bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4348 Location: United States, Iowa
Posted: Thu Feb 22, 2018 7:53 am Post subject: Re: Innacurate speedometer |
dobryan wrote: |
I can't believe the suggestions to spend $$$ and get larger radius tires are serious advice for the OP. ...
Your issue is with the speedo unit itself, not the tires, stock tires are just fine. |
Indeed, I was not intending to have OP do something that would not be in their best interest. Just wanted to say that if the tires were quite old, then they could consider a slight change. You are completely correct for calling me on this, as I also feel very strongly that the stock tire (at least the stock width and diameter) is quite important overall. I think a slight change would be on the OK side, but right, I actually advocate regularly to NOT go above 26" diameter as this is a cascading problem for both engine power and the effect on the spare clamshell. (Technically, I think a 26.5" tire will "fit" the clamshell, but I'd still stay smaller)
Thanks for the call-out Dave.
To the OP, I agree, there are places to send that speedo out to for calibration, and there are DIY threads, BUT, you should consider sourcing a spare and try it before going that route.
Hope things turn out well for you!
-bobby _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
WestfaliaMike Samba Member
Posted: Thu Feb 22, 2018 9:03 am Post subject: Re: Innacurate speedometer |
?Waldo? wrote: |
MichaelCampingInVA wrote: |
The problem I have is the needle is slow to move up |
That's a common issue with Vanagons. Put in a more powerful engine and the speedometer will move up more quickly. |
haha,
Thats on the “to-do” list _________________ 1981 Vanagon Westfalia
1983 Vanagon Passanger (Parts Vehicle)
2016 Passat TSI |
Posted: Thu Feb 22, 2018 9:55 am Post subject: Re: Innacurate speedometer |
Everyone wants more power from the engine compartment. I got a '93 EJ22 and was moving towards installing it. I think the EJ22 has 40 or so more HP, so that was going to be great. Turns out that my kids overheated their 2.1WBX and I sicked 'em on the swap I was half way through. I got that Subi for $200, drivable. Not sure I would want the EJ22 OBD1 if I had to go through it all again. I'm looking for an OBD2, but I have come to the conclusion that as long as I can keep stock, I will. Even though I WANT more HP, stock has always treated me well, in my 30-ish VW's I've owned over the years.
Now, GW is offering a replacement Fuel Injection kit for the Stock, and their larger displacement engines based off the 2.1 WBX bottom end. Seems like a good thing. Also, Marco is nearly ready with his FI/engine management replacement that will allow for a turbo addition on top of the FI upgrade. Both of these options are keeping my interest in stock or stock based engines alive.
There is one thing that will need attention regardless; in your case, the auto trans, and in mine the manual. Your 3'rd might top out at around 65-70 with screaming RPM's. I can push my 4th to 85 with my stock diameter tires. It is not wise tho. There's a Ring and Pinion change or gears change that makes modern driving more reasonable, but consider your options, your budget, etc. before you start dumping money into any of it. For now, I got lucky to NOT be doing the conversion on my van... Let the kids do it For the time being, I am concentrating on seam rust, kitchen rot, and general preservation, and that is taking up any spare change I have.
Good luck, and keep the great attitude you've got !!!
Jon_slider Samba Member
Posted: Thu Feb 22, 2018 1:52 pm Post subject: Re: Innacurate speedometer |
WannaDriveFar wrote: |
if I want to go 45 mph, my speedometer will read 60. |
get the speedo calibrated, click to see where to take it.
http://bfy.tw/GkpG _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
cmayna Samba Member
Joined: August 18, 2014 Posts: 1147 Location: SF Bay area, CA
Posted: Thu Feb 22, 2018 7:38 pm Post subject: Re: Innacurate speedometer |
Again,
What are you using to confirm that your speed is off? _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
WannaDriveFar Samba Member
Joined: September 02, 2017 Posts: 46 Location: Virginia
Posted: Fri Feb 23, 2018 12:09 pm Post subject: Re: Innacurate speedometer |
I was originally just using mile markers and my clock to do the math on my actual speed. Yesterday I downloaded a speedometer app to confirm, and yeah, my speedometer is about 20 mph higher than my real speed. _________________ 1983 Vanagon GL Automatic |
Posted: Fri Feb 23, 2018 1:15 pm Post subject: Re: Innacurate speedometer |
[quote="WannaDriveFar"I downloaded a speedometer app to confirm, and yeah, my speedometer is about 20 mph higher than my real speed.[/quote]
that is way out of normal range. typically speedos read 5% faster than true, with stock tire size like you have
you may learn from a speedo shop that your speedo needs some new parts, it is definitely out of spec. _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Fri Feb 23, 2018 1:35 pm Post subject: Re: Innacurate speedometer |
But was the odometer off?
If the odometer is reading accurate and the speedo is off, then some calibration will be needed. If both are off, then the gearing is not correct for your tires. |
Posted: Fri Feb 23, 2018 1:54 pm Post subject: Re: Innacurate speedometer |
If your odometer is off by a similar amount take a look where the mileage counter for the oxygen sensor resides and see if someone added a speedometer ratio adapter there. A PO may have run tiny tires and added an adapter to get the speedo to read correctly for him.
https://www.ebay.com/i/132343318658?chn=ps |
