pinetreeporsche Samba Member
Joined: June 11, 2009 Posts: 752 Location: Falls Church, VA
Posted: Sat Feb 24, 2018 5:06 pm Post subject: I need tips on dent removal w/heat gun and compressed air spray |
I've seen a few videos on youtube showing some success and some failures in fixing or at least making progress on body dents. And yes, I know those right at a body crease, or dents that actually crease the metal are not gonna way. And I do get it that lots of focused heat all over the dented area, and then a good chiller spray is most important. Is a hair drier an adequate heat supply? What chiller did you use- freon (as from a medical supply place) or just compressed air? Where'd you get it- a home depot or?? Have you mixed Any fine tips for a beginner? |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Pinetops Samba Member
Posted: Sat Feb 24, 2018 7:18 pm Post subject: Re: I need tips on dent removal w/heat gun and compressed air spray |
It's very unlikely to work unless you have just the right kind of dent. _________________ "A rolling bus gathers no rust." |
Tobias Duncan Samba Member
Joined: January 15, 2013 Posts: 1391 Location: Taos NM
Posted: Sat Feb 24, 2018 9:43 pm Post subject: Re: I need tips on dent removal w/heat gun and compressed air spray |
The steel is so much thicker on a vanagon than a modern car , I doubt the same techniques would work |
Posted: Sat Feb 24, 2018 10:14 pm Post subject: Re: I need tips on dent removal w/heat gun and compressed air spray |
^^^ Truth...I had thought about that, too.
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Sat Feb 24, 2018 11:57 pm Post subject: Re: I need tips on dent removal w/heat gun and compressed air spray |
I have found the paintless dent removal guys worth their weight in gold. By the time you get supplies and such, you might be 1/3 of the way to spending what it takes for a pro to make it literally disappear. Find a couple, send them a few pictures and see what they'd charge before trying it yourself. Your efforts might change the metal enough that then they cannot help you.
Doug _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
