ball joint hurting steering Knuckle. Really need help |
Are both sides rubbing? Looking at the last set of pictures, it looks
like it might be better to clearance the upright. Lots of material there. _________________ ☮️ |
Vanagon Nut Samba Member
Posted: Sun Feb 18, 2018 2:04 pm Post subject: Re: Lower ball joint hurting steering Knuckle. Really need help |
From Van-cafe web page for 84 - 85 Vanagon here:
http://www.van-cafe.com/page_768_318/ball-joint-front-lower-press-in
Part of this comment relates to the Syncro but may apply?
"These joints are sometimes slightly longer (a few more threads) and it has been found when used on a syncro (4 Wheel Drive) model with 14" alloys that they may be too long and may scrape the rim. There is at least 1/8" of extra metal beyond the threads, and we recommend grinding a portion of this area away on some models with 14" alloys to improve clearance. ...... "
Also, is wear at tapered hole on the lower ball joint adaptor a possible cause of issue? I can't imagine a ball joint getting so worn that it enlarges that hole but maybe?
1988 West DIY 50º ABA
VE7TBN |
drj434343 Samba Member
Joined: January 31, 2016 Posts: 401 Location: Portland, OR
Posted: Sun Feb 18, 2018 2:11 pm Post subject: Re: Lower ball joint hurting steering Knuckle. Really need help |
I encountered this contact when I lifted my 83.5' Westy using GW springs and totally rebuilt suspension. Using the GW upper ball joint did not solve the issue, but shaving the top of the lower ball joint shaft by about 1/8" inch did give me the clearance I needed. Later, I switched to the Burly upper control arms, which brought the spindle vertical enough that I wouldn't have needed to shave the ball joint shaft.
I think the contact comes from the lifted geometry changes. |
Fiorenzo Samba Member
Posted: Thu Feb 22, 2018 12:33 am Post subject: Re: Lower ball joint hurting steering Knuckle. Really need help |
Vanagon Nut wrote: |
Neil. |
Thank you, very very interesting information. I think it is all about that because i used Febi ball joints and they say some are longer than the OE. I will grind the tip off.
Regard the tapered hole it seemed to me in perfect condition but i did not checked if the febi conicity was the same of the hole... It will be a pain to dismantle and check it now but i will think about that... |
Posted: Thu Feb 22, 2018 12:37 am Post subject: Re: Lower ball joint hurting steering Knuckle. Really need help |
drj434343 wrote: |
Yes I think so, actually i did not lift the suspensions because the new springs are the same lenght of the original one but quite harder than the worn 34 year old one. I think that + longer tip of the febi ball joint and + the camper completely empty at the moment did the issue.
I hope!
Today with some luck I am going to dismantle the rear suspension and brakes...
Do you have suggestions to improve the force of the hand brake? Becaus it has never been sufficiently strong to lock the rear tires reliably.
Very thank you to the help of every one |
Posted: Thu Feb 22, 2018 12:42 am Post subject: Re: Lower ball joint hurting steering Knuckle. Really need help |
MarkWard wrote: |
like it might be better to clearance the upright. Lots of material there. |
Hi thank you, i am not completely sure of what you mean. The bushings of the up arm are completely in and new. I dont understand where you mean there is a lot of material.
