Coondog Samba Member
Joined: August 19, 2006 Posts: 78 Location: Daphne, AL
Posted: Sun Feb 18, 2018 7:59 pm Post subject: Tail light holes |
Do you guys know if the tail light holes for a '57 are smaller or the same size as the '58 hole? |
Ragtop Samba Member
Joined: November 23, 2003 Posts: 615 Location: Rio Rancho New Mexico
Posted: Sun Feb 18, 2018 8:10 pm Post subject: Re: Tail light holes |
same size |
Posted: Tue Feb 20, 2018 9:48 am Post subject: Re: Tail light holes |
Thanks Ragtop! I'm currently restoring a '58 PGSG. Unfortunately my pristine decklid was stolen. So, I'm committing a terrible VW sin. I'm going to use a third brake light decklid I've had in storage. As a result of that I'll go ahead and use some old bubble tail lights I've had for some time. Makes me feel a little bit better knowing my bus was built in October'57, lol. I might go all the way and drill holes for the reflectors |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Tue Feb 20, 2018 10:12 am Post subject: Re: Tail light holes |
that is a good sin to commit. That extra brake light might one day save your ass _________________ regards
Uli
Okie Adam Samba Member
Joined: November 07, 2003 Posts: 1347 Location: OOOOOOOOOOOOOOOOOklahoma
Posted: Tue Feb 20, 2018 10:21 am Post subject: Re: Tail light holes |
I guess if you're using 58 wiring it could be a third brake light but you'll have to run a new wire so it doesn't flash with one of the turn signals.
With bubble tail lights it is your only brake light. _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
60 Walkthrough Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Wed Feb 21, 2018 11:17 am Post subject: Re: Tail light holes |
Thanks guys for the replies. So, I'm just a tad confused. Were the bubble tail lights originally running lights only? And yes I figured I could just run a wire from the harness to the decklid light. Might not work. Hate to have that as my only source of brake light |
Posted: Wed Feb 21, 2018 12:10 pm Post subject: Re: Tail light holes |
Bubble tail lights were just running lights and turn signals. The only brake light was in the deck lid. If your bus originally has 58 wiring for silver dollar tail lights then the brake lights will be in the turn signal wires. _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
Posted: Wed Feb 21, 2018 2:40 pm Post subject: Re: Tail light holes |
It would be easy enough to have three brake lights. Just run a wire direct from the master cylinder pressure switch to the deck lid. _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
Ragtop Samba Member
Posted: Wed Feb 21, 2018 7:29 pm Post subject: Re: Tail light holes |
Okie Adam wrote: |
It would be easy enough to have three brake lights. Just run a wire direct from the master cylinder pressure switch to the deck lid. |
I did this on my nov 56 panel and it works great. I did use a 6 wire turn signal switch |
Posted: Fri Feb 23, 2018 10:36 am Post subject: Re: Tail light holes |
Great advice. I'll give it a go! |
