XXX-1.8T Samba Member
Posted: Tue Feb 20, 2018 3:21 pm Post subject: Painting gear Shifter DIY Instructions? |
Anyone have any gear Shifter do it your self instructions?
is it simply unbolt the shifter?
Mines looking scratched and want to repaint it etc |
socal1904 Samba Member
Posted: Tue Feb 20, 2018 4:19 pm Post subject: Re: Painting gear Shifter DIY Instructions? |
Pretty simple to take apart, once its apart you can re grease everything, also good time to check the plate underneath and replace as needed. |
Posted: Tue Feb 20, 2018 4:23 pm Post subject: Re: Painting gear Shifter DIY Instructions? |
OK so just undo the 2 bolts and thats it? |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Tue Feb 20, 2018 4:44 pm Post subject: Re: Painting gear Shifter DIY Instructions? |
XXX-1.8T wrote: |
Yes, but I would make paint or scratch marks on the tunnel so the plate can be put back in the same place. You will have less trouble adjusting it if you do so. |
Posted: Tue Feb 20, 2018 4:47 pm Post subject: Re: Painting gear Shifter DIY Instructions? |
KTPhil wrote: |
XXX-1.8T wrote: |
OK thanks! |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7023 Location: Clyde, TX
Posted: Tue Feb 20, 2018 6:19 pm Post subject: Re: Painting gear Shifter DIY Instructions? |
You could also carefully mask the shifter and paint it in situ. Or you can paint it without masking... guess it depends on how nice a job you'd like to make it and what method of paint application you wish to use. _________________ 1960 Ragtop w/Semaphores "Inga" |
rcooled Samba Member
Joined: September 20, 2008 Posts: 2504 Location: Santa Cruz, CA
Posted: Tue Feb 20, 2018 6:44 pm Post subject: Re: Painting gear Shifter DIY Instructions? |
You might consider powder coating the shifter instead of painting. It works well for the handbrake lever too. The constant rubbing of your fingers just below the shift knob will soon wear the rattle-can paint off just like the original finish was worn off. And dropping seat belt buckles down between the seats dings up the handbrake lever. Powder coat, when properly applied, resists wear and chipping much better than paint. You can get a near-perfect match to the stock color too. _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
Posted: Tue Feb 20, 2018 6:48 pm Post subject: Re: Painting gear Shifter DIY Instructions? |
mukluk wrote: |
You could also carefully mask the shifter and paint it in situ. Or you can paint it without masking... guess it depends on how nice a job you'd like to make it and what method of paint application you wish to use. |
was thinking this but knowing me i'd get paint everywhere |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Tue Feb 20, 2018 7:02 pm Post subject: Re: Painting gear Shifter DIY Instructions? |
If you powdercoat- remember the plastic knob's threads are easily cracked as you tighten it. _________________
EverettB wrote: |
FU#5 |
EVfun Samba Member
Posted: Tue Feb 20, 2018 7:36 pm Post subject: Re: Painting gear Shifter DIY Instructions? |
I like to lay strips of masking tape on the tunnel along all 4 flats on the shifter base so I can mark the location without damaging any paint.
If you want to paint it leave the greasing for much later. I recommend sanding off all the paint that isn't your finish color on the 6 inches below the knob so future wear looks nice (no color bands.) _________________
Wildthings wrote: |
HippyTom Samba Member
Joined: December 18, 2013 Posts: 676 Location: Florida, West Pasco
Posted: Tue Feb 20, 2018 10:25 pm Post subject: Re: Painting gear Shifter DIY Instructions? |
I found rustoleum smoke gray in a little can thinned down with paint thinner then applied with a foam "brush" leveled out smooth and looked factory on the gear shift and e-brake. No need to remove or mask off. |
