mascrappo Samba Member
Joined: January 11, 2012 Posts: 535 Location: New Mexico
Posted: Sat Feb 17, 2018 7:10 pm Post subject: 73 Super FTE master cylinder follow-up |
I installed a FTE German master cylinder today, I did not bench bleed. I have spongy pedal on the top 3/4 of pedal. At the end of pedal it will lock the fronts down, skids. I hear the back drums click when I push pedal, fluid comes out when bleeding. Replaced old ATE cylinder as it was leaking badly out the pushrod. The brakes worked better than now, but leaked.
Now, I realize I need to do some brake adjusting, but why the difference in pedal travel? I have solid fluid stream from all 4 wheels. A quart of Bosch brake fluid has been run through the system today and while it stops, I have to go WAY down on the pedal, it stops straight too.
Brake lights turn on when pedal is way down and stopping, but half the pedal travel is mush and no lights.
I did not adjust the pushrod, it is a little slacky, but even this shouldn't cause what I am describing. Totally stock system. Thoughts????
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Sat Feb 17, 2018 9:10 pm Post subject: Re: 73 Super FTE master cylinder question |
Loosen the push rod locknut and turn the pushrod in until it just touches the master cylinder piston. Now, turn counterclockwise one-half turn. At this point, using a ruler, check for the free play at the top of the pedal when pushing by hand. It should be 1/4inch, which provides the required 1mm freeplay between the end of the pushrod and the back of the mc piston.
If, after performing this adjustment, you don’t 1/4inch free play at the pedal, turn the rod a little one way or the other to achieve this distance. Tighten the locknut on the pushrod when done.
Bleed again if necessary.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Posted: Sat Feb 17, 2018 9:13 pm Post subject: Re: 73 Super FTE master cylinder question |
Tim Donahoe wrote: |
Tim |
Thanks Tim, I gave up for the evening. I will adjust rod tomorrow. Just frustrated that I bought all the best and brakes worse than when I started...UGH |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Sat Feb 17, 2018 10:16 pm Post subject: Re: 73 Super FTE master cylinder question |
It because the rod was improperly set, like Tim stated.
When the rod does not enter the Master Cylinder far enough, it will not fully depress the inner piston and move fluid in a high enough pressure to fully inact the shoes or pads. It may push the piston far enough to create some resistance but not enough.
Good luck tomorrow! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Sun Feb 18, 2018 6:39 pm Post subject: Re: 73 Super FTE master cylinder question |
Well I spent all day working and adjusting what needed to be done. NO IMPROVEMENT. I took it to my friend who has a pressure/vacuum bleeder this afternoon and did twice, still no pedal. Adjusted all the brakes and pushrod too.
We are in agreement that it must be a shelf-dead German unit. As there are no date codes I could find, it may be 10 years old and weak rubber for all I know.
I emailed the place I bought in from and await the reply. Thanks for the tips guys |
green1303 Samba Member
Joined: February 04, 2014 Posts: 748 Location: Alexandria, VA
Posted: Mon Feb 19, 2018 5:04 am Post subject: Re: 73 Super FTE master cylinder question |
I installed a master cylinder once without bench bleeding it first. After a fair amount of normal bleeding, I had no pedal and adjusted the push rod, giving me some pedal right at the bottom. There was still air in the system. We had to bleed each wheel cylinder until the fluid was clear and then keep going, because there were additional bubbles farther back. We went around the car two or three times, continually filling the reservoir and bleeding. The process took several hours, but I eventually had good brakes. It’s unlikely that the master cylinder is the cause of your problem. If you have no pedal, no leaks, and good adjustment, then you have air in the system. _________________ 1973 green Super Beetle |
Posted: Mon Feb 19, 2018 5:53 am Post subject: Re: 73 Super FTE master cylinder question |
I have ran almost 2 quarts of brake fluid through the system, bled it at least 6 times, plus a professional air evacuation over the past 2 days, there is no air left. It is just a weak master cylinder. |
Maddel Samba Member
Posted: Mon Feb 19, 2018 6:31 am Post subject: Re: 73 Super FTE master cylinder question |
mascrappo wrote: |
... I took it to my friend who has a pressure/vacuum bleeder this afternoon and did twice, still no pedal... |
Did you push the brake pedal to it's pressure point and fixed it in that position before you started pressure bleeding the system?
For correct bleeding results the pedal has to be fixed in this "compressed position" during the whole pressure bleeding process.
Glenn73 Samba Member
Joined: May 30, 2011 Posts: 1190 Location: West Jordan UT
Posted: Mon Feb 19, 2018 12:43 pm Post subject: Re: 73 Super FTE master cylinder question |
I had great brakes before the change, only changed because old cylinder leaked badly out the pushrod. I adjusted brake shoes anyway since I have not done in several years, but they didn't really need it.
Now the new cylinder seems to be getting worse, so it tells me it's weak and losing what pressure it had. Plenty of samba posts describing the same things and new master was to blame.
