fxshov Samba Member
Posted: Sun Feb 18, 2018 6:42 pm Post subject: identifying this loose wire under the dash |
1973 Bay Window. This Brown wire comes from the turn signal switch. It has 12v always. When you pull the switch for brights the switch closes and opens. I know its for the brights. My question is, where does it hook up? I cant figure it out. Ive looked at the wiring diagram and I'm scratching my head..
Ive found other loose wires I will ask about later if I cant figure it out.
Yes the bus is new to me.
_________________ GOOD AINT CHEAP AND CHEAP ANIT GOOD
73 Bay Window
05 Tundra
12 Scion
93 HD Softtail
18 NX 2500
I need a bigger garage. |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
fxshov Samba Member
Posted: Sun Feb 18, 2018 6:56 pm Post subject: Re: identifying this loose wire under the dash |
That's why Im scratching my head. I come out of the TS switch with 12v. Im supposed to ground it? _________________ GOOD AINT CHEAP AND CHEAP ANIT GOOD
73 Bay Window
05 Tundra
12 Scion
93 HD Softtail
18 NX 2500
Posted: Sun Feb 18, 2018 7:08 pm Post subject: Re: identifying this loose wire under the dash |
It may be that whatever it goes to is turned on and is looking for the ground to complete the circuit,you could put it to ground through a fused jumper and see if something come on.or touch it to ground little spark,it's ground,fireworks it's a live wire. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy
1974 parts bus
A smart man learns from his mistakes,a very smart man learns from other's mistakes. |
fxshov Samba Member
Posted: Sun Feb 18, 2018 7:22 pm Post subject: Re: identifying this loose wire under the dash |
I could add a inline fuse on the terminal side, before I touch it to ground I guess. _________________ GOOD AINT CHEAP AND CHEAP ANIT GOOD
73 Bay Window
05 Tundra
12 Scion
93 HD Softtail
18 NX 2500
Abscate Samba Member
Posted: Sun Feb 18, 2018 8:08 pm Post subject: Re: identifying this loose wire under the dash |
Trace it up to the other end and use the wiring diagram to identify it and then put it in the correct place.
Don't guess with electrics, use the resources and get it right.
Dont assume it's a ground from color, lots of wiring Hackert is done to Busses. _________________ .ssS! |
timvw7476 Samba Member
Posted: Sun Feb 18, 2018 8:14 pm Post subject: Re: identifying this loose wire under the dash |
due to the length, I'd check any knobs on the passenger side, like the
rear defrost switch. that is one long run. |
fxshov Samba Member
Posted: Sun Feb 18, 2018 8:53 pm Post subject: Re: identifying this loose wire under the dash |
according to this diagram for a 1973 bus. E2 is the suppose to be the turn signal switch..My turn signal switch has 5 terminals coming off of it. the black and green striped wires, and I have brown/white and solid brown wires shown in my picture. I don't quite understand where the solid brown is supposed to go to.
73 Bay Window
05 Tundra
12 Scion
93 HD Softtail
18 NX 2500
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Sun Feb 18, 2018 9:27 pm Post subject: Re: identifying this loose wire under the dash |
Solid brown is always direct ground. Brown with a stripe is switched ground, e.g. through a relay or switch like a dome light switch. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Mon Feb 19, 2018 4:41 am Post subject: Re: identifying this loose wire under the dash |
Tram wrote: |
Solid brown is always direct ground. Brown with a stripe is switched ground, e.g. through a relay or switch like a dome light switch. |
Look at the burned insulation, wrapped wires, and Walmart wire connectors in the OP pic
What are the chances wire colors were preserved?
Luvya Tram!
