Mattwynn88 Samba Member
Joined: February 20, 2018 Posts: 4 Location: Washington
Posted: Tue Feb 20, 2018 4:49 pm Post subject: 1993 Eurovan Rear Smoke? |
Hey everyone.
I’m currently working on my friends van. I don’t know much about euro vans but I know some basics. He has been telling me there is exhaust coming from the rear heater behind the passenger seat. Is this normal? If not what are some things I can look at to fix it!
Any advice is appreciated thanks! |
streamr Samba Member
Joined: February 26, 2007 Posts: 555 Location: Southwest FL
Posted: Thu Feb 22, 2018 5:04 am Post subject: Re: 1993 Eurovan Rear Smoke? |
Well, I wouldn't think exhaust coming into the vehicle is normal, hope he's driving with the windows down. I would check under the van to see where the exhaust leak is. It's working its way in somehow so I would look for cracks, rust holes, open seams, etc. Good luck. _________________ '03 MV |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22573 Location: NYC/Upstate/ROW
Posted: Thu Feb 22, 2018 7:03 am Post subject: Re: 1993 Eurovan Rear Smoke? |
He's got steam coming from a broken heat rear exchanger, gazing into my crystal ball. Ask him if the smoke has a sweet odour. Thats French for smell _________________ .ssS! |
Posted: Fri Feb 23, 2018 8:23 pm Post subject: Re: 1993 Eurovan Rear Smoke? |
Abscate wrote: |
He's got steam coming from a broken heat rear exchanger, gazing into my crystal ball. Ask him if the smoke has a sweet odour. Thats French for smell |
Thanks for the reply! It does have a little sweet odor smell to it. When you say rear exchanger is the the heater core you’re talking about? |
Posted: Fri Feb 23, 2018 9:00 pm Post subject: Re: 1993 Eurovan Rear Smoke? |
Correct, rear heater core _________________ .ssS! |
Posted: Sat Feb 24, 2018 5:24 am Post subject: Re: 1993 Eurovan Rear Smoke? |
Abscate wrote: |
Correct, rear heater core |
Is it possible for it to leak up to the floor? |
Posted: Sat Feb 24, 2018 5:27 am Post subject: Re: 1993 Eurovan Rear Smoke? |
Mattwynn88 wrote: |
Abscate wrote: |
Probably if it is spritzing? The cooling system is under pressure so coolant could spray up, I guess. That pressure is important for your engine so I would explore and fix that asap _________________ .ssS! |
Posted: Sun Feb 25, 2018 1:09 pm Post subject: Re: 1993 Eurovan Rear Smoke? |
Abscate wrote: |
Mattwynn88 wrote: |
Abscate wrote: |
Probably if it is spritzing? The cooling system is under pressure so coolant could spray up, I guess. That pressure is important for your engine so I would explore and fix that asap |
Rad thank you! I will check that and see! Thanks for your help! |
