smitty1976bus Samba Member
Joined: January 21, 2013 Posts: 369 Location: Cape Cod
Posted: Mon Feb 26, 2018 7:22 pm Post subject: Alternator Giving Very High Volts |
Hi all,
I have a 78' Westy with a 70 amp alternator, been having charging issues for a few months now, and just thought it was my VR on its way out. So I bought a spare one to keep in my bus for when I'd need it. One day, my ALT. light comes on, so I swap over the new VR. Start the bus up, and boom, over 16 volts!
Great.... I ended up buying another VR.. same problem, super high volts. Ok.. now I'm thinking my alternator bit the dust. I tested the Alt -> VR connectors first, using RatWells handy chart:
I got as far as measuring the D+ terminal, with the ignition on, but engine off. The volts were at 11.6. So straight from the battery. So thinking one of the diodes blew in the alternator, and caused it to push out max volts all the time. Bought a rebuilt unit off of BusDepot:
Old
New
Went through the painstaking task of putting it in, and just fired up the engine.... Super high volts still! Has anyone seen this issue before? Is there a ground I'm missing or something?? Any help is appreciated. |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22727 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Mon Feb 26, 2018 7:51 pm Post subject: Re: Alternator Giving Very High Volts |
Ever think the gauge might be the problem? Double check it with a VOM _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Mon Feb 26, 2018 8:02 pm Post subject: Re: Alternator Giving Very High Volts |
Tram wrote: |
Ever think the gauge might be the problem? Double check it with a VOM |
Yup. Getting approx 16.97 volts, measured at the battery. |
Posted: Mon Feb 26, 2018 8:12 pm Post subject: Re: Alternator Giving Very High Volts |
smitty1976bus wrote: |
Tram wrote: |
See if there's an open wire between the alternator and regulator. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Tue Feb 27, 2018 9:20 am Post subject: Re: Alternator Giving Very High Volts |
Also check transaxle ground strap; alternator/regulator needs to see battery ground; if there is a poor ground, it will not see battery voltage properly and will overcharge as a result.
Quick easy way to check this on a Bus would be to use a jumper to connect alternator housing to battery negative while engine is running and see what happens at the voltmeter. If it drops down to ~14v then you have a ground issue; if it stays high then the issue lies elsewhere. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
timvw7476 Samba Member
Posted: Tue Feb 27, 2018 12:58 pm Post subject: Re: Alternator Giving Very High Volts |
DO NOT TRUST that black plastic block that plugs most of your alternator
wires into your voltage regulator, make sure to 'seat' every copper prong
in it's proper place. Those blocks have been known to seat while letting
one connection run loose. Also, if a diode fails, you lose volts, never gain,
if I understand & recall rectification schematics properly. |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2743 Location: Hamble, Hampshire, UK
Posted: Tue Feb 27, 2018 2:06 pm Post subject: Re: Alternator Giving Very High Volts |
A battery charging at 17 volts is pretty well dead too.
The 11.7 volts with ignition on is another sign.
Unless there is a loose terminal clamp or earth straps.
I once left a battery clamp loose amd the bus ran OK for 14 miles then the warning light came on and the voltage measured at the alternator output went to about 18 volts.
Retightened the clamp by hand and pushd it down on the battery and the voltage went back to normal when I started it again. _________________ Ancient vehicles and vessels
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Tue Feb 27, 2018 5:59 pm Post subject: Re: Alternator Giving Very High Volts |
If you're getting 17 volts, it's because the alternator is running wide open, unregulated. Unplug the regulator and retry. There should be no output at all. If there is, then there is either a short in the alternator harness, or there is a failure inside the alternator. If the output falls to zero, then it's likely a regulator issue.
Side notes: never run an alternator without a battery load connected (make sure the battery has water above the plates). Otherwise, the alternator output voltage can rise high enough to cook the alternator diodes. If you must test, turn the headlight on to load down the alternator as much as possible. High voltages are really hard on the FI controller, and other bus electronics. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Tue Feb 27, 2018 6:10 pm Post subject: Re: Alternator Giving Very High Volts |
Thanks for the replies everyone, I'm working on it right now.. hopefully solving it soon, ha
sjbartnik wrote: |
Also check transaxle ground strap; alternator/regulator needs to see battery ground; if there is a poor ground, it will not see battery voltage properly and will overcharge as a result. |
All ground straps are good and tight. They're all new (under a year old) too, because bad grounds seems to be the culprit for every issue on this bus, haha.
mikedjames wrote: |
Unless there is a loose terminal clamp or earth straps. |
I traced the the 11.7-12 volts from the D+ terminal to the blue wire, whihc I beleive comes from the warning light, on the dash. No idea why that would put out 12v when the engine isn't running..... I unplugged it, hoping it would resolve the issue, but still getting high charging volts....
telford dorr wrote: |
If you must test, turn the headlight on to load down the alternator as much as possible. High voltages are really hard on the FI controller, and other bus electronics. |
Tried running without the VR attached, gave me no charge at all, so thats a good sign.. I guess, ha. When I do test, I turn the engine on, but no longer than 5 seconds at a time. The one time I did, when it first happened, I had to drive home, about 5 miles, and I had every electronic in the bus on (headlights, fans, wipers, radio, etc) just to spread out the volts. that trip was tense.
