Sahara74 Samba Member
Joined: December 12, 2013 Posts: 150 Location: Northern California
Posted: Mon Feb 19, 2018 6:53 pm Post subject: Dizzy Cam Lube substitute |
Greetings All !
Since Bosch distributor cam lube is rare enough to be handed down through families, what about a reasonable substitute ? I haven't had much luck finding Mallory 26015 either. I've seen Permatex Dielectic Tune-up Grease suggested. Any thoughts ? Sorry if this has been addressed and I missed it. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Mon Feb 19, 2018 6:55 pm Post subject: Re: Dizzy Cam Lube substitute |
_________________ Glenn
Member #1009
#BlueSquare |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Mon Feb 19, 2018 6:59 pm Post subject: Re: Dizzy Cam Lube substitute |
I run points in my 2 VWs, have not had issues with a small dab of wheel bearing grease on the distributor cam. I once had a tube of distributor cam lubricant I bought from JC Whitney in the 1970s, that's still around "somewhere". _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Glenn Mr. 010
Posted: Mon Feb 19, 2018 7:20 pm Post subject: Re: Dizzy Cam Lube substitute |
Wheel bearing grease can be slung all over the place at high rpm. it's just not sticky enough.
Member #1009
#BlueSquare |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Mon Feb 19, 2018 8:22 pm Post subject: Re: Dizzy Cam Lube substitute |
I have always used GM distributoe cam lobe grease. Good stuff, but they stopped making it a few years ago. Thanfully a tube could last three or four mechanics several years. There is another product based off of that GM grease, sold on Amazon for 16 bucks. Probably last a single user a few decades. Heres the link;
Super Lube 2 Distributor Cam Grease - 2 gram pillow pack https://www.amazon.com/dp/B071SLLQFP/ref=cm_sw_r_cp_tai_Jn5IAbABH75VK _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Tue Feb 20, 2018 5:57 am Post subject: Re: Dizzy Cam Lube substitute |
Thanks for the tips !! Found some Standard Lubricam on Ebay for a good price. I must confess that I have been using standard lithium for years. Looking forward to improved points life now that I know better. |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Tue Feb 20, 2018 10:23 am Post subject: Re: Dizzy Cam Lube substitute |
Glenn:
Not Bosch?
Bosch is no longer producing their distributor cam grease, just teasing. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Cusser Samba Member
