i_luv_my_bus76 Samba Member
Joined: May 18, 2012 Posts: 371 Location: High Desert
Posted: Sun Mar 04, 2018 12:15 am Post subject: Crankshaft key way |
I am assembling my crankshaft. I have installed the rods, timing gear, distributor drive gear, main bearings...
When I put on the oil slinger and the key way the pulley rides on I noticed the key way just slides in and has play from side to side...
Has anyone else ran into this issue, if so what is the fix?
Does anyone have dimensions for the key way? |
anthracitedub Samba Member
Posted: Sun Mar 04, 2018 5:45 am Post subject: Re: Crankshaft key way |
You could always use a new key. Or is it the crank that is loose? |
Posted: Sun Mar 04, 2018 7:48 am Post subject: Re: Crankshaft key way |
anthracitedub wrote: |
That is what I am trying to determine |
Posted: Sun Mar 04, 2018 10:27 am Post subject: Re: Crankshaft key way |
Just measured a key and got .2335”. Measured a crank and got the same. |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4524 Location: Oklahoma City, OK
Posted: Sun Mar 04, 2018 11:31 am Post subject: Re: Crankshaft key way |
Order of which I would tackle the issue:
Try another key, preferably a new one.
Peen the crank on both sides of the keyway.
Try some .001 shim stock
Last but not least find another crank. |
Posted: Sun Mar 04, 2018 11:35 am Post subject: Re: Crankshaft key way |
busman78 wrote: |
Last but not least finds another crank. |
I am hoping I do not have to do the last one since I have everything torqued and the crank built...I bought the re ground crank from a reputable and popular vw machine shop... surely they didn't sell me a bad crankshaft |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Sun Mar 04, 2018 11:43 am Post subject: Re: Crankshaft key way |
i_luv_my_bus76 wrote: |
Is it a stock or aftermarket crankshaft? If it's aftermarket, it may very well be the keyway that's too wide. I've also found many aftermarket keys to be too wide (need filing to fit a stock crank). So, maybe that would be the start of your "fix".
SD _________________ modok wrote:
Posted: Sun Mar 04, 2018 11:45 am Post subject: Re: Crankshaft key way |
I'll take a pic shortly |
Pickup a new key, maybe another good used one. |
Posted: Sun Mar 04, 2018 11:47 am Post subject: Re: Crankshaft key way |
esde wrote: |
SD |
Stock re ground crankshaft |
Posted: Sun Mar 04, 2018 11:50 am Post subject: Re: Crankshaft key way |
busman78 wrote: |
That was gonna be my first try... I live over an hour from a parts store that carries vw parts... it will have to wait until next weekend unless someone on here in the high desert is willing to sell me one that might work 😁😁😁😁😁 |
mark tucker Samba Member
Posted: Sun Mar 04, 2018 1:31 pm Post subject: Re: Crankshaft key way |
there are many widths of keys, and you can size one for your crank, but be sure to check the pully fit of the new key!!! you may need to size a step in it for the pully but probably not. I do not like the new keys sold these days, there powered metal...shit if you ask me. they crumble when trying to get them out of the crank making it a real bitch to get out. so ive tried to stock up on oe keys. the key should be snug to tight, not beat the shit out of it tight but enough so it dosent move when installing the pulley.Ive seen loose keys ride up in the groove and eff up the pully and grab the case...not good. I don't like the idea of peening the crank.although you can add a few diviots to the key to tighten it, but it's better to get a better fitting key. locktight is another option, but...still better to get a gooder fitten key. personaly I would of put a good crank in it....the reason I will not use a oe vw crank is they are so soft. |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3444 Location: San Diego