Still troubleshoot all the suggestions, will post back soon, hopefully with good news. |
Posted: Tue Feb 27, 2018 6:42 pm Post subject: Re: Alternator Giving Very High Volts |
Here's a general schematic for what you're working on:
To prove that the problem is the regulator and not the alternator:
1 - disconnect the regulator.
2 - at the regulator connector, jumper the red wire to the green wire. Leave the brown wire disconnected. Run the engine. There should be no alternator output.
3 - at the regulator connector, jumper the brown wire to ground. Leave the green wire and red wire disconnected. Run the engine. There should be no alternator output.
If either tests fail (e.g. the alternator runs wide open), then the problem is either a shorted harness or a short inside the alternator. If both test pass, the problem is the regulator.
This is based on the assumption that your voltmeter is reading accurately. To check, measure a different car and see if it reads as expected.
How it works (in case anybody is interested):
An alternator is like the power amplifier on your stereo. The output current from the B+ terminal into the battery is approximately equal to the current flowing between alternator terminals D+ and Df (the rotor current) times the engine speed times the alternator gain constant (a fixed number). This current causes the battery voltage to rise. When this voltage reaches between 13.8 to 14.4 volts (the setpoint), the regulator turns off the rotor current, which causes the alternator output current to fall. The battery voltage falls below the setpoint, the regulator restores the rotor current. This cycle repeats hundreds of times a second, resulting in a constant battery voltage. The battery is what converts the charging current to a voltage, and is why an alternator won't work properly without a battery. (Note: a really big capacitor, like 50,000uf or so, will work in place of the battery, but it's not likely one would have one of these handy...) _________________ '71 panel, now with FI
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Tue Feb 27, 2018 8:08 pm Post subject: Re: Alternator Giving Very High Volts |
at minimum that battery should have 12.2 "at rest" in my opinion....you're battery sounds weak. ideally a healthy one would be 12.6
that said. we use to do the 15-15 test.....put the battery on a 30amp charge for 15 minutes. if the battery hit 15v, it was junk. sometimes you could monitor it for just a few minutes and watch the voltage climb to 20v
just because a battery seems to "work" doesn't mean it's good. swap a known good battery and see if that does anything for you _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Tue Feb 27, 2018 8:16 pm Post subject: Re: Alternator Giving Very High Volts |
Great schematic and explanation telford dorr, thank you!
I did the test you recomended
2 - at the regulator connector, jumper the red wire to the green wire. Leave the brown wire disconnected. Run the engine. There should be no alternator output. |
Welp, that's as far as I got.. there was an output.. the same very high output I've been getting. Great. I'm hoping it's what a few other people have mentioned:
Tram wrote: |
See if there's an open wire between the alternator and regulator. |
timvw7476 wrote: |
DO NOT TRUST that black plastic block that plugs most of your alternator wires into your voltage regulator, make sure to 'seat' every copper prong in it's proper place. Those blocks have been known to seat while letting one connection run loose. |
It has to be the wiring harness, which connects the VR and Alt... I mean, I have 2 alternators, my old one and a freshly rebuilt one. I have 2 voltage regulators, my old one and a brand new one. And after interchanging them all, i keep getting the same results, super high voltage... The only other constant is the harness... and the battery. So it has to be the harness.... right???
Right?!?!
Ha, I hope so. I'm tapping out for tonight, tomorrow I'll probably pull the harness out and try and re-wire it. I see BusDepot offers a new harness, but for $90, and I don't want to spend that much on some wire.. Even though I'll probably end up buying it anyways.
Thanks for the help everyone.. Sooner or later I'll figure this out. |
Posted: Wed Feb 28, 2018 12:26 am Post subject: Re: Alternator Giving Very High Volts |
Quote: |
Great schematic and explanation telford dorr, thank you! |
No problem.
Quote: |
I did the test you recommended [red to green, brown disconnected].
It has to be the wiring harness, which connects the VR and Alt... I mean, I have 2 alternators, my old one and a freshly rebuilt one. I have 2 voltage regulators, my old one and a brand new one. And after interchanging them all, i keep getting the same results, super high voltage... The only other constant is the harness... and the battery. So it has to be the harness.... right??? |
Good chance. Look for a short from the brown wire to ground. Do a sanity check and make sure the wires are on the correct alternator terminals, not swapped somehow (stuff happens...)
Quote: |
I'm tapping out for tonight, tomorrow I'll probably pull the harness out and try and re-wire it. I see BusDepot offers a new harness, but for $90, and I don't want to spend that much on some wire.. Even though I'll probably end up buying it anyways.. |
Pull the old harness, strip off the sheath, find the short, and repair as needed. Shouldn't be too hard. The trick is to figure out WHY it shorted, and make sure it doesn't happen again. _________________ '71 panel, now with FI
Posted: Wed Feb 28, 2018 8:50 pm Post subject: Re: Alternator Giving Very High Volts |
Pull the old harness, strip off the sheath, find the short, and repair as needed. Shouldn't be too hard. The trick is to figure out WHY it shorted, and make sure it doesn't happen again. |
Pulled the harness out, and wow, it has hardened into the shape it's been for the past 40 years, ha.
