ragtop man Samba Member
Posted: Sun Feb 18, 2018 6:58 pm Post subject: Re: no turn signals- help |
yeah, it is probably 215c on the flasher. I was trying to remember it all, my bad. when I move the turn signal to make a right turn nothing happens as in flashing inside or any flashing noise, but I did not check to see if the lights were coming on and just not flashing on the outside. I did have to swap the tail light wires so I would have running lights instead of brake lights in the rear when the lights were turned on. I did not mention this but I have the turn signal lever out of its housing as I had to re solder the solid brown wire back on to the high beam copper section. I thought I would let you know about that. not sure it matters and the switch is really dirty inside, but it does move and hold both ways. all the help so far is great, thanks to everyone! |
Posted: Sun Feb 18, 2018 7:02 pm Post subject: Re: no turn signals- help |
where do I find the legend of what each component on the wiring diagram is?
like what is M12 or x2 |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Feb 19, 2018 8:04 am Post subject: Re: no turn signals- help |
ragtop man wrote: |
It should be in that very first archive link I posted. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Feb 19, 2018 12:56 pm Post subject: Re: no turn signals- help |
for some reason the wiring diagram for 1970 bus does not have a key or legend. do you know anywhere else I might find it? |
Posted: Mon Feb 19, 2018 3:27 pm Post subject: Re: no turn signals- help |
the blinkers are working for the most part on the front. I am getting the correct side blinking but the other side faintly blinks , so I think it is a ground problem with the fronts,. I will check that out. the rears are both blinking when I turn on either right or left turn signals, I think I have extra wires connected wrong in the back, I have checked the wiring diagram and it shows side marker lights with bulbs and wires going to them. Mine does not have any bulb housings at all in either side marker. I think this is the problem with the rears both blinking. can you tell me if that sounds correct? |
Posted: Mon Feb 19, 2018 4:47 pm Post subject: Re: no turn signals- help |
The side markers won't play any part in the signals. The weak light on the front sounds like a bad ground or dirty socket. The rears both blinking could be caused by a wire on the hazard or signal swith in the wrong place, or a bad ground or three.
I never noticed there wasn't any key for some of those diagrams around that time, the slightly earlier or later version diagram is essentially the same aside from the fuse box (and signals on 68/69), the rest of the components match. If there's something you can't identify ask here and we can tell you what it is or where it's located. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Feb 19, 2018 5:13 pm Post subject: Re: no turn signals- help |
okay, got to looking at the wiring on the tail lights. I found someone had connected the black and red passenger side tail light wire and the black with yellow striped for the drivers side rear tail light together. I have them separated now but I left my key on while going in to eat dinner and the battery was dead when I got back out to work on it. I did not get to check the turn signals after I separated the two tail light wires. I hope that will do the trick. battery is charging overnight. I will be trying again tomorrow after work. thanks for all the help so far!! |
Posted: Tue Feb 20, 2018 4:02 pm Post subject: Re: no turn signals- help |
hey! I have turn signals now!! I have a couple more questions though.
when I turn the turn signal lever to the left I get a blinking light on the left front turn lens, but the right light has a very faint blinking also. I think it is ground issue, but I am not sure which light to check? can someone please help with that. I really appreciate all the help you all have given me to help me diagnose this problem and solve it! VW people are the best!! |
Posted: Tue Feb 20, 2018 4:25 pm Post subject: Re: no turn signals- help |
One of the left signals is not grounded or the socket is dirty so it's finding a ground path through the parking light circuit, that's why the RH blinks dimly, look closely at night and you may even see the rears glowing a bit. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent Samba Member
Posted: Tue Feb 20, 2018 4:41 pm Post subject: Re: no turn signals- help |
Quote: |
the rears are both blinking when I turn on either right or left turn signals, |
although you solved this problem above it appears - what it and the front issue with the faint blink usually mean is that with the bad ground, it is easier for the electricity to travel thru the common ground wire back to ground thru the other bulb which has a better ground. As BusDaddy suggested - once you clean up the grounds and connectors that issue should go away. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Tue Feb 20, 2018 5:57 pm Post subject: Re: no turn signals- help |
thanks again for the help! I will clean the front grounds on both parking lights and hopefully that will do the trick. I have already cleaned the rear grounds. should I have separate turn signal lights in the speedometer? I am only getting one, the right signal arrow flashes for both turn signals. please let me know if that is correct, thanks! |
Posted: Tue Feb 20, 2018 6:12 pm Post subject: Re: no turn signals- help |
Cleaning the grounds will help, but may not solve the issue, you also have to clean the insides of each socket so the shell of the bulb can make good contact with it, that's how it grounds in the socket.
The arrows both flash regardless of which way you turn, sounds like one of yours is burnt out or loose. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Feb 20, 2018 6:19 pm Post subject: Re: no turn signals- help |
okay, I will check the bulb sockets tomorrow and see what I find. I do see another bulb flashing in behind the speedometer when I have the emergency flasher on. I will have to check on that also. hopefully it is just a burnt out bulb, I have more of them. I will let you know what I find out, thanks! |
Posted: Wed Feb 21, 2018 5:59 pm Post subject: Re: no turn signals- help |
okay, I worked on it some more this evening. I got the front turn signals corrected. the PO painted the whole passenger side bulb holder black, including the inside of the bulb socket. I got that cleaned up and the faint blinking went away, even in the dark. the rear passenger side is still acting up, but I am almost positive it is a bad bulb holder. I did replace the other wheat bulb in the speedometer and it started working. I thank you all again for all your help. I hope this post will help someone else that has a blinker problem in the future. |
Posted: Thu Mar 08, 2018 3:53 pm Post subject: Re: no turn signals- help |
can someone please tell me why when I tighten my turn signal housing down as it should be the lever will not park or stay up or down to make the turn signals work? If I take it loose from the column it works as it should and stays for left and right signals. I do not know what is causing this. I have the collar in it. I have tried to put it as close to the steering wheel as possible. anybody have any ideas?? |
Posted: Thu Mar 08, 2018 4:00 pm Post subject: Re: no turn signals- help |
The C shaped steel insert (shaped like an elongated horseshoe) has been crushed by previous overtightening and savagery, flatten it slightly to reduce the curve so it clamps against the column and stops the switch from squishing into the cancelling ring. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Mar 08, 2018 5:33 pm Post subject: Re: no turn signals- help |
bus daddy do you mean bring the ends closer to make the c shape smaller or tighter?
I did notice every time I take it apart the c shape ring is stuck to the steering column. |
Posted: Thu Mar 08, 2018 5:35 pm Post subject: Re: no turn signals- help |
Ends further apart. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Mar 08, 2018 7:19 pm Post subject: Re: no turn signals- help |
okay so spread it apart. I will try that tomorrow and let you know what I come up with thanks! |
