busboyjake Samba Member
Joined: September 22, 2002 Posts: 393 Location: Colorado
Posted: Sat Feb 24, 2018 8:35 am Post subject: Any threads about welding the rear frame back in? |
I'm about to weld a rear tortion housing back into a '69 bus that had it cut out for a rail, trike or irs conversion. Anyone done this before? Pics? _________________ 1965 Pearl White Caravelle Camper
1978 Dakota Beige Westy
1969 Montana Red Westy (for sale soon) |
JaimeH Samba Member
Joined: April 24, 2012 Posts: 265 Location: Canterbury, NH
Posted: Sat Feb 24, 2018 5:10 pm Post subject: Re: Any threads about welding the rear frame back in? |
Try searching for Torsion Tube. I know BusDaddy did a pretty good write up on it. _________________ 1978 Transporter 2.0 FI, BA6
Special Thanks to Razor's Customs, Boscawen, NH |
JaimeH Samba Member
Posted: Sat Feb 24, 2018 5:12 pm Post subject: Re: Any threads about welding the rear frame back in? |
busdaddy Samba Member
Posted: Sat Feb 24, 2018 5:22 pm Post subject: Re: Any threads about welding the rear frame back in? |
Well, that was a repair to the frame where it rots around the tube, it sounds like Jake's is missing completely and laying nearby on the floor.
There was a few threads in the split bus forum doing the de-buggy donor thing, but I just can't find them at the moment.
Is the donor part from the same bus?, or another?, are there any body remnants on the part that could serve as reference points before you grind them off? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
SGKent Samba Member
Posted: Sat Feb 24, 2018 8:06 pm Post subject: Re: Any threads about welding the rear frame back in? |
I'd have a friend bring a bay over and fabricate a quality alignment jig using the other bus, then clamp it to yours to hold the parts while you weld them up. Set it on a 2nd bus to fine tune it before you use it on yours. Once you have it you could sell it to the next guy doing the same job. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Feb 24, 2018 10:53 pm Post subject: Re: Any threads about welding the rear frame back in? |
Just find another bus body in decent shape and transfer your mechanical over. |
BusLust Samba Member
Joined: September 20, 2016 Posts: 185 Location: High Springs, Florida
Posted: Fri Mar 16, 2018 6:50 pm Post subject: Re: Any threads about welding the rear frame back in? |
I have a complete donor bus that had a bad cabin fire. My plan is to clean up the site on the red bus by making the burned edges on each surface into an identical geometrical slice that I can transfer to the donor. Then I'll weld up a few braces to locate the graft into proper position on the red bus (distance from the jackpoint, floor, etc.) Next, I'll weld a sleeve into the frame rail on the red bus. Then, I'll lift it up, measure again and weld away. I'll try to snap a few pics.
She will rise again from the soil!! _________________ 1965 Pearl White Caravelle Camper
Busstom Samba Member
Joined: November 23, 2014 Posts: 3853 Location: San Jose, CA
Posted: Fri Mar 16, 2018 10:16 pm Post subject: Re: Any threads about welding the rear frame back in? |
Wow! You started with baked filo dough! Any updates on your thread? |
Posted: Sat Mar 17, 2018 3:50 am Post subject: Re: Any threads about welding the rear frame back in? |
Busstom wrote: |
Not much happened this winter. Ordered the funky green front floor and it is beautiful! That will go in soon and I will start sprucing up the front cab and putting all the pedals and what not back together. Have to drill out or repair all of the drop gate bolt holes on the body. That is another daunting task I have been putting off. _________________ BUSLUST IS NOW IN HIGH SPRINGS FLORIDA!
Dynamic Duo - William & Jenn =)
1975 VW Westfalia "Willow"
1970 VW Single Cab Truck "Woodstock"
[email protected] |
Posted: Sun Mar 18, 2018 1:59 am Post subject: Re: Any threads about welding the rear frame back in? |
Started here:
The first time it's been off of the ground in probably 18 years.
The donor
The jagged ends
Cut and sleeved
That's as far as we got today
Manfred58sc Samba Member
Posted: Sun Mar 18, 2018 9:18 am Post subject: Re: Any threads about welding the rear frame back in? |
Thanks for posting, some Bus's were sacrificed to build trikes back in the day no doubt. I have to same task ahead of me on a 69 Westy, not in a huge hurry to tackle that one. _________________ Fat chick owner/operator |
Posted: Sun Mar 18, 2018 11:52 am Post subject: Re: Any threads about welding the rear frame back in? |
bb-jake, aren't you going to sandblast that donor section before grafting? |
