Stansell17 Samba Member
Posted: Mon Feb 19, 2018 9:11 am Post subject: Wiring disaster |
Hey guys I bought a 74 beetle a few weeks ago and put in new headlights. When I turn the blinkers on the headlights dim very faintly. The wiring harness is absolutely horrifying and I am looking for some help on finding a schematics for the harness, maybe a hard copy or something I could print out would be extremely helpful! |
sokyjeepster Samba Member
Joined: October 03, 2016 Posts: 22 Location: Franklin, KY
Posted: Mon Feb 19, 2018 9:18 am Post subject: Re: Wiring disaster |
Dim lights are usually a result of a poor ground... |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Mon Feb 19, 2018 9:19 am Post subject: Re: Wiring disaster |
Look at the header directly under the words "TheSamba.Com", follow that over to "Technical" and follow that to "Wiring". |
bluebus86 Banned
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15982 Location: North Florida, USA
Posted: Mon Feb 19, 2018 10:02 am Post subject: Re: Wiring disaster |
Follow the link bluebus86 posted to view the T1 wiring diagrams. Go down to the ‘74 model year and download the file. You can view them, print them... or even take the file to your nearest printing store (eg. Kinkos?) and have them print and laminate the image on a larger sheet of paper like A1 sized paper.
Unfortunately the more recent Bentley Orange service manuals did away with the colored wiring diagrams and show them as B&W (actually grey scale) with color acronyms for each wire. I much prefer the colored diagrams on this site.
If you have trouble reading the ‘73-later wiring diagrams you can print the ‘72 Beetle+SB wiring diagram. It should be about 75% the same. The biggest difference is that the ‘74-‘75 Beetles came with a large Interlock relay which locked out the starter until all seatbelts were buckled. If you or the PO have removed the Interlock relay you may want to wire your car more like the ‘72.
BTW, your headlights pulsing when you have your turn signals ON is a sign your grounds are bad. Clean up all wiring connections paying special attention to brown wires that connect to ground. Make sure these have a clean connection. Wire brush both the connector and the spot on the body where they connect.
The biggest problem with a 40yr old car that still has its original wiring is that ALL exposed connections will need cleaning to restore the original wiring resistance. Left as is, there is greater resistance down each circuit path which reduces the current that makes it to the end of the circuit. _________________ AshMan40
gt1953 Samba Member
Posted: Mon Feb 19, 2018 3:07 pm Post subject: Re: Wiring disaster |
Clean every ground connection you can find. Obtain a dremel tool with the small wire wheel. Make them all bright and shiny. Disconnect the battery and clean the all of the fuse connections also. Oh boy stuff will work even better. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
CWAVE Samba Member
Posted: Mon Feb 19, 2018 3:20 pm Post subject: Re: Wiring disaster |
Here you go.
Everything you'd ever want to know about your VW, including wiring!
VW.Workshop.Manuals.Complete.1969-1976
https://drive.google.com/open?id=1gRAruyQ0kgPByWlIiot63_60L4QRalsB
VW.Workshop.Manuals.Complete.1969-1976 ZIPPED
https://drive.google.com/open?id=1H9uKNbDgqHx3DnxomZIb84zWzJcXYoKu
CWAVE
Stansell17 wrote: |
Busdriver79 Samba Member
Joined: July 22, 2011 Posts: 1655 Location: The Peoples' Republic of "No" Jersey
Posted: Wed Feb 21, 2018 9:11 am Post subject: Re: Wiring disaster |
The wiring in my 71 Super Beetle was a total disaster when I bought it...I removed every single inch of wiring with cutting pliers and chucked them in the trash can...I'll be wiring the entire car from scratch...the engine and charging system will be first, with the ign. switch to be mounted on the tunnel...everything else will be wired, lights, wipers, turn signals and stop lights, with a modern fuse box under the front lid...nothing fancy, just functional...I may even use a toggle switch and a push button for starting the engine, with the ign. switch to deter theft...I've done this many times an many different vehicles with great success. |
