DJG66 Samba Member
Posted: Wed Feb 28, 2018 5:24 am Post subject: Beetle 1960 1200 conversion to 1600 |
Hi all!
There is a 1960 undergoing a resto mod... and now, the time has come to think about the engine.
The matching numbers 1200 block is OK and ready... for what? The full 1600 conversion kit is ready, but the question is: would the smaller oil channels and the smaller oil pump be an issue?
Anyone who has done it, or has any experience with that?
All advice is welcome! Here is the Beetle:
bluebus86 Banned
Posted: Wed Feb 28, 2018 9:39 am Post subject: Re: Beetle 1960 1200 conversion to 1600 |
nice looking car!
so you want to bump up a 1200 case to a 1600 size? well I suggest you get a dual relief case, and start from there for best results, as vw eventually went that way..
for oil pump if your running the same rpms as before, the stock pump and passages should be ok.
note when vw did make the bigger motors they did eventually increase engine cooling vents by adding deck lid louvers, a prop upped deck lid is an option if this becomes a concern
frankly Id consider a late dual port dog house fanned motor for your car, much improved cooling for the bigger motor, given your climate, that is probably a good idea.
good luck, Bug On!
PS what engine kit do you have, what pieces? _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Wed Feb 28, 2018 9:56 am Post subject: Re: Beetle 1960 1200 conversion to 1600 |
I'm going to put my 2 cents in and say build up the matching number 1200cc engine stock since you have a nice restoration going. And get a separate 1600cc engine you could swap in if desired. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
caleb0101 Samba Member
Joined: August 26, 2014 Posts: 524 Location: Bristol Connecticut
Posted: Wed Feb 28, 2018 1:16 pm Post subject: Re: Beetle 1960 1200 conversion to 1600 |
i would just buy a 1600 and swap it in and leave your original engine alone _________________ Ruby red 1967 beetle sedan with a 2021cc
1967 beetle sedan baja project
April 60 euro spec ragtop beetle with a 1641cc |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Wed Feb 28, 2018 2:03 pm Post subject: Re: Beetle 1960 1200 conversion to 1600 |
Here is my 2 cents based on my fairly stock 65. It was a little to weak to fully enjoy, so I did the big bore kit (1398?) and carefully tuned, which involved rejetting as well. The car still has the stock geared tranny. This car runs as well as most stock 1600's except that I dont have the top speed because of the gearing. Not claiming that this engine has quite as much HP as a stock 1600, but its close enough.
That said - depending on what your goal is - If its like mine, do a big bore. No machining except possibly clearancing the case on #3 - lots of write ups on this.
If you want a bit more power, then go with a 1600 based engine and keep your stock 1200 in the event you ever want to sell the car or put it back in. _________________ D-Dubya Manx clone - 63 Short pan,1914.
DJG66 Samba Member
Posted: Wed Feb 28, 2018 9:38 pm Post subject: Re: Beetle 1960 1200 conversion to 1600 |
Thanks for the replies!
This is not mine - it is owned by the guy who is doing my '66, with many a Beetle resto under his belt. I am talking here on his behalf, as his resto skills are much better than his English
He had recently built a 1776 from a F engine, so the appetite for adventure is obvious
Anyway... I was also thinking that a 1385 would be a better bet. 1600 sounds a little too much for the humble 1960 1200 block.
Asking the obvious, before I do a search: any links detailing the 1200 to 1385 build? Sorry if it has been done to death and back!
Oh, and none of the Beetles will be living here in the desert... they are both in Belgrade, Serbia (currently -10° Centigrade and lotsa snow...) so the cooling should not be a big issue, except in the summer, when it can hit 40° Centigrade. |
Posted: Thu Mar 01, 2018 7:04 am Post subject: Re: Beetle 1960 1200 conversion to 1600 |
Honestly - I am not aware of a 1600 conversion done on a 1200. Not saying it can't be done, but it seems that everyone that goes big starts with a 1600.
The one thing that I had mentioned was the transaxle gearing. With stock gearing, I think your top speed is around 70 MPH, but I wont cruise in mine much above 65 even though it will do it. If you dont have large hills to deal with and you are doing any work on the transaxle, you may want to consider a taller 4th gear to allow for better higher speed cruising, if you think that you may need it. The shorter ring and pinion in the early transaxles will give you decent accleration from a stop, but more 4th will drop cruising RPMS.
I dont have particulars for what would be recommended, but I just want to throw out the idea.
The big bore kit for the 1200 is surprising and I did mention tuning that I did. I know for a fact that I stepped up the main jet on the 28PICT1 quite a bit and it made a substantial improvement on the dyno. But I had done this maybe 5 years ago, so details are fuzzy. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Zundfolge1432 Samba Member
Posted: Thu Mar 01, 2018 7:56 am Post subject: Re: Beetle 1960 1200 conversion to 1600 |
andk5591 wrote: |
The big bore kit for the 1200 is surprising and I did mention tuning that I did. I know for a fact that I stepped up the main jet on the 28PICT1 quite a bit and it made a substantial improvement on the dyno. But I had done this maybe 5 years ago, so details are fuzzy. |
I suggest reading “how to hot rod the VW engine” by bill fisher. It’s a period book written in 1970 but still available and they discuss along my with Gene Berg what it takes to build a 1600 using a 40 hp case. It’s doable and reliable if done correctly. Why just be like everyone else and hack in a dual port??
