Dfasty Samba Member
Joined: November 22, 2005 Posts: 528 Location: north bay,ca.
Posted: Tue May 08, 2018 11:13 am Post subject: Re: Why was it parked? 1972 Type 3 Variant squareback |
The plugs look like platinum plugs. The cut wires are for the test port that was a vw tech tool that no one has any more. _________________ 70 fastback automatic 06 invader |
hentotheree Samba Member
Posted: Tue May 08, 2018 11:52 am Post subject: Re: Why was it parked? 1972 Type 3 Variant squareback |
Car im sure needs a ton of work, no more than $1000. Obviously the owner is allowing it go to waste and rot in his back yard. If I was him I'd be happy that someone is willing to get it off of my hands for a grand... that's me, though. |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13843 Location: White Mountains Arizona
Posted: Tue May 08, 2018 12:37 pm Post subject: Re: Why was it parked? 1972 Type 3 Variant squareback |
Well I did haul it out of there for the grand total of eight hundred. This to me seemed a reasonable fair price for a straight dry body. Even thought infamous right side pan aka battery region needs replacement.
Yep the plugs are the platinum one that I cleaned, installed and fired up the engine with them. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Dfasty Samba Member
Posted: Tue May 08, 2018 6:34 pm Post subject: Re: Why was it parked? 1972 Type 3 Variant squareback |
Regular plugs like NGK BR6HS burn better than platinum ones. The smoking might go away to after a few drives on the motor. _________________ 70 fastback automatic 06 invader |
gt1953 Samba Member
Posted: Wed May 09, 2018 4:52 pm Post subject: Re: Why was it parked? 1972 Type 3 Variant squareback |
My major concern is being parked for ten years that valve springs being compressed for that length of time is not a good thing. Ask any old school mechanic. So rebuilt heads are for sure going to happen. Since I will be that far into it, piston and cylinders as well. Depending on end play may have to open it up the rest of the way. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
gt1953 Samba Member
Posted: Sun Jun 17, 2018 7:22 am Post subject: Re: Why was it parked? 1972 Type 3 Variant squareback |
Oh my many reasons why it was parked.
Well cleaned fuel tank, repaired all lights and they all work, windows roll up and down, door weep holes cleaned, fuel sending unit repaired, gas tank cleaned, gauge lights all work, odometer still does not, speeedometer does, greased everything that needs grease, timing would not advance with the distributor so swapped in a German 009, yep the engine still smokes, I was glad to see the horn can be taken apart and repaired now sounds great, emergency hand brake was waky repaired that.
Oh brother still needs floor pan welded in that is happening this week, soon after new muffler. Will remove engine, more then likely will just do a top end rebuild.
Still have lots more to do. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Sqrbckguy38 Samba Member
Joined: December 21, 2004 Posts: 415 Location: Tooele, ut
Posted: Sun Jun 17, 2018 8:03 am Post subject: Re: Why was it parked? 1972 Type 3 Variant squareback |
Sounds like great progress though. Are you still running that Weber? What kind of muffler are you looking to get, stock or aftermarket? What are you going to replace that carb with? Hope you're enjoying the car. _________________ It's not the fall that hurts, it's the sudden stop at the bottom.
69 Square needs love, even after 15 years
70 Fasty former dd, now my daughter's
67 Beetle, Opal |
gt1953 Samba Member
Posted: Sun Jun 17, 2018 8:36 am Post subject: Re: Why was it parked? 1972 Type 3 Variant squareback |
Are you still running that Weber? Yes while its in progress.
What kind of muffler are you looking to get? Stock one for sure
What are you going to replace that carb with? Have sourced stock set of dual carbs, linkage, and air cleaner.
Still not actively driving the vehicle while doing the repairs...not insured to drive yet, is registered. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
gt1953 Samba Member
Posted: Fri Jun 22, 2018 7:23 am Post subject: Re: Why was it parked? 1972 Type 3 Variant squareback |
Right side pan was replaced this week. Turned out fine and dandy. Another reason it may have been parked.
