GLHTurbo Samba Member
Joined: March 30, 2009 Posts: 1376 Location: New Jersey
Posted: Mon Feb 26, 2018 5:59 pm Post subject: Any Nissan Techs out there? |
I have an 05 Sentra with a perpetual P1138 Swirl Control error code. Any Nissan tech's out there by any chance? Curious if there's an easy fix other than replacing the lower intake manifold?
Thanks! _________________ 1957 Beetle
1966 Bus |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51144 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Feb 26, 2018 6:29 pm Post subject: Re: Any Nissan Techs out there? |
I'm not familiar with the later ones like yours, but the early ones suffer from a petrified or ruptured diaphragm in the dashpot, I'm guessing yours has a lift sensor on it?
Maybe it's binding and some intake cleaner will free it up?, or is the solenoid valve shorted internally?, or broken?
The factory service manuals for those are very well done and worth the money (used on Ebay), most dedicate a few full pages to diagnosis and repair of a system such as that. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Feb 26, 2018 6:54 pm Post subject: Re: Any Nissan Techs out there? |
It has a position sensor of sorts on the passenger side of the "butterfly" rod, and a servo (or solenoid?) on the driver side to open and close the "butterflies". When disconnecting the linkage to the servo/solenoid it, the "butterflies" moves freely.
The bummer is, Nissan doesn't sell just the sensors on their own, you have to purchase an entire intake manifold $$! For now, I tried spraying some electronics cleaner in the servo, and was able to fiddle with the plugs as well. No luck.
The bummer is, it does nothing to affect the driveablility, in fact the system is only used briefly when the engine is cold I believe. It's preventing the car from passing inspection currently due to the OBD code. _________________ 1957 Beetle
1966 Bus |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Wed Feb 28, 2018 1:31 pm Post subject: Re: Any Nissan Techs out there? |
GLHTurbo wrote: |
The bummer is, it does nothing to affect the driveablility, in fact the system is only used briefly when the engine is cold I believe. It's preventing the car from passing inspection currently due to the OBD code. |
Can you find a used one in a local junk pile or off of ebay? I have had a lot of luck purchasing parts for an old Jeep Cherokee one of the kids drives, off of Ebay. May be worth a quick search. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
