rr8325 Samba Member
Posted: Sun Feb 18, 2018 2:42 pm Post subject: rear drum brakes |
Anybody have this issue? On rear drum brake I am reassembling from new parts and the notch in the push bar seems to be just a smidgen shallow. Even with the star adjusters all the way in the drum does not want to slip on. This is only on one side. If I could deepen the notch on the bar it would solve my problem. Thanks
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Sun Feb 18, 2018 2:55 pm Post subject: Re: rear drum brakes |
I would compare the push bar to the one on the other side to see if they are different. If they are the same then I would deepen the notch on the shoe. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Sun Feb 18, 2018 4:34 pm Post subject: Re: rear drum brakes |
Double check your adjusters to be sure they are the right type (angled or straight) for the type of shoe you have AND if angled, the angle matches the angle on the shoe. You would not be the first person who mismatched shoes and adjusters or had the adjusters in upside down. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Joey Samba Member
Posted: Sun Feb 18, 2018 6:16 pm Post subject: Re: rear drum brakes |
I believe the shoe is straight where the shoe contacts the adjuster for '58-'64. _________________ Joey
rr8325 Samba Member
Posted: Sun Feb 18, 2018 7:00 pm Post subject: Re: rear drum brakes |
Yes, both the adjusters and the shoes are straight. I guess I'm thinking this is a case of aftermarket parts not playing together so well... |
rs58rag Samba Member
Joined: August 22, 2010 Posts: 419 Location: riverside,ca
Posted: Sun Feb 18, 2018 8:27 pm Post subject: Re: rear drum brakes |
Loosen adjustment nuts at E-brake handle then retry. Also, some shoe spring pins and springs are too long. I reused the original shoe spring, spring retaining pins and caps. |
fly2kads Samba Member
Joined: July 09, 2012 Posts: 148 Location: Roanoke, TX
Posted: Sun Feb 18, 2018 9:15 pm Post subject: Re: rear drum brakes |
It's hard to tell from the pic, but it looks like there is a bit of a gap on the right hand star adjuster, like the shoe is not seating well in the slot. It may be the pic, or my old, tired eyes, but that would be worth confirming. |
herbie1200 Samba Member
Joined: April 27, 2006 Posts: 833 Location: Rome - Italy
Posted: Mon Feb 19, 2018 12:46 am Post subject: Re: rear drum brakes |
Usually the culprit should be identified by increasing testing.
Try to remount all with the e-brake cable detached from inside the drum.
If not success: try to remount drum without the push bar, checking if upper part of shoes does deeply push-in the cylinder halves.
If not success: re-check shoes if they are definitively straight by posing them on a flat surface.
Be sure that both (cylinder and adjuster) have the NARROW slot, i.e. the shoe should be firmly seated into the slot and perfectly aligned with drum internal face.
Only a few parts maker (LPR, FAG...) have the correct narrow slot cylinders, while others declare compliance for large slot cylinders that are wrong. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2091 Location: Perry, GA
Posted: Mon Feb 19, 2018 2:03 pm Post subject: Re: rear drum brakes |
Don't alter the E-brake shoe connecting link. Loosen ebrake cables and compress shoes in by hand. Looks like ebrake lever is slightly activated in picture. |
