Type 4 Motor in My THING
73Nick
73Nick is offline
PostPosted: Sun Feb 25, 2018 7:56 pm    Post subject: Type 4 Motor in My THING Reply with quote
So I bought a THING 6 months ago.
I did some research and found out the motor that is in it is a Type 4 flat that out of a 72 Transporter.
The question I have is, will the THING stock transmission hold up to this motor? When I drive it, it seems the trans is slipping. From 2nd to 4th. Once u shift and get in to the gas the car had no pull, just high rpm's.
CraigInPA
CraigInPA is offline
PostPosted: Mon Feb 26, 2018 6:54 am    Post subject: Re: Type 4 Motor in My THING Reply with quote
Sounds like you need a new clutch...
73Nick
73Nick is offline
PostPosted: Mon Feb 26, 2018 6:07 pm    Post subject: Re: Type 4 Motor in My THING Reply with quote
That's what I was think, just needed some reassurance.
Is it possible that when the engine swap was done that the clutch for the Type 1 1600 could have been installed on the Type 4 engine? Or would it not even bolt up.
Wildthings
Wildthings is offline
PostPosted: Wed Feb 28, 2018 10:32 am    Post subject: Re: Type 4 Motor in My THING Reply with quote
Have you checked your clutch adjustment?
Not at all sure of the clutch options, you may has either a 210 or 215 clutch, I would think either would work fine with the right throwout bearing and guide. Don't think you could have the larger 228mm clutch as the engine and tranny probably would not have mated and the Thing starter would not have worked if they did.
RWK
RWK is offline
PostPosted: Thu Mar 01, 2018 6:08 pm    Post subject: Re: Type 4 Motor in My THING Reply with quote
I had a T4 in my baja, 30 years ago, but had a KEP converted T1 flywheel/clutch, didn't think T4 flywheel/clutch would work? but yes clutch slippage.
73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530
RWK
RWK is offline
PostPosted: Thu Mar 01, 2018 6:39 pm    Post subject: Re: Type 4 Motor in My THING Reply with quote
Never mind my last reply, I had an auto stick motor, so went with a T1 flywheel vs. T4 it was cheaper and T1s are forged vs. cast I was told.
73 Type 181
63 Type 113
73Nick
73Nick is offline
PostPosted: Fri Mar 09, 2018 7:19 pm    Post subject: Re: Type 4 Motor in My THING Reply with quote
You where correct sir. The clutch had no freeplay. Readjusted clutch cable and problem solved.
