My 1976 westfalia project
Page: Previous  1, 2, 3, 4, 5
Calvin&Hobbes
Calvin&Hobbes is offline
PostPosted: Thu May 06, 2021 6:40 am    Post subject: Re: My 1976 westfalia project Reply with quote
Thanks Bus Daddy
I have a kit to replace all... but I wanted to work on the floor mat and having everything in place give me a better view
Wasted youth
Wasted youth is offline
PostPosted: Fri May 07, 2021 7:18 am    Post subject: Re: My 1976 westfalia project Reply with quote
https://www.thesamba.com/vw/gallery/pix/1169088.jpg
https://www.thesamba.com/vw/gallery/pix/1169089.jpg
Calvin&Hobbes
PostPosted: Mon Jun 28, 2021 11:27 am    Post subject: Re: My 1976 westfalia project Reply with quote
Hi there
About to reinstall the interior but I have one more question
I believe the 2 layers of the floor were screwed together but I was wondering if it was also going through the metal floor or not
Let me know
Calvin&Hobbes
PostPosted: Sun Jul 04, 2021 11:00 am    Post subject: Re: My 1976 westfalia project Reply with quote
Hello folks
I’ve put the interior back in the bus but I can’t recall how the wiring was coming to the water pump ( and to the speaker)
Is it under the carpet?
Calvin&Hobbes
PostPosted: Mon Jul 05, 2021 12:12 am    Post subject: Re: My 1976 westfalia project Reply with quote
any Idea
I believe under the carpet is my best option but want to make sure
thanks
Laurent
Jetfxr69
Jetfxr69 is offline
PostPosted: Mon Jul 05, 2021 5:02 am    Post subject: Re: My 1976 westfalia project Reply with quote
Water pump feeder goes under the front floor mat, through the storage area below drivers seat, out a grommeted hole in the spare tire cabinet, around the back of the sink/stove cabinet and finally to the pump. Nat a very good run by any means. Its also on a fused link and the ground is off the wall behind the sink/stove cabinet.
For rear speakers, I ran my wires up the front left pillar, under headliner, and then behind the wood grain trim pieces above the windows ( same area as the sink light). Into the wardrobe cabinet, and then through that one into the headbanger.
The two pieces of floor (masonite/foam pad) were not screwed together. And I dont believe ive seen any OG ones that were screwed to the steel bed. So many have been changed out since new that its hard to say. Only one of my ‘77’s was OG, and I pulled that floor up so long ago, I dont recall fully.
You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer. Zappa
‘77 westy Seamus
‘76 tintop Crusher
‘77 westy The Judge
‘72 tintop bastard westy Hudson
Calvin&Hobbes
PostPosted: Tue Jul 06, 2021 7:03 am    Post subject: Re: My 1976 westfalia project Reply with quote
thanks Jetfxr69
for the 2 piece of floor mine was OG (and relatively well maintained but there was few stains that would dissapear hence the change... they were definitely screwed together but indeed not down to the metal floor
thanks for the wiring, not that optimum indeed... I will do as you mentionned
hve a great day
Page 5 of 5
