lostinavan Samba Member
Joined: November 10, 2016 Posts: 31 Location: Southern Oregon
Posted: Mon Feb 26, 2018 5:16 pm Post subject: What's this thing I just broke? |
Pulled the van out of its cave today, went to start it ..nothin. Charged the battery, then tried jumping, still nothing. Moving down the list, I tapped the starter a little, then noticed a semi-corroded cable connection associated with the starter that I hadn't seen previously. Worth a shot to clean it yeah?
Bad move, perhaps. When I finally got a socket on this thing and gave it some love, the whole thing cracked up and, semi hilariously, caused the starter to finally fire up and roll the van about ten feet (forward, thank god) before i got it in neutral. The starter continued going off until I d/qd the battery (yes I know).
The thing is conveniently located under the coolant line passage to the right of the starter. It's an 84 Vanagon btw, 1.9 water boxer. There are three cables that connect to it, one from the front of the vehicle and two that head to the starter.
Stupid question perhaps, but I can't find this thing in the Bentley, what is it?
Follow up: do you have one you'd like to sell, or is it even necessary?
Bomus question, would anyone like to speculate on whether the thing's desire to break could be related to the original problem? |
Zeitgeist 13 Samba Member
Posted: Mon Feb 26, 2018 5:18 pm Post subject: Re: What's this thing I just broke? |
That's an aftermarket starter solenoid, and yes it's more than likely related to your starting issues. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4800 Location: Bemidji, MN
Posted: Mon Feb 26, 2018 5:20 pm Post subject: Re: What's this thing I just broke? |
it's a "Ford" starter solenoid someone installed to try to cure the Vanagon "no crank" syndrome due to a voltage drop to the OEM solenoid.
you can get a new one for about $8 if you want to keep the entire system the same and not mod anything that the PO did.
-dan |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10252 Location: N. Idaho
Posted: Mon Feb 26, 2018 5:23 pm Post subject: Re: What's this thing I just broke? |
Agree - replace it. That's not a bad idea, actually. While you're messing with it and starter wiring, I think this is the perfect time to toss a hidden switch in the wiring so you can prevent its theft. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Mon Feb 26, 2018 6:38 pm Post subject: Re: What's this thing I just broke? |
Thank you guys. Good info.
So breaking the aftermarket solenoid essentially shorted out the switch, causing the starter to go. And the oem solenoid is essentially defunct.
Options seem to be a)replace with another 'fordanoid' b) find an oem solenoid and try to make it work or perhaps c) replace the whole starter with a fancy new gear reduction one from GW that hopefully solves the whole deal?
Paulbeard Samba Member
Posted: Mon Feb 26, 2018 6:44 pm Post subject: Re: What's this thing I just broke? |
lostinavan wrote: |
Options seem to be a)replace with another 'fordanoid' b) find an oem solenoid or perhaps c) replace the whole starter with a fancy new gear reduction one from GW that -maybe- doesn't require a solenoid? Let me know if I'm wrong, thanks again |
d. Get a Bosch TDI starter and the adapter from Karl @ Westyventures… _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
Posted: Mon Feb 26, 2018 6:55 pm Post subject: Re: What's this thing I just broke? |
Looks like westyventures doesn't sell starters any more, and the kit is $75 - any particular reason the tdi starter is better than the one offered by gw? |
Red Beard Samba Member
Joined: May 09, 2006 Posts: 463 Location: Seattle, WA
Posted: Mon Feb 26, 2018 7:00 pm Post subject: Re: What's this thing I just broke? |
Also, disconnect the battery before you work on the starter next time. _________________ 1990 Vanagon, FAS Gen V 2.0 NA, AT w/ Peloquin diff, NAHT conversion |
Posted: Mon Feb 26, 2018 7:27 pm Post subject: Re: What's this thing I just broke? |
lostinavan wrote: |
Lots of threads on that.
Not sure Karl ever sold starters, but his adapter is the thing. Buy the starter anywhere that has it. You can find it at any FLAPS, unlike the GW one. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
— dhaavers |
markswagen Samba Member
Joined: January 28, 2018 Posts: 1039 Location: san diego
Posted: Tue Feb 27, 2018 8:04 am Post subject: Re: What's this thing I just broke? |
The starter adapter allows you the option that, if it were to go bad, you can go to your local flaps and pick one up.
Also the Bosch starter is a MUCH better option,I have had to replace several of those high torque starters, and I will not fit another, you do not have to modify it out of the box, to make it work.
lostinavan wrote: |
_________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
Posted: Tue Feb 27, 2018 8:08 am Post subject: Re: What's this thing I just broke? |
Also while you are at it, fit a new hard start relay, from thatvwbusguy, his stuff is about the best out there, can't you find a link to it right now. _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16508 Location: Brookeville, MD
Abscate Samba Member
Joined: October 05, 2014 Posts: 22671 Location: NYC/Upstate/ROW
Posted: Tue Feb 27, 2018 8:54 am Post subject: Re: What's this thing I just broke? |
A poster child thread for why adding crappy parts to solve other faulty parts is bad practice.
If your starter won’t hit start , fix the starter and /or wiring , don’t add more wiring and connections to go wrong _________________ .ssS! |
Posted: Tue Feb 27, 2018 10:57 am Post subject: Re: What's this thing I just broke? |
Cool, thanks again everyone.
Going to go with the adapter and tdi starter
Would that be a likely fix for the 'no crank' that led to the am solenoid being installed (and later led to me breaking it) Or would it be highly advisable to also do the hard start relay? |
Vanagon Nut Samba Member
Posted: Tue Feb 27, 2018 11:55 am Post subject: Re: What's this thing I just broke? |
lostinavan wrote: |
IMO, the short answers are "yes" and "no".
Its my understanding that a gear reduction starter typically requires less Amps to make it turn (it's certainly more mechanically efficient than the old style Bosch starter.) so its' solenoid probably requires less Amps? At the very least there'd be more Amps available to actuate the solenoid. So, if corrosion in wires to starter were part of the original issue, (it inhibits current flow), a new gear reduction starter would most likely not be affected as much by that.
For POV, various used old Bosch starters I used on my '81 with Jetta engine suffered from slow cranking. The last one would intermittently fail to even "click". Then, I installed a Mullendor plate and off shore gear reduction starter. Since then, I've had zero issues with solenoid and cranking. That said, and this would happen with any starter, driving the van only short distances tends to leave the starter battery a little undercharged; the starter does turn a little slower in that case but still works fine. Were it the old starter, I'd think it would turn quite slowly in that case.
I'm curious what happened to the aftermarket solenoid. Was it a used part when installed? Did time and road salt kill it? It sure looks gnarly. It also makes me wonder if a "continuous duty" rated solenoid would generally be a better quality part than that used for this application.
1988 West DIY 50º ABA
VE7TBN |
calfredson Samba Member
Joined: January 21, 2015 Posts: 70 Location: Vancouver, BC
Posted: Tue Feb 27, 2018 12:10 pm Post subject: Re: What's this thing I just broke? |
The hard start relay is inexpensive and easy to install, particularly if you are doing the starter anyway. In addition to giving more amps to the starter, it also protects your ignition switch, so I would say there's no reason not to do it. |
Dampcamper Samba Member
Joined: October 07, 2013 Posts: 788 Location: Rainy Portland, Oregon
Posted: Tue Feb 27, 2018 12:17 pm Post subject: Re: What's this thing I just broke? |
Photo of solenoid doesn't show much corrosion, the bakelite housing broke at the point where the lugs go through. If the heavy wires were pulled tight or hanging a lot of weight on those lugs that would strain it. Bakelite doesn't exactly have tensile strength. |
Posted: Tue Feb 27, 2018 12:40 pm Post subject: Re: What's this thing I just broke? |
It wasn't broken until I wrenched on it. The nut for the cable connector was/is seized, so the whole Bakelite broke in half. Good times. Hopefully though, that flukish occurance will lead to the permanent solution of all starting issues with this van, ha ha |
Posted: Tue Feb 27, 2018 1:06 pm Post subject: Re: What's this thing I just broke? |
lostinavan wrote: |
Dampcamper, lostinavan, ok. Thanks. Curious more than anything. Looking at the image, I'd assumed housing was corroded steel.
VE7TBN |
