Heater channel rear Y tubes
ReefchiefReece
ReefchiefReece is offline
PostPosted: Sat Feb 24, 2018 3:34 am    Post subject: Heater channel rear Y tubes Reply with quote
Hi all
Need some advise on how to remove the Y tubes with insulation on (think its a muffler for the sound or something) that connect to the heater channels that are in the rear footwell as i need to access the pan underneath to restore it ??
Thanks
Vanillagurilla
Vanillagurilla is offline
PostPosted: Sat Feb 24, 2018 3:47 am    Post subject: Re: Heater channel rear Y tubes Reply with quote
I believe there welded in. Repair from underneath maybe?
AlmostHeavenWV_VW Premium Member
AlmostHeavenWV_VW is offline
PostPosted: Sat Feb 24, 2018 7:29 am    Post subject: Re: Heater channel rear Y tubes Reply with quote
I'm assuming you mean these:
They are just friction fit on the rear part and have one screw/bolt on the part that connects to the heater channel (you can see the screw on the front part in this pic)
Be careful when taking these Y's off. The rear portion that comes through the body into the passenger compartment (the 'snout' that the Y slides onto) is made of a heat-resistant plastic called "Bakelite". It's heat resistant but quite brittle.
1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor
Bill T.
Bill T. is offline
PostPosted: Sat Feb 24, 2018 1:36 pm    Post subject: Re: Heater channel rear Y tubes Reply with quote
I've just done something very similar. I had to pull the Y tubes to replace the pans on my 78 and in the process I broke one of the Bakelite tubes. I advise you loosen the Bakelite tubes from underneath the car. Jack up the car and crawl underneath (with jack stands secure) and loosen/remove the two bolts that hold the tubes to the body of the car. The passenger side comes out easy. I could not remove the drivers side from the vehicle, but loosening the Bakelite tube gives you more wiggle room to get the Y tube out. In this case the extra step of loosening the Bakelite tubes when removing the Y tubes could save you $50 (each if you break the Bakelite) Good luck
'78 Super Beetle Convertible
'72 Triumph TR6
