66 dormi Samba Member
Joined: September 06, 2006 Posts: 607 Location: Ontario Canada
Posted: Tue Feb 27, 2018 4:39 pm Post subject: Bay window EFI ECU info needed can I use a 75 ecu on a 76 motor? |
Hello all I'm in the process of ditching the proggy on my 76 engine and going back to injection I got all the parts but the ecu is alluding me will the 75 ecu work? _________________ DORMOBILE TOP WANTED!!!!
1978 westy daily driver
1960 panel camper project
Mini R53 bob the tomato |
busdaddy Samba Member
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1602 Location: Indianapolis, IN
Posted: Tue Feb 27, 2018 4:57 pm Post subject: Re: Bay window EFI ECU info needed can I use a 75 ecu on a 76 motor? |
Yes it will _________________ Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone) |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Tue Feb 27, 2018 5:14 pm Post subject: Re: Bay window EFI ECU info needed can I use a 75 ecu on a 76 motor? |
they all work in all. |
Abscate Samba Member
Posted: Tue Feb 27, 2018 5:28 pm Post subject: Re: Bay window EFI ECU info needed can I use a 75 ecu on a 76 motor? |
That means I can add a “ How to convert a 75 to a 76 ECU “ video to my series! _________________ .ssS! |
Posted: Tue Feb 27, 2018 6:15 pm Post subject: Re: Bay window EFI ECU info needed can I use a 75 ecu on a 76 motor? |
that poor bastard is getting soooo much hate. |
Posted: Wed Feb 28, 2018 2:13 am Post subject: Re: Bay window EFI ECU info needed can I use a 75 ecu on a 76 motor? |
Abscate wrote: |
That means I can add a “ How to convert a 75 to a 76 ECU “ video to my series! |
As long as you don't then put it in a 72 covered in snow... _________________ Rebuild your own FI Harness..My Harness
Posted: Wed Feb 28, 2018 6:31 am Post subject: Re: Bay window EFI ECU info needed can I use a 75 ecu on a 76 motor? |
aerosurfer wrote: |
Abscate wrote: |
As long as you don't then put it in a 72 covered in snow... |
Thanks! We can stitch the two together et and make a third video!
Now it’s a sellable album set. First edition! _________________ .ssS! |
ROCKOROD71 Samba Member
Joined: January 18, 2012 Posts: 2770 Location: Boston, MA
Posted: Wed Feb 28, 2018 8:21 am Post subject: Re: Bay window EFI ECU info needed can I use a 75 ecu on a 76 motor? |
Wasn't there a switch in Mid 76 from the pre-heat 75 style FI to the Temp 2 sensor 77 style?
Wouldn't the ECUs be different betwixt the two?
6pin to 7 pin AFM harness...
Correct me if I'm wrong here.... _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
1977 WESTY "KrustyKamper" 2L FI
79SuperVert wrote: |
30 years from now, the next guy may not want your girlfriend, but he may want your classic car, depending on how nice you were to it. |
asiab3 wrote: |
Careful guys, a petulant child can grow up to be president these days. |
**winter drivers: no survivors!**rust warrior**#keepbodyshopsbusy** |
SGKent Samba Member
Posted: Wed Feb 28, 2018 8:40 am Post subject: Re: Bay window EFI ECU info needed can I use a 75 ecu on a 76 motor? |
in answer to the original question yes and no. The 1975 and the early 1976 are the same (012), the 1976 1/2 is the same as the 1977 (018 & 020). See BusDaddy's link to Ratwell. 1975 and early 1976 use a micro switch to determine WOT. 1976 1/2 and on use the speed of the door swing and position to determine WOT. So - it all depends on which 1976 motor and FI system you have - 1975 - early 1976, or 1976 1/2 (late). _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sun Mar 11, 2018 3:48 pm Post subject: Re: Bay window EFI ECU info needed can I use a 75 ecu on a 76 motor? |
Does anyone know the part # for the early 76 unit?
Thanx for the link I used ratwell to get the 78 westy Efi running back in 07 couldn't have done it or even contemplated doing this without it!!!
One thing do I have to use the old clear plastic vac hose ? is there a place that sells it? I wouldn't mind replacing the rubber bits too but they are hard to find now _________________ DORMOBILE TOP WANTED!!!!
Posted: Mon Mar 12, 2018 7:02 am Post subject: Re: Bay window EFI ECU info needed can I use a 75 ecu on a 76 motor? |
There is a guy who goes by GEEBEE on Samba who makes most or all of the hoses for FI that need to be replaced. They are top quality silicone hoses (incl the S boot). I bought a set and corresponded with him, he mostly makes parts and hoses for airplanes, so you know he's not screwing around. They are not the cheapest but you'll likely never have to buy any of them ever again.
The hard plastic hose up to the decel valve I would re-use unless you can find something similar, or a same-sized flexible reinforced hose that won't collapse from the vacuum. Not sure on the ECU part number but I am almost positive I have one in my garage as well as an NOS AFM for those 75-76 FI setups, both are totally useless to me. I will try and dig around tonight for them to post the numbers but we have a big storm coming so might not get to it right away. _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
asiab3 wrote: |