Again thanks for all the tips, but I am not wasting any more time on this cylinder and will just replace it. |
Starbucket Samba Member
Posted: Mon Feb 19, 2018 1:20 pm Post subject: Re: 73 Super FTE master cylinder question |
Take that MC apart and see what's wrong with it, if its just a torn cup put a kit in it and bench bleed it. |
Posted: Tue Feb 20, 2018 7:16 pm Post subject: Re: 73 Super FTE master cylinder question |
Alright, due to the guilt trips, I bled it again 4 more times tonight per right front, left front, right rear, left rear. Tonight I cracked and bled the fittings on the master cylinder, front then rear. Well, no air I can find and the pedal still went way down. Drove it, stops straight, and will lock up the tires--but you have to stand on it.
After the drive, however, I am able to quickly feather pump the brake pedal and pedal comes right back to the top and holds (where it was before the change). Let off the pedal and try again, almost to the floor. Quickly (not the full pedal travel) pump, brakes are hard and on top, per say.
What gives? Do I have my helper learn the fast/short pump trick to get pedal "up" then bleed again? Is the cylinder truly weak and bypassing? I have no hair to pull out, but if I did! Keep the suggestions coming folks, thanks! |
Posted: Wed Feb 21, 2018 8:12 am Post subject: Re: 73 Super FTE master cylinder question |
OK you bleed brakes Right REAR, Left REAR, Right FRONT, and Left FRONT. You are doing it exactly wrong per your post. |
Posted: Wed Feb 21, 2018 1:13 pm Post subject: Re: 73 Super FTE master cylinder question |
Starbucket wrote: |
I'm doing exactly the sequence genuine VW service manual says to bleed them? I agree it sounds strange, all the old Chevys I've bled say to do it your order. |
vernonc Samba Member
Joined: April 23, 2012 Posts: 681 Location: Parkersburg, WV..yes, I sold the boat
Posted: Wed Feb 21, 2018 2:09 pm Post subject: Re: 73 Super FTE master cylinder question |
Starbucket wrote: |
Wrong!!
For dual circuit master cylinders, he's doing it correctly!
mort _________________ "Those who don't read newspapers are un-informed. Those who do read newspapers are mis-informed." Will Rogers
'69 sedan, low mileage, all original.....currently being 'freshened-up' for road trips and daily driving...just not every day
Freshening-up link http://www.thesamba.com/vw/forum/viewtopic.php?t=617386 |
Posted: Wed Feb 21, 2018 2:09 pm Post subject: Re: 73 Super FTE master cylinder follow-up |
If you can pump up the brakes, and the pedal then holds firm at the top under foot pressure, then I would adjust the brake shoes out farther. _________________ 1973 green Super Beetle |
sokyjeepster Samba Member
Joined: October 03, 2016 Posts: 22 Location: Franklin, KY
Posted: Wed Feb 21, 2018 2:59 pm Post subject: Re: 73 Super FTE master cylinder follow-up |
I had the same issue when I change the master cylinder in my 71 SB back in November. After replacement, I bled several times. I tried the push rod adjustment, but the rod came out before making contact, so I replaced it back to as original as I could. I ended up doing a Brake Pedal Travel adjustment (http://www.vw-resource.com/brake_adjust.html#travel) and then bled again. After that, all of the sponge was gone and everything ( appears ) to work great so far (just shy of 1,000 miles since). |
Posted: Wed Feb 21, 2018 3:07 pm Post subject: Re: 73 Super FTE master cylinder question |
vernonc wrote: |
Starbucket wrote: |
Wrong!!
mort
WELL MORT, He said he was using a PRESSURE BLEEDER. |
mukluk Samba Member
Posted: Wed Feb 21, 2018 3:14 pm Post subject: Re: 73 Super FTE master cylinder follow-up |
green1303 wrote: |
If you can pump up the brakes, and the pedal then holds firm at the top under foot pressure, then I would adjust the brake shoes out farther. |
Agreed, the very first thing I'd do in this situation is adjust every brake shoe out until it comes into contact with the drum, sufficient that you cannot turn the wheels. Once adjusted so, test the pedal to see if it is satisfactory or if it still requires pumping to firm up. If the pedal now checks good, back off each shoe adjuster so that the wheel just drags -- three clicks of each adjuster is usually pretty close. If the pedal still required pumping however, then rebleed the entire system with all brake shoes still firmly in contact with the drums, then readjust the shoes after a firm pedal is attained.
If after all that you find no air when bleeding and the pedal still needing to be pumped up, check for obstructions in the master cylinder fluid inlet ports and the reservoir/lines. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Wed Feb 21, 2018 3:35 pm Post subject: Re: 73 Super FTE master cylinder question |
Starbucket wrote: |
vernonc wrote: |
Starbucket wrote: |
Wrong!!
mort
mascrappo wrote: |
Sounds to me like he's using the "pump and hold" method. Besides, earlier he said he took it to a friend and used a "pressure/vacuum" system. I wonder which is was.....pressure or vacuum? With either, there's no particular sequence for bleeding. However, vacuum bleeders are known for drawing air around the threads of the bleeder screws.
