vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Wed Feb 21, 2018 2:23 pm Post subject: Re: Engle FK grinds for 2127cc |
The two thing that wear out lifter bores are how high the cam lifts and valve spring pressures. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Wed Feb 21, 2018 2:24 pm Post subject: Re: Engle FK grinds for 2127cc |
pondervwmike wrote: |
So its rough on opening and closing the valves. I think i get it now. I didnt understand what you meant when you said it was a hammer/slammer cam. Now it makes sense. Thanks Dan for your information it is very helpful.
Mike |
Yep
I am big fan of all the web 86 grinds and possibly jpm raptor grinds based off of what knowledgeable people have said and what the ads say. Costly stuff.
The old FK stuff is also good but I am not a fan of the newer FK4x stuff.
Dan |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3466 Location: Paradise, Ca
Posted: Wed Feb 21, 2018 2:25 pm Post subject: Re: Engle FK grinds for 2127cc |
Mike,
I would email CB Tech with all your combo specs and see what they recommend.
I trust Pats recommendation as he has installed/dynod/supported a zillion cams.
Dan, your only experience with this grind is when you plotted 3% of the grind and sent it back to CB. Alstrup and Modock raised good points about your "findings" in your 2292 thread. _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
Posted: Wed Feb 21, 2018 2:28 pm Post subject: Re: Engle FK grinds for 2127cc |
vwracerdave wrote: |
The two thing that wear out lifter bores are how high the cam lifts and valve spring pressures. |
And cams with steep ramp angles. Like the engle VZ cams. They push the lifter heavily sideways into the lifter bore.
Posted: Wed Feb 21, 2018 2:29 pm Post subject: Re: Engle FK grinds for 2127cc |
jpaull wrote: |
Mike,
Dan, your only experience with this grind is when you plotted 3% of the grind and sent it back to CB. Alstrup and Modock raised good points about your "findings" in your 2292 thread. |
Like what? And the other 97% is very good but that 3% is very important unless you like a noisy engine, I don't. |
modok Samba Member
Posted: Wed Feb 21, 2018 5:47 pm Post subject: Re: Engle FK grinds for 2127cc |
I don't want to BASh anybody, but
Buying Web camshafts, you get 100% of the cam lobes, 100% of the time. |
fivelugshortaxle Samba Member
Joined: May 13, 2011 Posts: 4254 Location: Aumsville, Oregon
Posted: Mon Dec 16, 2019 1:16 am Post subject: Re: Engle FK grinds for 2127cc |
Ever decide on the cam? I say go with a Steve Long cam also. And SLR XR310 on a 106 lobe. About like a W125, FK10. Easier on the valve train. Quiet. Makes big power. 310 adv dur... [email protected] .558 inch lift as measured with my 1.4 rockers. _________________ Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc |
