Obsesso Samba Member
Posted: Fri Mar 02, 2018 9:45 am Post subject: Denver or Front Range pop top swap shop or help? |
Hi,
I am trying to get my franken syncro, an 87 with a carat interior swapped in, converted to a pop top. I have an early pop top roof clip and top. I have read all the threads I can find on methods, of which there are many, but I have no welding skills. Apparently I won't be able to just rent a welder and learn how on this project
I have tried to find someone in CO to do this for me, Joel/escorial syncro/green syncro is too busy currently, RM Westy stopped doing them, Bavarian Wrench is apparently out of town living the dream in his syncro, Dai at opt overland would consider it but has yet to do a roof swap, he's installed his cool power roof with the country homes top and I would prefer the wider westy bed.
Anyway, bottom line question, is there anyone in the CO area(or within a days drive) with some experience to help me with or do this job? I was thinking of doing the spot weld method as I have a dent on the rear of my tintop anyway...I'm handy enough that I believe I could do the drilling and grinding to get the roofs ready but would need welding and paint help. |
nepawesty Samba Member
Posted: Fri Mar 02, 2018 12:30 pm Post subject: Re: Denver or Front Range pop top swap shop or help? |
I'm in Denver and would be happy to help. Although... No welding skills. Do you have a workshop? |
termuehlen Samba Member
Joined: May 02, 2012 Posts: 994 Location: Redwood City
Posted: Fri Mar 02, 2018 12:40 pm Post subject: Re: Denver or Front Range pop top swap shop or help? |
I know that you are asking for help along the front range, but if I were you, I would contact a few of the west coast companies that do this work. Who knows, maybe if your schedule is flexible, something can be worked out.
I would call:
Santa Cruz Campers
North Westy
das Mule
Can't hurt to ask. _________________ 1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx |
fleetwood41 Samba Member
Posted: Fri Mar 02, 2018 12:41 pm Post subject: Re: Denver or Front Range pop top swap shop or help? |
I had an early model pop top grafted to my 1987 excellently by Joel at Green Syncro last year. I don't have the skills needed to do this job or to be much help, but if you want to take a look at a professionally converted top, maybe we could figure something out. I tried to stay involved in the process as much as possible.
I'm northwest of Colorado Springs in Woodland Park and do travel to Denver occasionally.
Best of luck with the Conversion! _________________ 1987 2WD w/ 2.5 Subi & Poptop Conversion |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Fri Mar 02, 2018 3:23 pm Post subject: Re: Denver or Front Range pop top swap shop or help? |
It is pretty expensive to have a shop do it, lots of detail and time. But the "small hole" method is the simplest, pretty much just cut hole and bolt the top on. The process is well documented and final result looks nice. If you aren't doing a full westy conversion, this is worth considering. You can still manage to have a full width upper bunk, you just have to store the front upper mattress over the engine compartment when the top is down which is only a minor inconvenience. I did my first van this way.
Alternatively if you are committed to full roof skin swap, you can prepare the roof skin, you can have a body shop can weld it down for you. I started out thinking I would do a full roof skin swap, but it was difficult to separate the roof skin from the donor. It was tedious drilling out the spot welds but got a little easier with practice. I gave up after just trying to do one side. But if you do that yourself, then just start working on separating the roof skin from the donor roof clip all the way out to the gutters and front to back. If you get it off and in good shape, you are half way there.
I did my current van with the "overlap method using panel adhesive up top and welding inside. I did not go all the way out to the gutters and found it reasonably challenging but doable for me. I paid a shop to weld/glue on the top. Here is my thread.
https://www.thesamba.com/vw/forum/viewtopic.php?t=612349 |
Posted: Fri Mar 02, 2018 3:56 pm Post subject: Re: Denver or Front Range pop top swap shop or help? |
nepawesty wrote: |
Appreciate it, unfortunately, I'm working in my backyard at this point. Do you have any experience in this process?
Thanks! |
DenverB Samba Member
Joined: July 23, 2012 Posts: 704 Location: Denver, Colorado
Posted: Sat Mar 03, 2018 8:40 am Post subject: Re: Denver or Front Range pop top swap shop or help? |
Are you the guy who called me (rocky mountain campervans) a few months ago about this? If so, I have had about as much finding someone as you have.
my advice: unless you do it right, you're going to devalue the thing. Nobody wants a hacked-on roof on a top-dollar syncro.
do yourself a favor: do the interior swap, enjoy it as a tintop camper for now and wait until you can get someone to do the top correctly. _________________ -------
'77 Transporter/camper (Bussy - Reef Blue/Pastel White)
'67 bug (Santos - VW Blue)
'84 Vanagon Westfalia (Pink Flamingo - Pastel White/Pink)
'88 Vanagon GL Westfalia (Frankie Says - Wolfram Gray)
'02 Eurovan Weekender (Green Apple)
'95-'03 Eurovan full campers and weekenders (rental fleet)
'84 -'91 Vanagon full campers and weekenders (rental fleet)
'72 Porsche 914 (Greta - RIP)
www.RockyMountainCampervans.com |
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2079 Location: Bulli Klinik, Colorado Springs
Posted: Sat Mar 03, 2018 10:16 am Post subject: Re: Denver or Front Range pop top swap shop or help? |
I may have an interest in doing your project. What is the time-frame? You can see some of my work in the gallery.
