Holey42001 Samba Member
Joined: January 13, 2017 Posts: 99 Location: Fresno, CA
Posted: Sun Feb 25, 2018 10:49 am Post subject: Re: Homemade Parts |
flat4olsen wrote: |
And carpets from IKEA
You’re inspiring me to do mine! Nicely done! _________________ Post...edit...post...edit....
If it’s not leaking oil, there probably isn’t any left.
1973 Standard Bug
1972 MG Midget
1973 Hilux w/flatbed & crate motor
1989 Aero & Adams FV |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Sun Feb 25, 2018 11:20 am Post subject: Re: Homemade Parts |
Disaster06 wrote: |
I like the garage door clicker! Mine is the old school kind on my sun visor and it won’t even open the door until I fold down the visor and give it a clear shot through the glass at about 20’ away 😬 hopefully batteries are just old. Otherwise if the metal body is blocking it I don’t think the glovebox would work for me haha |
I have a momentary switch underdash on my 1971 for the door opener, plugs into the remote which is in my trunk. It's visible in this photo, near the air box.
I also made a homemade metal panel to cover the hole I cut in the 1970s for access to #3 and #4 plugs, back when there was leaded gas and I had a DPD AC compressor blocking access. I accessed the plugs under the LR fender above the rear tire. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
74Shovel Samba Member
Joined: October 18, 2017 Posts: 165 Location: Yakima, WA
Posted: Sun Feb 25, 2018 4:24 pm Post subject: Re: Homemade Parts |
I made a replacement fuel vapor trap for my '78 Super Beetle to replace the one a previous owner had made. Here's the one from the previous owner:
And here's what I replaced it with:
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Mon Feb 26, 2018 3:10 pm Post subject: Re: Homemade Parts |
I made this throttle cable pivot to keep the cable from rubbing on tube (as it had in the past) and it really helped the smoothness of the feel of it.
gt1953 Samba Member
Posted: Mon Feb 26, 2018 3:38 pm Post subject: Re: Homemade Parts |
Clutch cable adjusting tool. Why purchase one.
https://vwparts.aircooled.net/Clutch-Adjusting-Wrench-Tool-EACH-p/clutch-adj-tool.htm _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
bobinphx Samba Member
Posted: Wed Feb 28, 2018 8:30 pm Post subject: Re: Homemade Parts |
Homemade? Well,,,, sort of.
I couldn’t keep my valves in adjustment more than a couple of hundred miles using adjusters from my local independent parts house. Inspection found that the adjusters were flatting out at the tips.
I gotten a bunch of used adjusters that I believe to be genuine old german vw adjusters in a parts deal. So I tried using them. Yea, they were worn pretty well, but they adjusted up fine. 500 or so miles, still adjusted perfectly.
Scratching my head a bit, I ran a file over the new valve adjuster tips and the file bit in fairly deep. I ran the same file over one of the "genuine" valve adjusters and the file skated across the tip like skating on an ice skating rink right after the Zamboni was done. My guess was that there was no heat treating on the new ones.
I read up on how to harden metal, watched a couple of YouTube videos and spoke to a buddy who does forge work. I figured what the heck. So I took one of the new crummy adjusters, heated the end to a bright cherry red and then quenched it in salt water. Did the file test again and the file skated across new adjuster with no resistance, just like the genuine article.
I put the new newly heat treated adjusters in about 500 miles ago and guess what? Nothing was out of adjustment. So my homemade heat treated valve adjusters appear to be working. More miles and more time will tell the full story. |
Posted: Sat Mar 03, 2018 7:15 am Post subject: Re: Homemade Parts |
Homemade warm air intake hole blockoff. Made with 1/8 inch thick aluminum plate and a scroll saw. Quick and easy.
Posted: Sat Mar 03, 2018 7:23 am Post subject: Re: Homemade Parts |
Fresh air intake cover. My air box was fully sun rotted, so it was removed. This let rain into the trunk. 1/8 inch aluminum, a scroll saw and a little thin rubber gasket under it. I bolted the plate through the vents into a second piece of aluminum inside the trunk. Its been about a year, so I really should take it off and re-polish it.