The wires were very hard, well the casing was. I examined the harness, looking for anything. Found some wear in one are:
The casing was split, but the wires looked ok. I then noticed the connector, to the alternator, had a pin out of place (the bottom pin was pushed down into the rubber boot). It looks like it was plugged into the alternator off center, and had a bad connection:
Not sure if that could be the problem... I took the harness and did a ohm test on it, to make sure the wires are good. They all passed but the brown wire; it wasnt' making an open connection, I was getting 5-6 ohms on it (not sure if I'm wording this right, not 100% what an ohm is, ha, just that it is the measurement of resistance)... looked like the wire was cracked up on the VR connection end:
So I'm hoping these small issues add up to my big problem. Now I need to fix it. I'll try to rig a harness with all new wires and connectors, and see how that goes. If that's too hard, I'll just buy a new one
I'm really hoping this is the problem. |
Posted: Wed Feb 28, 2018 9:10 pm Post subject: Re: Alternator Giving Very High Volts |
That brown (ground) wire looks like it's hanging on by a thread. I would think that could be your problem all by itself. _________________ 1965 Volkswagen 1500 Variant S
Posted: Wed Feb 28, 2018 9:28 pm Post subject: Re: Alternator Giving Very High Volts |
Final tests:
- measure the resistance of all wires, end-to-end. The resistance should be zero (same as meter probes shorted together).
- measure the resistance between all wires. The resistance should be infinite (e.g. open circuit).
From your symptoms, there is a short from the brown wire to ground somewhere. We're assuming it's in the harness (the most likely location).
As a sanity check, measure the resistance from the alternator Df and D- terminals to ground (the alternator case). It should be infinite (no connection). _________________ '71 panel, now with FI
Chochobeef Samba Member
Joined: May 01, 2013 Posts: 811 Location: Ft. Worth, Texas
Posted: Thu Mar 01, 2018 7:21 am Post subject: Re: Alternator Giving Very High Volts |
With as short as those wires are, I would just make my own new harness. New connectors with soldered ends. Then get some new sheathing and some new plug ends and call it good. Just match the wire gauge as best you can, and always go bigger if you can't find an exact size match. |
Posted: Thu Mar 01, 2018 8:32 pm Post subject: Re: Alternator Giving Very High Volts |
There just isn't enough hours in the day.. Tackled as much as I could this evening.
Final tests:
1 out of the 3 wires gave me a true zero resistance. 1 was a little off. 1 was way off (the brown wire)
This test came back good. surprisingly. So none of the wires were touching each other.
Chochobeef wrote: |
With as short as those wires are, I would just make my own new harness. |
Yup, a new harness is what I need. Making one seemed a little taunting at first, but once I realized that BusDepot doesn't offer a harness with the 70 amp alternator connectors, I decided it needed to be done. My plan was to take the existing connectors, take the old wire out of them, and put new wires in. Which means I had to cut it up.
I super glued, rubber cemented, and heat shrunk it all back together. The connectors are tightly in there, so hopefully they line up, and stay still, when I plug it into the alternator; which they should. I then connected the other end of the harness to the VR connector, wrapped it up in heat shrink and tape, put the guard around it, and prest-o! A new harness. I tested the resistance, and they're all good. Zero resistance, and no crossed wires. Should do the trick!
As for the alternator to the battery, just going to use a heavy gauge wire and run it through the grommet. So, if this was the problem i was having, this should solve it... Hopefully. But I'll have to test it another night, it's late, a Nor'Easters blowing in, and I blew a brake line in my other car, ha. No rest for the wicked. |
Posted: Fri Mar 02, 2018 9:17 am Post subject: Re: Alternator Giving Very High Volts |
New harness looks nice.
Quote: |
Quote: |
Final tests:
- measure the resistance of all wires, end-to-end. The resistance should be zero (same as meter probes shorted together). |
1 out of the 3 wires gave me a true zero resistance. 1 was a little off. 1 was way off (the brown wire) |
Resistance in the rotor (Df, D-) wires will limit the alternator output, not increase it. The critical wire is the red wire, as it supplies the reference voltage to the regulator. It needs to be as near to zero ohms as possible.
Quote: |
Quote: |
- measure the resistance between all wires. The resistance should be infinite (e.g. open circuit). |
This test came back good. surprisingly. So none of the wires were touching each other. |
If that's the case, then the problem hasn't been found yet! Did you measure the resistance from the alternator Df (green) and D- (brown) terminals to ground? Both should be infinite. A short here will override the regulators ability to control the alternator. _________________ '71 panel, now with FI
Posted: Fri Mar 02, 2018 9:27 am Post subject: Re: Alternator Giving Very High Volts |
I still suspect this was the issue.
(the main issue anyway, that harness had a lot of issues! ) _________________ 1965 Volkswagen 1500 Variant S