Thanks |
Posted: Thu Feb 22, 2018 4:33 am Post subject: Re: Lower ball joint hurting steering Knuckle. Really need help |
Instead of grinding the ball joint, you could clearance the area on the suspension where it is rubbing. Reads like you have decided to cut the ball joint down. _________________ ☮️ |
Posted: Thu Feb 22, 2018 8:54 am Post subject: Re: Lower ball joint hurting steering Knuckle. Really need help |
You could easily cut off the tang on the the top of the stud. Its only purpose is to give you something to grab onto when installing the stud into the eye and it is hardly necessary as if you load the suspension the stud will lock into the eye and not turn anyway. Grind 6 to 8mm off the top of the stud and be on your way. |
Posted: Thu Feb 22, 2018 9:16 am Post subject: Re: Lower ball joint hurting steering Knuckle. Really need help |
Too much caster angle will pull the wheels forward which angles the spindle/upright into a position where the tip of the ball joint can come into contact with the upright. It looks to me like you have a combination of too much caster angle combined with the stud on the ball joint being slightly taller than normal. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Sun Feb 25, 2018 1:45 am Post subject: Re: Lower ball joint hurting steering Knuckle. Really need help |
MarkWard wrote: |
Instead of grinding the ball joint, you could clearance the area on the suspension where it is rubbing. Reads like you have decided to cut the ball joint down. |
Yes but how could i proceed to "clearance the area on the suspension where it is rubbing" ? |
Posted: Sun Feb 25, 2018 2:00 am Post subject: Re: Lower ball joint hurting steering Knuckle. Really need help |
Christopher Schimke wrote: |
Too much caster angle will pull the wheels forward which angles the spindle/upright into a position where the tip of the ball joint can come into contact with the upright. It looks to me like you have a combination of too much caster angle combined with the stud on the ball joint being slightly taller than normal. |
This is interesting, actually I did not checked the caster angle until now because I have left it as it was before rebuilding the suspension, i will check it when i will do the suspension aligning.
However i have cut the tip of the stud and now i don't have any more problem.
But if you compare this photo with the next one it seem that, even if all the steering is turned, the limit point it is never reached because the lower arm adaptor hit the back of the knuckle.
I don't know if it is due to a bad suspension alignment or it is a normal behaviour.
The camber is all the way positive now, the caster i am not sure, the front is not lifted.
Thank you |
spatiald Samba Member
Joined: May 31, 2015 Posts: 35 Location: Santa Cruz, Ca.
Posted: Sat Feb 02, 2019 7:26 pm Post subject: Re: Lower ball joint hurting steering Knuckle. Really need help |
Pinging this old thread as I am having the same issue after rebuilding the front end with all new bushings and replacing shocks and springs, upper and lower ball joints. The springs are the GW zero lift - though I understand there may be a bit of lift added.
I imagine this is fairly common after completing the dreaded front end rebuild. Would be great to hear if anyone else found the issue to be caster angle. Or if other problems were found to be the source.
I have an 83.5 and the LBJ I installed was lemforder. I'll grind off the end if I have too but want to make sure this is not indicating another issue. |
Wellington Samba Member
Joined: September 21, 2004 Posts: 1890 Location: Montreal
Posted: Sun Feb 03, 2019 7:15 am Post subject: Re: Lower ball joint hurting steering Knuckle. Really need help |
Since you just did the job, any chance you have the old ball joint kicking around? A quick measurement will tell you if the stud is longer.
It has come to the point that I will evaluate a new part prior to installation no matter the brand, just to be sure it is "the same"
If the shaft has a slightly smaller taper, it will go in deeper and protrude further, if the shaft is a tad longer....
and then proper alignment. |
Posted: Sun Feb 03, 2019 8:57 am Post subject: Re: Lower ball joint hurting steering Knuckle. Really need help |
Unfortunately I do not still have the old ball joint and I'll start grinding away here soon.
FWIW, I just messed with various adjustments to caster (radius rod) and camber (UCA bolt). Neither seem to make this work so grinding is increasingly seeming to be the right answer. I'll reply back here if I'm able to make either of those work. |
grant111 Samba Member
Joined: March 01, 2019 Posts: 3 Location: Roswell, GA
Posted: Sun Jun 23, 2019 3:39 pm Post subject: Re: Lower ball joint hurting steering Knuckle. Really need help |
I had the same problem indicated in the photos and used a thin cutting wheel on my die grinder to remove 4.3 mm (the unthreaded top portion of the lower ball joint shaft). Problem solved.
Perhaps the problem is a combination of the ball joint shaft being a bit longer and the mounting point in the knuckle being widened from use allowing more of the ball joint shaft to penetrate.
My Vanagon is a 1985. I added 1986 knuckles and used a GW 1.5" lift spring with the extension. It could also be possible that the lower limit / geometry of the early Vanagon is different from later Vanagons.
Either way - after fretting the whole weekend - I'm moving to the next hurdle. |
