ADIDAS Samba Member
Joined: October 11, 2004 Posts: 30 Location: Belmont NC
Posted: Mon Feb 26, 2018 12:16 pm Post subject: What fuel injection system is used on a 1973 vw 412 station wago |
Does anyone know which fuel injection system was used on a 1973 412L station wagon. Pretty sure the engine is a 1.7 Does it have the D-jetronic or L jetronic? Thanks |
412STi Samba Member
Joined: September 25, 2015 Posts: 23 Location: Germany
Posted: Mon Feb 26, 2018 2:13 pm Post subject: Re: What fuel injection system is used on a 1973 vw 412 station wago |
Hi
Our type 4 was equipped only with the D-Jetronic. _________________ Gerold
The morning brings a mystery, the evening makes it history
The oil can not be, was none in it. |
KTPhil Samba Member
Posted: Mon Feb 26, 2018 2:21 pm Post subject: Re: What fuel injection system is used on a 1973 vw 412 station wago |
Would that make it a 412LE, not a 412L? Or were models not always perfectly synced with the badges? |
raygreenwood Samba Member
Posted: Mon Feb 26, 2018 4:18 pm Post subject: Re: What fuel injection system is used on a 1973 vw 412 station wago |
KTPhil wrote: |
The badges were a little different on 411 and 412. I have to look in the book but there were "L" models and non L- models through the range.
From memory the L was for automatic and the E was for injection...though we never saw the L or the E or the LE here in the US because except for gray market they were all auto with fuel injection....so they were all LE's.
Don't quote me on that...I am far from my books.
But....if it was a 412 of any type in the 1973 model year...it had D-jet injection in the US. The 412 did not get L-jet injection until the 1975 model year. There were even a few more that continued for a month or two into the 1974 model year with D-jet.
My 2 door 412 confuses some.....because...and again...dang...going off memory here...I "think"...mine is a November 1973....but its a Euro tourist vehicle import with four speed....steel bumpers and D-jet.
also....if it has a 1.7L engine...it has D-jet. The L-jet only came on the 1.8L Ray |
KTPhil Samba Member
Posted: Mon Feb 26, 2018 5:30 pm Post subject: Re: What fuel injection system is used on a 1973 vw 412 station wago |
Type 3 and 4 badging may not have been identical, but for the Type 3:
L Luxus (luxury, as in clock and carpeting!)
T Touring (Fastback)
E Einspritzer (German for injection)
So for my '71 US-destined (deluxe) fastback, the European scripting would have been VW1600TLE, but in the US, it just got VOLKSWAGEN. I have seen actual cars with this script, and I now have it on my US model, decked out with side parking lamps (tied to turn signals and 4-ways), halogen headlights, and amber rear turn signals (still MPH speedo, though).
Again, I haven't found any claim the Type 4 script suffixes were identical, but by then VW had standardized a lot of things like this... |
Posted: Mon Feb 26, 2018 8:45 pm Post subject: Re: What fuel injection system is used on a 1973 vw 412 station wago |
KTPhil wrote: |
The problem is that VW had more type 4 "packages" than we have letter identifiers.
I have never seen a "T" type 4...but its possible. In Europe and Australia teh badging was different also.
They had LE and LS in Europe...I think LE was 1800 twin carbs and LS 412 with injection.
I will have to wait until I get home to check books. Ray |
Type4ever Samba Member
Joined: November 08, 2011 Posts: 47 Location: Veghel the Netherlands
Posted: Tue Feb 27, 2018 12:30 pm Post subject: Re: What fuel injection system is used on a 1973 vw 412 station wago |
Ray, in Europe LE means Luxury Einspritzung (Injection). Also possible with only E. In 74 we have 4 different 412's. 412, 412L, 412S and 412 LS. The first two with carburators 75 BHP. The last two (with S) 85 BHP. With L means also here Luxury-version. |
937carrera Samba Member
Posted: Tue Feb 27, 2018 3:08 pm Post subject: Re: What fuel injection system is used on a 1973 vw 412 station wago |
KTPhil is right on the type 3 designations, but they were not universal as there was not only the 1600 TL model, but according to my '72 MY brochure the 1600A was carbs while 1600E was the injection version
Type 4 was very similar, for the '72 model year in the UK there was only the 411LE, though on other European markets there was a lower spec 411E.
For the final model year in the UK there was the increase in engine size and designation change to 412LS.
In Germany however the final model year had 4 models:
412
412L
412S
412LS
the L designating the trim and the S designating the engine output, 75HP for the standard and 85HP for the S as type4ever posted above.
I didn't know about the lower output engine until I read the brochure just now The compression ratio was lower at 7.8:1 rather than 8.6:1
That doesn't really answer the OP question though and the question is about US spec cars. According to type4.org the switch to L-Jetronic was made at the same time the European cars moved back to carbs
Best way to tell might be a picture of the engine bay and there's a b/w one here https://www.type4.org/manuals/ljet/components/ljet10.html#location-of-components[/url
A 1973 model year will be D-Jet, late 73 build /74 model year would be L-Jet
Hope that helps _________________ 1974 412LS Variant 1.8 AN engine on twin carbs
1973 412LE 4 door Fastback / Saloon 1.7 EA engine on D-Jet |
Posted: Wed Feb 28, 2018 9:13 am Post subject: Re: What fuel injection system is used on a 1973 vw 412 station wago |
937carrera wrote: |
412
412L
412S
412LS
Hope that helps |
Thank you for the info!
The type 4 line has always driven me crazy as designations, part numbering, standard equipment lists..etc....were widely varied over the range of markets.....and no two dealer parts books, fiche's or lists I have ever found....seem to have it all. Ray |
