davidw99 Samba Member
Joined: September 04, 2003 Posts: 696 Location: Boston, MA
Posted: Thu Feb 22, 2018 6:46 am Post subject: Check Clutch Wear - Engine out but clutch still installed |
Hello,
Is it possible to check clutch wear with the clutch still installed on the engine, engine out of car? I'm having a hard time visualizing the edge of the clutch disk. Wondering if it is possible or if there some info I'm missing. _________________ Dave
'73 Saturn Yellow Sports Bug that has undergone a full pan off restoration. "Herbert IV."
'67 Sedan. "Bellamy." Currently being "refreshed" and recently repainted. |
Zundfolge1432 Samba Member
Posted: Thu Feb 22, 2018 6:58 am Post subject: Re: Check Clutch Wear - Engine out but clutch still installed |
Remove the pressure plate grab the clutch disc and using an 8mm open end wrench should just fit the thickness. This has worked for years. You can clean it and the flywheel with brake cleaner or lacquer thinner, don’t forget to lube the gland nut and you’ll need a line up tool to put it back together, those bolts get 18 ft lbs take em down evenly. Use a screwdriver for a flywheel lock. |
Posted: Thu Feb 22, 2018 7:07 am Post subject: Re: Check Clutch Wear - Engine out but clutch still installed |
I was hoping to avoid that by getting a "peek" at the edge of the clutch disc but, as I have the engine out of the car, I guess I'll do as you suggest. Thank you. _________________ Dave
Cali_Army_Guy Samba Member
Joined: March 19, 2015 Posts: 2094 Location: Stockton, CA
Posted: Thu Feb 22, 2018 7:17 am Post subject: Re: Check Clutch Wear - Engine out but clutch still installed |
davidw99 wrote: |
I was hoping to avoid that by getting a "peek" at the edge of the clutch disc but, as I have the engine out of the car, I guess I'll do as you suggest. Thank you. |
You already have the motor out. Literally takes another 10-15 minutes to pull the pressure plate and check the clutch and bolt it back together. I have an old shaft from another trans that I use as my clutch alignment tool. Easy peasy. _________________ 2015 VW Passat Wolfsburg Edition
1966 VW Beetle - Sold |
Posted: Thu Feb 22, 2018 7:25 am Post subject: Re: Check Clutch Wear - Engine out but clutch still installed |
Cali_Army_Guy wrote: |
davidw99 wrote: |
You already have the motor out. Literally takes another 10-15 minutes to pull the pressure plate and check the clutch and bolt it back together. I have an old shaft from another trans that I use as my clutch alignment tool. Easy peasy. |
And you get to peek at gland nut every once in awhile the bearing goes south, it would be good to catch that early at very least you can relube it. |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Thu Feb 22, 2018 8:51 am Post subject: Re: Check Clutch Wear - Engine out but clutch still installed |
Yeah it's literally what, 6 bolts, and the pressure plate is off.
You may find a flywheel lock handy for torquing the pressure plate bolts back to spec when re-installing.
Also you want to loosen the pressure plate bolts in a cross-wise pattern and evenly so as not to warp the pressure plate. I may be a bit over-cautious about that but I like to do about 1 turn of each bolt in a cross-wise pattern until all the spring tension is relieved.
Same for re-installation.
For reinstalling you will want to have handy one of those clutch alignment tools that all the VW stores sell for a couple bucks. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Thu Feb 22, 2018 9:08 am Post subject: Re: Check Clutch Wear - Engine out but clutch still installed |
Definitely check the ling thickness and for and oil film on the disc, pressure plate, or flywheel while you're so close !!!
sjbartnik wrote: |
For reinstalling you will want to have handy one of those clutch alignment tools that all the VW stores sell for a couple bucks. |
About a decade ago when I couldn't find my alignment tool, I wrapped duct tape to build up the diameter of a dowel that fit into the flywheel gland nut.
Yes, I've since found the alignment tool, and some nice long-forgotten soul here sent me a couple of transmission shafts to use as alignment tools. But I also remember cutting off a piece of broom handle and whittling the end small enough to fit into the gland nut.
Last Sunday, I used one of those transmission shafts to align as I installed/torqued the pressure plate, engine slipped right in, no helper needed or available.
Yes, if one does not have a flywheel lock, a large screwdriver wedged in the flywheel teeth can prevent the flywheel from turning. Another trick would be to wedge a VW lug bolt wrench between gear teeth and the cylinder head stud. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Thu Feb 22, 2018 10:09 am Post subject: Re: Check Clutch Wear - Engine out but clutch still installed |
Thank you all. I'll take care of it this weekend. _________________ Dave
bluebus86 Banned
Posted: Thu Feb 22, 2018 10:17 am Post subject: Re: Check Clutch Wear - Engine out but clutch still installed |
a breaker bar on the pulley nut can also be used to hold the engine from turning when doing clutch work.