Cusser Samba Member
Posted: Sat Mar 03, 2018 8:13 am Post subject: Re: Homemade Parts |
bobinphx wrote: |
I just use a rubber stopper, can be seen in this picture. Yes - I did connect/repair the license plate wires seen loose in this photo...
hopkin Samba Member
Joined: June 25, 2012 Posts: 2480 Location: Ottawa, Ontario
Posted: Sat Mar 03, 2018 9:10 am Post subject: Re: Homemade Parts |
I forgot about this one on my last post, a cover for the luggage area. My car came with one that was badly damaged, so I used it for a template and cut a new one out of a piece of half inch plywood.
I covered it with some indoor/outdoor carpet. Later I cut out a recessed area in the center to store the spare light bulb/fuse kit (blue), as it was sliding around in the front of the car.
The 'VOLKSWAGEN' script is off of my very first car ('71 Super) that I bought way back in 1977. I removed it from the car before I scrapped sometime in the early '80s:
_________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (current)
2017 Dune Edition (daughter's car) |
AlmostHeavenWV_VW Samba Member
Posted: Mon Mar 12, 2018 4:11 am Post subject: Re: Homemade Parts |
Found a pic of my homemade heat tube under the rear seat that goes from the bakelite tube to the heater channel snout
Two fernco reducing couplings from the hardware store and a length of preheat hose from the FLAPS. Seals well and gets the heat where it needs to be.
Costs about $20 to do both sides _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
Posted: Mon Mar 12, 2018 6:02 pm Post subject: Re: Homemade Parts |
Ok not really a homemade part but I put 60lbs of bench press weights in the front to make the ride a little softer on these Fresno, CA roads (thanks to the man in Sacramento, what a joke ). Anyways, there’s one of those swamp cooler hay filters on the bottom and two rags on the sides to keep them from sliding back and forth.
1973 Standard Bug
1972 MG Midget
flat4olsen Samba Member
Joined: February 20, 2014 Posts: 342 Location: Denmark, Europe
Posted: Tue Mar 13, 2018 3:14 am Post subject: Re: Homemade Parts |
Homemade "Jet Doctors". Made from a piece of brake line epoxied in place. Haven´t had a plugged idle jet since.
_________________ Type 1 1968, Lotosweiss. 2109 oxyboxer engine
Early Bay 1970, Montana Red. Under construction |
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2388 Location: Seekonk,Massachusetts USA
Posted: Tue Mar 13, 2018 8:24 am Post subject: Re: Homemade Parts |
The throttle linkage is from Swedish Logmech: http://logmech.se/eng/products/carburator/throttlecontrol-cable-kits/
Very nice product, and easy to syncronize.
Thanks,- the bottom air cleaner setup is sold to a gentleman from USA by the way _________________ Type 1 1968, Lotosweiss. 2109 oxyboxer engine
Posted: Tue Mar 13, 2018 10:40 pm Post subject: Re: Homemade Parts |
Two reasons: cold air is denser than hot air, thus containing more oxygen and therefore extracting more power from the engine.
And,- it´s a summer car, so I chosed 1 5/8” J-tubes over heat exchangers. Again, to enhance performance. _________________ Type 1 1968, Lotosweiss. 2109 oxyboxer engine
plotch Samba Member
Joined: December 22, 2004 Posts: 540 Location: jeffersonville, vermont
Posted: Wed Mar 14, 2018 5:08 pm Post subject: Re: Homemade Parts |
Fresh air pick-up rerouted to the interior, to pick-up warm air. A
little wood a little PVC. And a bracket for the Rabbit windshield washer bottle. |
Posted: Wed Mar 14, 2018 7:09 pm Post subject: Re: Homemade Parts |
flat4olsen wrote: |
And,- it´s a summer car, so I chosed 1 5/8” J-tubes over heat exchangers. Again, to enhance performance. |
Ok,Thanks. _________________ Parts for sale https://www.thesamba.com/vw/classifieds/search.php?username=APPLEGREENVW
02/76 Beetle sedan |
Posted: Wed Mar 14, 2018 8:23 pm Post subject: Re: Homemade Parts |
plotch wrote: |
I’m a little confused hahah. So it picks up air from the passenger side foot well and routes it through the dash vents? Looks like the fresh air intake is taped off is why I’m asking. If this is the case, how does the air get pushed through the dash from the foot well? _________________ Post...edit...post...edit....
1973 Standard Bug
1972 MG Midget