It is quite possible to build a sleeper which looks all innocent but runs great so you have the best of both worlds. Even if you don’t execute this plan I’d read that book as it’s a wealth of info for earlier parts. 😉 |
DJG66 Samba Member
Posted: Mon Mar 05, 2018 1:05 am Post subject: Re: Beetle 1960 1200 conversion to 1600 |
Zundfolge1432 wrote: |
I suggest reading “how to hot rod the VW engine” by bill fisher. It’s a period book written in 1970 but still available and they discuss along my with Gene Berg what it takes to build a 1600 using a 40 hp case. |
Will look into this...
It’s doable and reliable if done correctly. Why just be like everyone else and hack in a dual port?? |
Quite the train of thought that is slowly gaining steam...
Yep, that's the intention from day one. Aside from chromed vented 5J wheels, and the colour (see the first post), everything else is as standard as can be. Will get the book definitely! |
turbotype1 Samba Member
Posted: Mon Mar 05, 2018 3:37 pm Post subject: Re: Beetle 1960 1200 conversion to 1600 |
Isn't the 1200 in a 1960 a 36 horse? I haven't been aware of a kit to convert a 36 horse based case to a 1600. _________________
117harv wrote: |
This new fad of get it the lowest, or run it with the worst looks, (patina) isn't cool, it's for the hey everyone look at me crowd, i'm driving a beat down ratty, unsafe, VW, how cool am I ???...your not....
Pissing off the purists since 1997
Wanted: Boyd Motors plate frame
57 Turbo Oval Sliding rag
67 13 window delux walk-thru- now 21
64 all original for the misses
83 Sinka m-TDI diesel |
mukluk Samba Member
Posted: Mon Mar 05, 2018 5:39 pm Post subject: Re: Beetle 1960 1200 conversion to 1600 |
Yep, a stock 1960 Bug's 1200 would be a 36 horse. The 40 horse 1200 wasn't a stock engine in a Beetle until the 1961 model. _________________ 1960 Ragtop w/Semaphores "Inga" |
DJG66 Samba Member
Posted: Tue Mar 06, 2018 6:00 am Post subject: Re: Beetle 1960 1200 conversion to 1600 |
mukluk wrote: |
Yep, a stock 1960 Bug's 1200 would be a 36 horse. The 40 horse 1200 wasn't a stock engine in a Beetle until the 1961 model. |
You gentlement are correct.
BTW... may I fully agree with the quote below:
"117harv wrote:
This new fad of get it the lowest, or run it with the worst looks, (patina) isn't cool, it's for the hey everyone look at me crowd, i'm driving a beat down ratty, unsafe, VW, how cool am I ???...your not.... "
To quote a guy that just lowered the front: "I had to drive with my mouth open, paid too much for the fillings...)
Yep, you got it.
I can't get the slamming... patina yes, IF it is real, but no rust through or such stuff. To everyone his own, huh?
Trolling my own thread |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Tue Mar 06, 2018 7:26 am Post subject: Re: Beetle 1960 1200 conversion to 1600 |
If someone is losing fillings after lowering their bug they’re doing it wrong. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
Posted: Tue Mar 06, 2018 7:27 am Post subject: Re: Beetle 1960 1200 conversion to 1600 |
turbotype1 wrote: |
Isn't the 1200 in a 1960 a 36 horse? I haven't been aware of a kit to convert a 36 horse based case to a 1600. |
Maybe go over to vintage speed forum and see what they talk about. Stroker and big bore, more aggressive cams, dual carbs. It’s all there, people just gravitate to hacking in a newer engine because it’s easier. Single ports run great if you know what you’re doing and when you pop the hood it has the look there was life before dual port believe it or not. |
Posted: Tue Mar 06, 2018 7:29 am Post subject: Re: Beetle 1960 1200 conversion to 1600 |
Sharp64 wrote: |
If someone is losing fillings after lowering their bug they’re doing it wrong. |
Humor never works here. |
Posted: Tue Mar 06, 2018 7:31 am Post subject: Re: Beetle 1960 1200 conversion to 1600 |
Sharp64 wrote: |
I get he was exaggerating, but some people truly believe this. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
herbie1200 Samba Member
Joined: April 27, 2006 Posts: 833 Location: Rome - Italy
Posted: Wed Mar 07, 2018 12:24 am Post subject: Re: Beetle 1960 1200 conversion to 1600 |
1200 engines are very rare, I think they should be preserved.
Follow the hints above to take a stock 1600 engine and keep (or rebuild or, if you don't have space to keep, sell) the original 1200.
Look at VW shops: 1200 cylinders/Piston/Head set cost twice the value of 1600 parts.
The same for intake manifold.
Plus a 1200 with all its original parts has an intrinsic value, today and especially in the future. |
karl h Samba Member
Joined: October 10, 2005 Posts: 578 Location: austria
Posted: Wed Mar 07, 2018 5:06 am Post subject: Re: Beetle 1960 1200 conversion to 1600 |
herbie1200 wrote: |
Maybe in Italy but over here they are still going in the trash. I like the 1200 too had many a 36 and 40 hp, very durable in my opinion. They get a bad rap and people always want more never satisfied with what they’ve got. |
Posted: Wed Mar 07, 2018 7:02 am Post subject: Re: Beetle 1960 1200 conversion to 1600 |
karl h wrote: |
a 60 has the early style sheet metal at the front of the engine bay. if you want to stuff a motor with heaterboxes into it, you have to modify it. just FYI |
Not sure about this. Put a 1600 single port into a friends 60 a couple of years ago with fresh air heater boxes.... Although it is a tight fit, we didn't have to modify the front sheet metal. _________________
117harv wrote: |