Feel free to shoot me a PM. _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
Posted: Sat Mar 03, 2018 11:11 am Post subject: Re: Denver or Front Range pop top swap shop or help? |
DenverB wrote: |
do yourself a favor: do the interior swap, enjoy it as a tintop camper for now and wait until you can get someone to do the top correctly. |
I'm not sure we spoke, I do believe I emailed about trying out one of your vans to see if a poptop makes sense, and I agree, I want to do this right, though my 300,000 mile syncro is not a top dollar one:) |
Posted: Sat Mar 03, 2018 11:20 am Post subject: Re: Denver or Front Range pop top swap shop or help? |
Bulli Klinik wrote: |
Feel free to shoot me a PM. |
impressive work! PM sent |
jimf909 Samba Member
Posted: Sat Mar 03, 2018 11:47 am Post subject: Re: Denver or Front Range pop top swap shop or help? |
Obsesso wrote: |
Nice gallery. This has potential. Hope it turns into a thread. _________________ - Jim
Abscate wrote: |
Posted: Sat Mar 03, 2018 2:27 pm Post subject: Re: Denver or Front Range pop top swap shop or help? |
word. let me know if you need to come by and look at a camper for any reason.
E1 Samba Member
Joined: January 21, 2013 Posts: 6556 Location: Westfalia, Earth
Posted: Sat Mar 03, 2018 5:07 pm Post subject: Re: Denver or Front Range pop top swap shop or help? |
Do you install poptop tents, too?
Need ours done in late Spring on our way through Colorado. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
3dig Samba Member
Joined: October 20, 2012 Posts: 142 Location: Bellingham, Wa
Posted: Sat Mar 03, 2018 5:56 pm Post subject: Re: Denver or Front Range pop top swap shop or help? |
Try OPT Overland in Ft Collins, they will do you right. |
E1 Samba Member
Posted: Sat Mar 03, 2018 7:56 pm Post subject: Re: Denver or Front Range pop top swap shop or help? |
Thanks for that!
We're having RMW do some things while there anyway, I've yet to ask if they do those installs. May take it on ourselves, too... _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Posted: Sat Mar 03, 2018 9:44 pm Post subject: Re: Denver or Front Range pop top swap shop or help? |
E1 wrote: |
Thanks for that!
We're having RMW do some things while there anyway, I've yet to ask if they do those installs. May take it on ourselves, too... |
Dai at opt overland is really nice, he's never done a Westy swap, but owns the country homes fiberglass mold and has put his popup mechanism under that before. He expressed a little interest in doing my Westy swap, he was where I was referred to by Rocky mountain Westy for a poptop though he's booked out a ways. Interestingly Dai said RMW used to do them but stopped, he seemed to be hinting it was just too labor intensive to be worth it. From the perspective of a repair and not a body shop, I'm sure it is. |
E1 Samba Member
Posted: Sat Mar 03, 2018 10:26 pm Post subject: Re: Denver or Front Range pop top swap shop or help? |
Thanks for all the insights, Obsesso.
We may get an Atelier tent if we can. We did a commonly-available one last time and it's just not great material, whereas Sunbrella is. Our awning from Fancher uses Sunbrella and has been up over 1,000 days (at least) and withstood Hurricane Matthew 40 miles inland (seriously).
Atelier does installs for $225 for the stapled style, and $160 for the later, screw-in style. They must be really fast because that is one great deal! There's a certain race in Montreal every June, I was at the first 40 years ago (witnessing Canada's finest racing day ever to that point) and an excuse like this is pretty tempting...
Being it's hard to find someone doing these tents, it seems to me to be a cool thing to offer -- the idea being some customers find more work to have done for the specialized service (I do, anyway).
Thanks Again. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
SyncroChrick Samba Member
Joined: January 10, 2005 Posts: 1010 Location: San Francisco, CA
Posted: Sat Mar 03, 2018 11:29 pm Post subject: Re: Denver or Front Range pop top swap shop or help? |
Obsesso,
I am in the process of finishing the conversion of a 1988 Vanagon Syncro into a Westfalia. My van has 330000 miles on it, but at this point virtually everything has been replaced so the miles don't mean much.
I did tons of research and I was going to do it myself, but here is my advice - if you are going to do it, do it the right way. There is only one way to do it to replicate the factory and it is to remove the skin at the spot welds.
I ended up having the Kombi Haus in Sacramento do the work, and they did an excellent work. It was $4500 + tax for the rough job, that did not include any painting or reinstalling the poptop tent or any of the interior work. In my case I was lucky because the roof came from a van of the same year/color, so there was only a few "scars" to cover.
I am extremely pleased with the result.
Pics soon... |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Mon Mar 05, 2018 9:16 am Post subject: Re: Denver or Front Range pop top swap shop or help? |
If you decide to do the hole-in-the-roof method, Matt did a really nice job with his:
Part of me thinks that this would be an excellent Saturday afternoon barn-raisin' type project if we could get Matt or Dave involved, but I can't speak for other people's availability.
I am planning to eventually do something similar (haven't decided on a top) for my Syncro, but have never done it before and don't want to learn how on your Syncro.
Whatever direction you end up going, please keep us posted, and come to one of the Vanagons and Microbrews get-togethers so we can check it out! _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
Posted: Tue Sep 18, 2018 9:23 am Post subject: Re: Denver or Front Range pop top swap shop or help? |
I decided to bite the bullet and pay big bucks. Mike at Bulli Klinik has been great to work with and is an artist with sheetmetal. Unfortunately my top was in rough shape so it was taken back to bare metal before grafting, which was spendy compared to just welding it on with the prep, treatment, etc but will be best long term. I've attached a few pics. Mike doesn't do much paint, so now I'm in need of a shop around here. I'm going to contact the commerce city maaco, I know Wheels of Time have done a few paint jobs also, but given this is mostly covered by the fiberglass I'm not sure I need a show quality finish and the cost that comes with it....
