What size rear tire?
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
Speedbird73
Speedbird73 is offline
PostPosted: Fri Mar 02, 2018 7:16 pm    Post subject: What size rear tire? Reply with quote
Hi guys,
Curious, I was on busselcta.com playing around, and it made salivate over the look of a large tire in the rear of my '72 bug. It has been lowered "2 clicks" according to the PO. What is the biggest tire that you think would fit back there?
RareAir
RareAir is offline
PostPosted: Sat Mar 03, 2018 9:00 am    Post subject: Re: What size rear tire? Reply with quote
205/70 is a popular large size for Beetles not lowered too severely.
I’ve also seen 215/70, but not sure what ‘2-clicks’ looks like
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
esde
esde is offline
PostPosted: Sat Mar 03, 2018 9:44 am    Post subject: Re: What size rear tire? Reply with quote
My experience is that 2 clicks down and 205-215/ 70 series tires often don't play well together. The wheel back spacing has to be just right to get the tire centered in the fender.
modok wrote:
ALB
ALB is offline
PostPosted: Sat Mar 03, 2018 2:23 pm    Post subject: Re: What size rear tire? Reply with quote
A 205/70-15 is over 26 1/4" tall so as well as possible clearance issues, it will suck the life out of the car's acceleration and with a smaller engine and stock transaxle you may find 4th gear somewhat unusable.
Just something to keep in mind...
As usual, just my 2 1/2 cents (I'm Canadian, eh). Al
On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!!
Speedbird73
PostPosted: Sat Mar 03, 2018 7:54 pm    Post subject: Re: What size rear tire? Reply with quote
Thanks guys, I didn't even think of it robbing the power (that it barely has!)
Any ways, here she is last summer, I like the tires on it I suppose.
ALB
ALB is offline
PostPosted: Wed Mar 07, 2018 5:16 am    Post subject: Re: What size rear tire? Reply with quote
The car looks good, Speedbird. What size tires are on the back now?
RareAir
RareAir is offline
PostPosted: Sat Mar 10, 2018 10:27 pm    Post subject: Re: What size rear tire? Reply with quote
I’d have to disagree with this assessment. My ‘59 Beetle is still powered by the original 36hp engine and crash box trans. It has no problems propelling the car with it’s 205/70-15 rear tires.
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
dagen_1
dagen_1 is offline
PostPosted: Tue Mar 20, 2018 1:46 pm    Post subject: Re: What size rear tire? Reply with quote
out of curiosity, what size are the rear tires pictured here?
74 Super Beetle
ALB
ALB is offline
PostPosted: Thu Mar 22, 2018 11:02 am    Post subject: Re: What size rear tire? Reply with quote
First- good looking car! Love it. And ok, 'suck the life out of the car's acceleration' may be a little bit of an exaggeration, but going to a taller rear tire is like putting a taller r&p in the trans- it changes things. You may not have noticed it (or care), but it's not as quick off the line as with the stock size tires.
All I'm saying is it's something to be considered. Al
Stewartwms21
Stewartwms21 is offline
PostPosted: Fri May 04, 2018 4:10 pm    Post subject: Re: What size rear tire? Reply with quote
RareAir that is the look I'm going for on my 74. What size tires are you running up front? Also what is the width of your wheels and are you lowered in front and back?
RareAir
RareAir is offline
PostPosted: Sun Jun 03, 2018 8:03 pm    Post subject: Re: What size rear tire? Reply with quote
Wheels are Fuch (pronounced Fox, as in German. Not foosh as most Americans pronounce it).
Fronts measure 15x4.5J with 145R15
Rears are 15x5.5 with 205/70R15 (soon to be replaced with 15x6J)
Front end is lowered approx 3-1/2” using dropped spindles and Avis adjusters
In those older photos, rear end was at stock height. Car currently sits 2” lower (+3 inner spline, -2 outer spline)
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
aa390392
aa390392 is offline
PostPosted: Mon Jul 30, 2018 8:21 am    Post subject: Re: What size rear/front tire? Reply with quote
Looking for some advise, on my 56 convertible tire sizes, a few question
1.will these tires fit on a stock smoothie wheel. 185/65r 15--195/65r 15's?????
2 iffen they do fit will they work, or are they to large for a stock suspenion car?
Any help or suggestions will be appreciated.
Cheers Thomas
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet
Mike Fisher
Mike Fisher is offline
PostPosted: Mon Jul 30, 2018 8:44 am    Post subject: Re: What size rear/front tire? Reply with quote
Cheers Thomas
4.5" wide VW wheels are only safe for up to 185's but no bigger!
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