Please mark the clutch so it is remounted in same position. often the flywheel,is balanced with the clutch, so put it back the same way for best results.
also while the motor is out, check the crank endplay, just because you can
Good Luck, Bug On, With Smart Shifting! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34013 Location: Conejo Valley, CA
Posted: Thu Feb 22, 2018 12:04 pm Post subject: Re: Check Clutch Wear - Engine out but clutch still installed |
Yes, any time the engine is out, do the following:
1) Check crank endplay and record it in a log.
2) Check clutch lining thickness.
3) Check the TO bearing and mounts.
4) Make sure there is thick grease in the pilot bearing, but not too much.
5) Check your starter bushing.
6) Check your axle boots, and make sure your tranny fill plug is easily removed.
7) Do any general cleanup and inspection of rubber parts, wiring and tinware while you have easy access.
These are impossible or a PITA with the engine in place, so make life easy and do this stuff now. |
Cusser Samba Member
Posted: Thu Feb 22, 2018 12:48 pm Post subject: Re: Check Clutch Wear - Engine out but clutch still installed |
KTPhil wrote: |
I don't typically do #1 (Check crank endplay and record it in a log) Last week on my 1970 I left the flywheel installed.
I would add
Grease the clutch cable threads
9) Check condition of the flexible fuel line coming from the pan tube
10) Check rear motor mounts _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Thu Feb 22, 2018 12:58 pm Post subject: Re: Check Clutch Wear - Engine out but clutch still installed |
Numbers:
1 - hadn't thought about this, will do
2 - will do
3 - checks ok
4 - also, hadn't thought about this, will do
5 - replaced
6 - replaced
7 - done
8 - done
9 - old one gone, new one to be installed along with new firewall grommet
10 - replaced along with front
Also, engine compartment seals replaced and missing engine cooling tin to be installed. _________________ Dave
mukluk Samba Member
Posted: Thu Feb 22, 2018 1:17 pm Post subject: Re: Check Clutch Wear - Engine out but clutch still installed |
This is also the perfect time to do a really good cleanup of the engine bay, fix any wiring issues for tail&backup lights, replace firewall insulation, replace leaky swingaxle boots, check the transaxle output shaft seal, replace the starter bushing, rebuild/refresh the starter.... _________________ 1960 Ragtop w/Semaphores "Inga" |
Cusser Samba Member
Posted: Thu Feb 22, 2018 2:08 pm Post subject: Re: Check Clutch Wear - Engine out but clutch still installed |
davidw99 wrote: |
Also, engine compartment seals replaced and missing engine cooling tin to be installed. |
I replaced my 1970's engine seals for first time last year; they were harder than a teenager in the 1960s seeing his first Ann-Margret movie ! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Fri Feb 23, 2018 4:43 am Post subject: Re: Check Clutch Wear - Engine out but clutch still installed |
Cusser wrote: |
davidw99 wrote: |
I replaced my 1970's engine seals for first time last year; they were harder than a teenager in the 1960s seeing his first Ann-Margret movie ! |
Good analogy! Mine were the same. _________________ Dave
gt1953 Samba Member
Posted: Fri Feb 23, 2018 7:11 am Post subject: Re: Check Clutch Wear - Engine out but clutch still installed |
({I replaced my 1970's engine seals for first time last year; they were harder than a teenager in the 1960s seeing his first Ann-Margret movie !})
Cusser I had an electronics instructor whom compared electronic associated stuff to sex. Did you ever teach?? _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
KTPhil Samba Member
Posted: Fri Feb 23, 2018 9:30 am Post subject: Re: Check Clutch Wear - Engine out but clutch still installed |
I had a junior high school electronics teacher back in the early 70s who was very naïve and didn't know why the whole class was laughing hysterically when he instructed us on the art of soldering: "A tight connection is a necessary prerequisite to a proper joint."
Cusser Samba Member
Posted: Fri Feb 23, 2018 11:59 am Post subject: Re: Check Clutch Wear - Engine out but clutch still installed |
gt1953 wrote: |
Cusser I had an electronics instructor whom compared electronic associated stuff to sex. Did you ever teach?? |
No, never taught electronics, but know the difference between male and female terminals.
Never taught banking either, but know that early withdrawal results in loss of interest ! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Mon Feb 26, 2018 4:02 am Post subject: Re: Check Clutch Wear - Engine out but clutch still installed |
OK, I checked the clutch and it looks almost brand new. A Brazilian-made SACHS rigid disc. Everything else under the pressure plate checks out good, too. It was easy. Glad I did it. Thanks everyone. _________________ Dave
