DE Type 3 Samba Member
Joined: September 14, 2017 Posts: 23 Location: Wilmington, Delaware
Posted: Wed Feb 21, 2018 5:27 pm Post subject: Rear heat exchanger removal from cylinder head |
I need a little advise on removing the rear heat exchanger from the cylinder head. I can get the outside nuts off but having trouble getting to the inside nuts on the inside. Can someone help with the best way to access the nut? I am almost to the point of cutting the heat exchanger off. Any suggestions would be appreciated |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Wed Feb 21, 2018 7:39 pm Post subject: Re: Rear heat exchanger removal from cylinder head |
A 13mm on a LONG extension will get one of them (can't remember which side) and an S shaped box end is needed on the other.
_________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34022 Location: Conejo Valley, CA
Posted: Thu Feb 22, 2018 9:38 am Post subject: Re: Rear heat exchanger removal from cylinder head |
...and when you reinstall, use the thinner and smaller 12(?)mm copper nuts. |
Slow 1200 Samba Member
Posted: Fri Feb 23, 2018 2:23 am Post subject: Re: Rear heat exchanger removal from cylinder head |
KTPhil wrote: |
personally I hate those copper nuts, they do make access easier, but you have to use the wrench all the way in or out instead to just the last tightening (or first loosening)and use your pinky finger for the rest of the threads |
