Jrm1080 Samba Member
Joined: December 21, 2012 Posts: 104 Location: Phoenix, Az
Posted: Sun Feb 18, 2018 9:06 pm Post subject: Stripped Generator Shaft and Nut. Now what?? |
Someone please tell me I dont have to remove the generator to fix this:
_________________ -Constant over thinker
-Figuring it out as I go. (With lots of Samba inquiries)
67 Type I mostly original semi daily driver (temperature permitting 🔥☀️)
74 Type I work in progress. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34009 Location: Conejo Valley, CA
Posted: Sun Feb 18, 2018 9:08 pm Post subject: Re: Stripped Generator Shaft and Nut. Now what?? |
A new nut and a cleanup of the shaft threads with a die might make it usable. If it won't hold torque, it's time to exchange the generator for a rebuilt unit. |
mukluk Samba Member
Posted: Sun Feb 18, 2018 9:14 pm Post subject: Re: Stripped Generator Shaft and Nut. Now what?? |
The armature threads look like it's mostly just the remains of the stripped threads from the nut stuck in them, I'd say there's a pretty good chance they'll clean up just fine. Might want to try a bit less torque with the new nut. _________________ 1960 Ragtop w/Semaphores "Inga" |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31373 Location: Hot Arizona
Posted: Mon Feb 19, 2018 4:29 am Post subject: Re: Stripped Generator Shaft and Nut. Now what?? |
I used a die, and then a new nut to fix my generator shaft (can't remember now which VW I did that on).
Remember: no law says you need to stay the original size or thread either !!! Mine's not the factory thread anymore !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Tue Feb 20, 2018 5:56 pm Post subject: Re: Stripped Generator Shaft and Nut. Now what?? |
So the consensus from others is that this should be an M10 thread but no one seems confident of the thread pitch.
Can anyone enlighten me so I know where to get the correct die?
....In North Phoenix???
....Cusser???
🤔 _________________ -Constant over thinker
mukluk Samba Member
Posted: Tue Feb 20, 2018 6:28 pm Post subject: Re: Stripped Generator Shaft and Nut. Now what?? |
M12 1.50 _________________ 1960 Ragtop w/Semaphores "Inga" |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Tue Feb 20, 2018 6:30 pm Post subject: Re: Stripped Generator Shaft and Nut. Now what?? |
I don't have access to a Type 1 parts book but the Type 3 parts book shows the generator nut as p/n 111 903 181 (111 prefix indicates part originally a Type 1 part) and some google-fu shows that as an M12 nut with thread pitch 1.5.
I can't vouch for any of that. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Cusser Samba Member
Posted: Tue Feb 20, 2018 7:01 pm Post subject: Re: Stripped Generator Shaft and Nut. Now what?? |
Jrm1080 wrote: |
So the consensus from others is that this should be an M10 thread but no one seems confident of the thread pitch. |
The following diagram shows the stock thread for the generator pulley threads for Type 1 VWs to be 12mm x 1.5mm
Jrm1080 wrote: |
....Cusser???
I cannot remember whether it was on my 1600cc engine or my 1835cc engine which I had this issue with my generator threads, this was definitely over a decade ago.
OK, here's what I know:Sunday/Monday I was up near Prescott, R&R'd the engine of my 1970. Its generator nut took a 19mm socket, but I don't know its thread or pitch. It tightened fine, I don't have an issue with it.
Right now I'm back in north Phoenix. My 1971 with 1835cc engine also takes a 19mm socket for its generator nut. For you, I just went out and removed it, THIS ONE is a 12mm x 1.5mm thread but definitely NOT 10mm for the 12 volt generators !!!
OK, that said: I am in North Phoenix and I do have 12mm x 1.5mm die and tap in my set. I'm near Tatum and Greenway, and I plan to be in the valley Wed. but cannot "promise" I'll be here for all of Thurs.-Sat. So if you want me to help and bring over my tap/die etc., PM me here with your E-mail address. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
bluebus86 Banned
you can measure the pitch with a ruler, or caliper. pitch is expressed in mm for metric. simply measure peak to peak. best to measure several peaks, and divide
say 5 peaks are measured, thats 4 full pitches ( 2 peaks is one pitch) measure across the 5 peaks and say you get 6 mm. 6 mm divided by 4 pitches is 1.5 mm pitch. ypu can look up on thread tables what pitches are offered say a 1.0 mm, and a 1.5mm, select the closest fit. this way you wont come up with 1.4 as a pitch if your measurements are a bit off, you can figure the correct answer is 1.5 mm as only a 1.5 or 1.0 is offered.
