itsa914 Samba Member
Posted: Sat Feb 17, 2018 3:07 pm Post subject: Remanufactured engine - need value help please |
Hi everyone. I'm a 914 guy and trying to gather info on value of a remanufactured what I believe is a Vanagon motor. I purchase a project 914 over a year ago and sitting inside the engine bay was the engine. The owner had passed away and the family couldn't really tell me anything about the 914 or why this engine was installed (but not completely).
I pulled the engine and it has been sitting on my engine shelf ever since. I do turn it over once or twice a month. There is a Michigan Buggy Builders show next month and a buddy is getting a space and asked f I have anything I would like to take. I don't have a need for this engine anytime soon so I think it is best to move it along.
So I am asking for some help here on fair value of the long block. The serial number is CV005433 3 and has remanufactured sticker on it from VW Canada. I'm not looking to retire off the sale of it, just looking for a honest value for it.
So what do you think? I will clean the dust off of course before I take it to the show. Hopefully the pictures will load.
_________________ Garold Shaffer
1970 Porsche 914 w 2.0L
INR SCCA #70 DSP |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Posted: Sat Feb 17, 2018 3:32 pm Post subject: Re: Remanufactured engine - need value help please |
Thanks Dave. I wish I had more build info on it, but I don't. I was thinking $500 - $750 value and to be honest I would be happy with that. It does me no good sitting on my engine shelf and it needs to go to someone that can use it. _________________ Garold Shaffer
INR SCCA #70 DSP |
Posted: Sat Feb 17, 2018 4:30 pm Post subject: Re: Remanufactured engine - need value help please |
Thanks for the education. _________________ Garold Shaffer
INR SCCA #70 DSP |
Gauche1968 Samba Member
Posted: Sat Feb 17, 2018 4:45 pm Post subject: Re: Remanufactured engine - need value help please |
IIRC, Wasserboxers remanufactured by VW Canada have a hit or miss reputation. Not sure about aircooled motors, though. _________________ 1984 Vanagon GL
1984 Vanagon Westy |
?Waldo? Samba Member
Posted: Sat Feb 17, 2018 8:00 pm Post subject: Re: Remanufactured engine - need value help please |
There are enough differences between the vanagon air-cooled engine and the late bay engine that it's irritating to mix and match. Engine tin is different. Alt is different. Exhaust ports in the head are different and consequently the heater boxes and the rest of the exhaust as well. Etc, etc etc... Point is, it's not a desirable engine for the late bay vanagons compared to the one that actually fits. |
Posted: Sun Feb 18, 2018 10:05 am Post subject: Re: Remanufactured engine - need value help please |
The only problem with the heads, assuming they are good if that they require one to find a pair of '79 Federal heat exchangers. This could be as simple as a call to Busted Bus or it could take months of searching. In a way this is a good thing though, as '79 will take the early '72-74 mufflers instead of the pile of spaghetti used on 75-78 buses.
FWIW, if I can not run an engine and get it hot and put it under load I am just not very apt to want to pay very much for it. I have one supposedly zero mile engine I need to tear into sometime that I bought from a respected Samba member. I was able to start and run it but not put it under load before buying it, but once installed it I drove one trip around the block and pulled it right back out as it was beating itself to death when under load. |
AZ Landshaper Samba Member
Joined: February 08, 2009 Posts: 1698 Location: The Old Pueblo
Posted: Mon Feb 19, 2018 11:48 am Post subject: Re: Remanufactured engine - need value help please |
I got $900 for my AC motor here in Tucson. Good riddens! _________________ Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Mon Feb 19, 2018 12:39 pm Post subject: Re: Remanufactured engine - need value help please |
That does not look like Vanagon tin work. It also does not look like 2.0 Porsche tin work either. Probably tin work from a 1700 or 1800 914.
The main difference in the VW type 4 heads was the exhaust port shape. Early heads had oval ports and used a copper crush gasket to seal the exhaust. The later heads had "square" ports and used a conventional type of exhaust port gasket.
My guess is the previous owner was going about getting the car back on the road with that engine. I assume you have other plans for the chassis. An examination of the intake and exhaust ports should give you an idea of the mileage. As mentioned a compression test, but probably easier to do a cylinder leak down on the bench to get some comparison numbers. _________________ ☮️ |
