obus Samba Member
Joined: March 08, 2001 Posts: 11070 Location: just off Garden State Parkway Exit 81
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Feb 18, 2018 3:17 pm Post subject: Re: walk thru seat prep |
If you don't replace the springs you'll never achieve the perfect ass nirvana VW engineered them to do, maybe you have grown accustomed to that soft spot and it won't matter, it's up to you, I always find a seat with all it's springs more comfy even though it wasn't bad before. And how many other springs are close to letting go?, clean them up and inspect. Old couches are often good donors for springs like that if you can't get your hands on a donor bus seat.
A media blast and powder coat is the best way to refinish the frames/springs, a wire brush and maybe pressure wash followed by a liberal coat of Rustoleum would be a close second, maybe even some sort of acid to remove the rust? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sun Feb 18, 2018 3:22 pm Post subject: Re: walk thru seat prep |
You might make yourself insane, but... I had a regular plastic bristle car scrubbing brush in one hand and an air blower chuck in the other and went for it. I have scrubbed every piece of the smallest fur off all the seat frames of two beetles, a 13w bus, and a my camper this way. A shop vac might substitute well if you would rather suck than blow.
I don't know what that blurry hole picture represents. If it's a PO's idea of a seat belt mount they are sorely mistaken. Is the driver's side of the pass seat missing its welded pivot tab? Again, too fuzzy with your cell phone.
The gate latch behind the seat back better be off there before you finish reading this. _________________
EverettB wrote: |
FU#5 |
obus Samba Member
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Sun Feb 18, 2018 4:16 pm Post subject: Re: walk thru seat prep |
My ‘58 has an oblong hole. You can see it right by the termination of the bulkhead wing.
Matt Miller did my seats. He used cotton over burlap.
Here’s a shot of the passenger side with the seat back laying on the bottom cushion.
_________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
obus Samba Member
EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
Posted: Sun Feb 18, 2018 6:15 pm Post subject: Re: walk thru seat prep |
The oblong hole is just a production thing - that's how the metal base was made.
I wouldn't want to re-use the coco pads, I think they will fall apart or are already thin from age and wear.
Did your passenger side backrest have a coco pad?
Later Buses only have stuffing for the passenger side backrest - no pad. _________________ How to Post Photos
hitest Samba Member
Posted: Sun Feb 18, 2018 6:48 pm Post subject: Re: walk thru seat prep |
I don't know when paint code decals came into use- but if I had the holes of that latch with which to deal- it's what I'd do. Or maybe a maintenance sticker from an esso station
It is strange about the passenger side seat back and lack of hair padding. The seat back is fully covered in the later models (my '66)- are they for the early ones as well? Perhaps there's an upholstering production technique that coincided? _________________
EverettB wrote: |
FU#5 |
obus Samba Member
Malokin Martin Samba Member
Posted: Sun Feb 18, 2018 7:36 pm Post subject: Re: walk thru seat prep |
Blast and powder coat. That way it’s done for the life of the vehicle. |
obus Samba Member
Douglas Denlinger Samba Member
Joined: May 23, 2003 Posts: 1382 Location: Arizona's version of the east coast
Posted: Sun Feb 18, 2018 7:45 pm Post subject: Re: walk thru seat prep |
Weld the spring if you don't have a replacement....I do it all the time.
Then sand blast, check all springs....to make sure no more broke during blasting, powder coat. _________________ Transporter Restorations
Upholstery Haus
Active 23 Window Samba Collector/Restorer,since 1986 |
obus Samba Member
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Mon Feb 19, 2018 10:41 am Post subject: Re: walk thru seat prep |
You can get brass tubing from hobby supply places and slide a pre-bent 2" curve around the two broken spring halves then crimp into the brass with dikes to hold. |
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Tue Feb 20, 2018 12:54 pm Post subject: Re: walk thru seat prep |
they are very simple to replace. i would try to find some from another seat and replace them. I have done several spring replacements on middle and rear seats.
send me the size of the springs, I might have a few that will work. _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
BarryL Samba Member
Posted: Sat Mar 03, 2018 11:07 am Post subject: Re: walk thru seat prep |
obus wrote: |
P.S. do i need to worry about these holes and what the heck are they?
pass side
easy e wrote: |
My ‘58 has an oblong hole. You can see it right by the termination of the bulkhead wing. |
I always assumed the oblong hole was access to nutting and wrenching a seatbelt attachment point. Early year might negate this theory as I don't know how far back you could even get them. Later years the nut was preattached so access wasn't really necessary. |
obus Samba Member