for english threads the pitch is expressed as threads per inch, metric is expressed as length of one pitch
Bug On, Metricly, its German after all, _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Tue Feb 20, 2018 8:22 pm Post subject: Re: Stripped Generator Shaft and Nut. Now what?? |
This is Awesome. Thanks everyone. I found what Im looking for. _________________ -Constant over thinker
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24757 Location: Olympia Wash Rinse & Repeat
Posted: Tue Feb 20, 2018 9:44 pm Post subject: Re: Stripped Generator Shaft and Nut. Now what?? |
Using a thread chaser instead of a threading die is much better. Chaser will reshape the threads. The die will cut the threads and if off set will cut the threads thinner, causing the nut to be loose/fall off. _________________ In Stereo, Where Available! |
Cusser Samba Member
Cusser Samba Member
Posted: Wed Feb 21, 2018 3:18 am Post subject: Re: Stripped Generator Shaft and Nut. Now what?? |
Eric&Barb wrote: |
Using a thread chaser instead of a threading die is much better. Chaser will reshape the threads. The die will cut the threads and if off set will cut the threads thinner, causing the nut to be loose/fall off. |
Agree that IF one actually had a 12mm x 1.5mm "thread chaser die" that would be best, but those things are not like readily available, not sure I've ever seen one (just thread chaser taps, usually for spark plugs). This might be one, from Snap-On https://store.snapon.com/Rethreading-Tap-and-Die-S...51936.aspx
That said: I think the 12mm x 1.5mm would do fine if threaded on correctly into the existing threads. Of course any shards of the old nut (if any) would need to be removed from the shaft threads with a pick, and using lube/thread cutting fluid the die would get turned clockwise then counterclockwise as needed.
Sometimes even a stainless steel or hardened nut can be used similarly to clean up slightly damaged threads.
The plan is to avoid generator replacement cost and R&R to salvage what he has.
I'm not a butcher, don't want to cut to 7/16-inch threads !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Wed Feb 21, 2018 10:45 am Post subject: Re: Stripped Generator Shaft and Nut. Now what?? |
Here is a kit for less than $15.00 that has that size.
https://www.amazon.com/METRIC-THREAD-CHASER-RETHRE...ser+metric
A single tap will cost as much.. With the chaser kit one has many more possible tools to fix the next messed up thread. _________________ In Stereo, Where Available! |
Cusser Samba Member
Posted: Wed Feb 21, 2018 1:07 pm Post subject: Re: Stripped Generator Shaft and Nut. Now what?? |
I like that kit myself, I always like to get new tools. So I think I'll order such kit for myself; in the past I've always just used my tap & die set for this, and think that I've only cut "new" threads once (to make a bolt full length for my Frontier).
I'll leave it up to original poster Russ if he wants to get a set of those and try it. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Cusser Samba Member
Posted: Sat Feb 24, 2018 11:57 am Post subject: Re: Stripped Generator Shaft and Nut. Now what?? |
Cusser wrote: |
Eric&Barb wrote: |
That said: I think the 12mm x 1.5mm die would do fine if threaded on correctly into the existing threads. Of course any shards of the old nut (if any) would need to be removed from the shaft threads with a pick, and using lube/thread cutting fluid the die would get turned clockwise then counterclockwise as needed.
The plan is to avoid generator replacement cost and R&R to salvage what he has. |
I went to Russ' house this morning, and in less than 10 minutes we had used my 12mm x 1.5mm die to repair his 1967's generator threads. Was straightforward, no issues; his new 12mm x 1.5mm nut screwed on readily. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Sat Feb 24, 2018 12:12 pm Post subject: Re: Stripped Generator Shaft and Nut. Now what?? |
Cusser wrote: |
Cusser wrote: |
Eric&Barb wrote: |
I went to Russ' house this morning, and in less than 10 minutes we had used my 12mm x 1.5mm die to repair his 1967's generator threads. Was straightforward, no issues; his new 12mm x 1.5mm nut screwed on readily. |
Thanks again Cusser.
Russ. _________________ -Constant over thinker
fly2kads Samba Member
Joined: July 09, 2012 Posts: 148 Location: Roanoke, TX
Posted: Sat Feb 24, 2018 1:23 pm Post subject: Re: Stripped Generator Shaft and Nut. Now what?? |
Cusser wrote: |
Where is that "like" button? |
Posted: Sat Feb 24, 2018 7:15 pm Post subject: Re: Stripped Generator Shaft and Nut. Now what?? |
fly2kads wrote: |
Cusser wrote: |
Wrong Social Media, Fly. Lol! _________________ -Constant over thinker