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Mon Feb 19, 2018 5:55 am Post subject: Re: identifying this loose wire under the dash |
I would really check that diagram before plugging it anywhere. those other two wires coming out of the signal are for some crazy reason mated together with a crimp. That's not how it supposed to be. even stock, why bring out two wires to just connect them? why not just do it in the switch? unless it is a fuse between them, but I don't think so. I have yanked a few of these, but did not pay close attention, except to remember that some of them did go to the plastic block, and I see you have a couple doing just that. good luck. When the weather turns here in Michigan and my 73 comes out, I could check what I have, but that is still acouple weeks out (I hope just a couple)
edit- does your turn signal work now? does it flash outside? (it wont inside on the dash) where is the flasher relay? |
fxshov Samba Member
Posted: Mon Feb 19, 2018 7:40 am Post subject: Re: identifying this loose wire under the dash |
The TS and flashers work out side. And the indicator lights work inside. Flasher relay is the black one attached to the fuse block. The wire with the terminal is Brown/white. Only thing I can think of is they tapped into the wire at one time and didn't use a butt connector to put them back together. That solid brown wire being a ground with a push on terminal seems odd to me. I would think a ground wire would have a ring terminal that you would attach with a screw. Like they have done on the back of the headlight housing.. That solid brown wire comes out of the TS switch. Its for the high beams. I don't understand this schematic well enough to tell exactly what its supposed to attach to. _________________ GOOD AINT CHEAP AND CHEAP ANIT GOOD
73 Bay Window
05 Tundra
12 Scion
93 HD Softtail
18 NX 2500
Posted: Mon Feb 19, 2018 8:35 am Post subject: Re: identifying this loose wire under the dash |
at the back of the gage housing there is a ring of blade connectors for ground connections and there is another ring on the front wall,plus a couple more in the engine compartment. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy
1974 parts bus
Posted: Mon Feb 19, 2018 8:36 am Post subject: Re: identifying this loose wire under the dash |
VW uses females spades on the ends of their ground wires and typically have some form of male spade welded or otherwise attached to the body or engine.
A brown/white wire is probably going to be a switched ground, where the switch is on the ground leg of a circuit instead of being on the hot leg. The switch for your dimmers shown in current tracks #21-22 shows the dimmer switch on the ground side of the dimmer relay and connected to the relay by a brown/white wire.
double click to enlarge:
fxshov Samba Member
Posted: Mon Feb 19, 2018 8:52 am Post subject: Re: identifying this loose wire under the dash |
I'll try and look into that tonight. Thx... _________________ GOOD AINT CHEAP AND CHEAP ANIT GOOD
73 Bay Window
05 Tundra
12 Scion
93 HD Softtail
18 NX 2500
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Mon Feb 19, 2018 10:27 am Post subject: Re: identifying this loose wire under the dash |
This is where a small test light is invaluable. You can connect the wire to ground through the light, then operate the turn switch (or whatever it is connected to) and see how it affects the light operation. The test light draws so little current that (unless it is wired to some solid state electronic device) you likely won't hurt anything... _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
itsawesty Samba Member
Joined: April 25, 2016 Posts: 101 Location: St Albans, UK
Posted: Mon Feb 19, 2018 10:32 am Post subject: Re: identifying this loose wire under the dash |
is it not E2, current track 22, goes to the dimmer relay. When you pull up on the turn signal lever it activates the dimmer relay, switch between normal/dipped headlights. |
Posted: Mon Feb 19, 2018 12:00 pm Post subject: Re: identifying this loose wire under the dash |
itsawesty wrote: |
E2, the two part turn signal/dimmer switch is shown in two different current tracks including #22. |
Posted: Mon Feb 19, 2018 12:21 pm Post subject: Re: identifying this loose wire under the dash |
Abscate wrote: |
Tram wrote: |
Luvya Tram!
Forget everything around it- those are different issues. The brown wire comes out of a factory loom, doesn't look burned, and has a factory push on connector attached that still has its gold cad original finish.
Luv you too, thweetie. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
fxshov Samba Member
Posted: Mon Feb 19, 2018 6:51 pm Post subject: Re: identifying this loose wire under the dash |
It is indeed a ground wire.
That problem solved. On to other loose wires.
Why would someone cut this wire off the emergency flasher switch?
73 Bay Window
05 Tundra
12 Scion
93 HD Softtail
18 NX 2500
