Zundfolge1432 Samba Member
Posted: Wed Mar 07, 2018 7:37 am Post subject: Re: Beetle 1960 1200 conversion to 1600 |
turbotype1 wrote: |
karl h wrote: |
a 60 has the early style sheet metal at the front of the engine bay. if you want to stuff a motor with heaterboxes into it, you have to modify it. just FYI |
Not sure about this. Put a 1600 single port into a friends 60 a couple of years ago with fresh air heater boxes.... Although it is a tight fit, we didn't have to modify the front sheet metal. |
I’m real sure because I’ve done it many times. Leave heater boxes off until motor is in. In fact leave off header, fuel pump, carb,distributor, gen pulley, breast plate and engine install is easy. Cursing is at a minimum and it’s not that hard to put all that stuff back on engine in.
Below is a 1964 deluxe that I installed a 1600 single port into, it also had doghouse tin, cooler and fan. Ran like a top plenty of giddy up, was missing 40 hp engine when I got it.
turbotype1 Samba Member
Posted: Wed Mar 07, 2018 9:12 am Post subject: Re: Beetle 1960 1200 conversion to 1600 |
Zundfolge1432 wrote: |
turbotype1 wrote: |
karl h wrote: |
So what modifications did you do to the front sheetmetal?
All I'm trying to say is that we did not have to modify the sheetmetal to put a 1600 into his 60. _________________
117harv wrote: |
This new fad of get it the lowest, or run it with the worst looks, (patina) isn't cool, it's for the hey everyone look at me crowd, i'm driving a beat down ratty, unsafe, VW, how cool am I ???...your not....
Pissing off the purists since 1997
Wanted: Boyd Motors plate frame
57 Turbo Oval Sliding rag
67 13 window delux walk-thru- now 21
64 all original for the misses
83 Sinka m-TDI diesel |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Wed Mar 07, 2018 11:32 am Post subject: Re: Beetle 1960 1200 conversion to 1600 |
turbotype1 wrote: |
turbotype1 wrote: |
All I'm trying to say is that we did not have to modify the sheetmetal to put a 1600 into his 60. |
Zundfolge1432 is actually confirming what you are saying!
I will also confirm it . . . I installed "doghouse" 1600 engines into my 1956 Bug and my 1962 Bug WITHOUT cutting anything on the body.
Leave the heat-exchangers off of the engine until the engine is bolted to the transaxle. _________________ Jesucristo es mi Señor y Salvador! |
Posted: Wed Mar 07, 2018 11:44 am Post subject: Re: Beetle 1960 1200 conversion to 1600 |
Gotcha.... Thanks
Pete _________________
117harv wrote: |
karl h Samba Member
Joined: October 10, 2005 Posts: 578 Location: austria
planenut Samba Member
Posted: Wed Mar 07, 2018 6:45 pm Post subject: Re: Beetle 1960 1200 conversion to 1600 |
If you stick the 1600 in, my advice, from experience in my '66, is to make sure you use stock oil pump, and keep the oil pressure within the designed limits. Too high an oil pressure when using a doghouse engine, will keep the cooler bypass in the 'bypass' position.n This means no oil thru the cooler, and overheating is a problem. I had to remove my 30mm oil pump, and put stock back in to get my oil pressure back to specs. Just a little advice, do what you want with it. Good looking car, by the way. |
DJG66 Samba Member
Posted: Sun Mar 18, 2018 6:48 am Post subject: Re: Beetle 1960 1200 conversion to 1600 |
herbie1200 wrote: |
1200 engines are very rare, I think they should be preserved.
Follow the hints above to take a stock 1600 engine and keep (or rebuild or, if you don't have space to keep, sell) the original 1200.
Look at VW shops: 1200 cylinders/Piston/Head set cost twice the value of 1600 parts.
The same for intake manifold.
Plus a 1200 with all its original parts has an intrinsic value, today and especially in the future. |
I know.
As I have said, not my car. The guy decided to do it, and is doing it. Who is on Facebook, check out Mad Beetle 1303
Who is not, the restoration album is here:
https://www.facebook.com/media/set/?set=a.69064845...a5fa189b7a
For the time being, the block is modified for a larger oil cooler, the crank from an AB engine is in, and so on... the cooling shroud modifications are ongoing.
Lots of 1200 engines in Serbia still, if you need some, let us know.
I will post some of the pics of the work |
