The Vos Samba Member
Joined: November 04, 2011 Posts: 44 Location: N. La. Swamps
Posted: Wed Feb 21, 2018 8:59 pm Post subject: J Tubes or Not? |
[]My heater boxes are rust buckets and I am thinking of going with J Tubes now! I live in Louisiana so,,, the heaters are not being used and disconnected anyways! My question is, Does the cooling tins that runs under the cylinders attach to the J Tube in any way like it does the heater boxs, or do you just take them off and leave them off? Seems to me that the Tubes would heat the cylinders even more if you have to leave them off????[/b] |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
mukluk Samba Member
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Wed Feb 21, 2018 10:08 pm Post subject: Re: J Tubes or Not? |
i made my own industrial tins, out of a piece of left over piece of sheet metal. Used a template on tS. In the search function I typed in "industrial tins". First or second hit. They attach to the sleds and just hoover above the Jtubes.
My Bug was running a little hot. I was using an IR temp gun to measure. Manufactured and installed these tins and dropped, somewhere around 15 - 20 degrees!
[/img] _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76937 Location: Sneaking up behind you
SLO-N-LO-69 Samba Member
Joined: July 06, 2006 Posts: 629 Location: Central Florida
Posted: Fri Feb 23, 2018 10:13 pm Post subject: Re: J Tubes or Not? |
My jtubes have mounts for the stock tins. You need them for proper cooling and protection but here in FL I didn't need heat either. Find the tubes with the mounts so you can use the original tins. |
