Mid West Dubber Samba Member
Joined: July 11, 2011 Posts: 315 Location: Natimuk, VICTORIA, AUSTRALIA
Posted: Tue Feb 20, 2018 5:18 pm Post subject: RHD 67 Notch |
A few years ago I bought two Notchbacks, a 67 and a 70. The 1970 was already registered but needed a full mechanical overhaul to get the registration transferred across. I really wanted to build the early Notch first but I figured it would be easier to get the late one on the road quicker and be driving a Notch sooner.
Have had the 70 on the road now for a little while so Ive been getting stuck into this early Notch project when time is available.
Posted: Tue Feb 20, 2018 5:21 pm Post subject: Re: Aussie 67 Notch |
I will try to get this build thread up to date over the coming days |
XXX-1.8T Samba Member
Posted: Tue Feb 20, 2018 5:50 pm Post subject: Re: Aussie 67 Notch |
What colour red is it? |
Posted: Tue Feb 20, 2018 6:02 pm Post subject: Re: Aussie 67 Notch |
XXX-1.8T wrote: |
It was repainted in the 90s and I believe it is Picardy Red which was a colour used on HK Holden Monaros |
Posted: Tue Feb 20, 2018 6:48 pm Post subject: Re: Aussie 67 Notch |
Unbolted the bumpers and fenders. Pretty stoked to find no rust in the inner guards!
Posted: Tue Feb 20, 2018 6:50 pm Post subject: Re: Aussie 67 Notch |
Looks like Kings Red L30a do you know what the factory colour is? |
Posted: Tue Feb 20, 2018 6:56 pm Post subject: Re: Aussie 67 Notch |
XXX-1.8T wrote: |
It does look similar but I have been in contact with the guy who painted it and he said it is definitely a Holden colour. The original colour was either Savannah Beige or Sahara Beige I am told |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7549 Location: Santa Cruz
Posted: Wed Feb 21, 2018 12:00 am Post subject: Re: Aussie 67 Notch |
Look forward to seeing this project roll,
But,
Love that Four-Five!
Is that yours? _________________ Bus Motor Build
Whats That Noise?!? |
Posted: Wed Feb 21, 2018 12:42 am Post subject: Re: Aussie 67 Notch |
Clatter wrote: |
But,
Is that yours? |
Thanks Clatter, the 45 is a project that Dad and I have been playing around with! |
andybla Samba Member
Posted: Wed Feb 21, 2018 7:58 am Post subject: Re: Aussie 67 Notch |
Good luck, looks very solid underneath |
Bobnotch Samba Member
Posted: Wed Feb 21, 2018 11:45 am Post subject: Re: Aussie 67 Notch |
That 67 looks very clean. Was it originally assembled in OZ? Or is it a German built car? Either way it's clean and should be a fairly easy resto. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Thu Feb 22, 2018 3:30 am Post subject: Re: Aussie 67 Notch |
Bobnotch wrote: |
That 67 looks very clean. Was it originally assembled in OZ? Or is it a German built car? Either way it's clean and should be a fairly easy resto. |
Thanks Bobnotch, I believe it is an OZ assembled car |
Posted: Thu Feb 22, 2018 3:36 am Post subject: Re: Aussie 67 Notch |
I stripped a few more parts off the notch including doors, bonnet, decklid, fuel tank etc.
with the fuel tank out it made it a lot easier to start disassembling the front end and brakes to make a start on cleaning everything up.
Front end disassembled gave me more room to clean back everything and I prepared the inner fender etc for paint.
A little more work painting some front end and brake stuff and it was almost ready to start renewing and putting the front end back together and back on wheels.
Posted: Thu Feb 22, 2018 3:38 am Post subject: Re: Aussie 67 Notch |
The steering box that was on the car was worn but I had another one on my spare type 3 beam which felt really good.
Unbolted it, gave it a clean up, disassembled a little bit of it and cleaned out the inside, put it back together and gave it a lick of paint.
Posted: Thu Feb 22, 2018 3:39 am Post subject: Re: Aussie 67 Notch |
Also took the discs off, cleaned them up and painted them and had them machined. Also painted the backing plates and calipers.
Before..
After..
Posted: Thu Feb 22, 2018 3:41 am Post subject: Re: Aussie 67 Notch |
There were only one or two spots of rust in the body just around the base of the windscreen. Will be doing the finishing touches to this repair when I start paint prep down the track
Posted: Thu Feb 22, 2018 11:48 am Post subject: Re: Aussie 67 Notch |
Mid West Dubber wrote: |
Bobnotch wrote: |
Just asking, as I thought OZ cars had 5 lugs up thru 69, and yours has 4 lugs. I suppose a PO could have converted them.
Car is looking good though. Nice work. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Thu Feb 22, 2018 12:58 pm Post subject: Re: Aussie 67 Notch |
Bobnotch wrote: |
Bobnotch wrote: |
Car is looking good though. Nice work. |
It was originally wide 5 and I have now changed it back to wide 5, I will post that update soon |
Posted: Thu Feb 22, 2018 6:21 pm Post subject: Re: Aussie 67 Notch |
I decided to get another pair of doors as the ones on the car were split and dented.
The hinges on the passenger door needed a small tweak but now have it opening and closing nicely. The drivers door was a little more work as the spot where the lower hinge bolts to the A pillar was split, causing the door to sag. With a few welds and tweaks both doors are opening and closing great.
The doors need to be pulled off and need a little bit of body work and a rebuild but are much better than the doors I had.
Posted: Thu Feb 22, 2018 6:26 pm Post subject: Re: Aussie 67 Notch |
Pulled the engine out and found two small areas of rust which needed attention...
All rust converted and fixed and ready for the engine bay to be cleaned back and paint applied. |