Finished product. Another item checked off the list.
72 type 1
72 Squareback
gt1953 Samba Member
Posted: Thu Aug 09, 2018 6:26 pm Post subject: Re: Why was it parked? 1972 Type 3 Variant squareback |
Still attempting to remove this 46mm nut from the heat exchanger as it has suffered rustosis. Just another reason it was parked for ten years. Not surprising and to be expected. The brakes are refreshed, trans oil changed, still waiting engine parts, its a hobby like golf for example. Take my time I only want to do it once.
72 type 1
72 Squareback
gt1953 Samba Member
Posted: Mon Oct 15, 2018 3:28 pm Post subject: Re: Why was it parked? 1972 Type 3 Variant squareback |
Its running yippy. As mentioned did the top end of the motor, Pistons, cylinders, rebuilt heads, Volksbiz carbs. Went thru the brakes as well. STill have more to do but I did drive it about 20 miles today. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33883 Location: Conejo Valley, CA
Posted: Mon Oct 15, 2018 3:37 pm Post subject: Re: Why was it parked? 1972 Type 3 Variant squareback |
Congrats! Great progress! |
gt1953 Samba Member
Posted: Tue Oct 16, 2018 5:57 am Post subject: Re: Why was it parked? 1972 Type 3 Variant squareback |
The carbs had to go to Volksbiz. Glad I did he is the top shelf carb guy. A couple of mechanics looks at them before and said just ad the carb rebuild kit to them. Well I figured new pistons and cylinder, rebuild heads, may as well do the carb also. Take a look at before and after.
72 type 1
72 Squareback
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Tue Oct 16, 2018 8:03 am Post subject: Re: Why was it parked? 1972 Type 3 Variant squareback |
gt1953 wrote: |
Where are the 'after' pics of YOUR carbs? |
gt1953 Samba Member
Posted: Wed Oct 17, 2018 11:37 am Post subject: Re: Why was it parked? 1972 Type 3 Variant squareback |
ataraxia you had asked "Where are the 'after' pics of YOUR carbs?"
They went from the shipping box to the engine. The after pics of the carbs I think you directed me to them....They, the ones on the engine look as good or better then the photos. I do not intend on removing them to take a photo duh.
72 type 1
72 Squareback
RAIDER SS Samba Member
Joined: November 21, 2003 Posts: 270 Location: Fairport, New York
Posted: Wed Oct 17, 2018 7:10 pm Post subject: Re: Why was it parked? 1972 Type 3 Variant squareback |
Thanx for saving another T3, and for properly getting rid of that weber!
I say properly with the exception of that throttle linkage return spring rigging - That is a full throttle disaster waiting to happen! _________________ 1972 SquareBack.....recycled back to life......
"Elwood" |
Posted: Wed Oct 17, 2018 8:10 pm Post subject: Re: Why was it parked? 1972 Type 3 Variant squareback |
gt1953 wrote: |
The pictures you posted are of carburetors I had rebuilt over 2 years ago - so, naturally, I found it odd that you copied them from my gallery, saved them to your own gallery and posted them as your own photos.
If you're going to swipe pics from the gallery at least be transparent about it.
The 'duh' comment speaks for itself. |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22697 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Wed Oct 17, 2018 8:27 pm Post subject: Re: Why was it parked? 1972 Type 3 Variant squareback |
RAIDER SS wrote: |
I say properly with the exception of that throttle linkage return spring rigging - That is a full throttle disaster waiting to happen! |
And proper except the gawddamn fasteners, nipples, butterflies and levers/ linkages should be yellow cad and not silver, but I won't bring that up. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Wed Oct 17, 2018 8:28 pm Post subject: Re: Why was it parked? 1972 Type 3 Variant squareback |
ataraxia wrote: |
gt1953 wrote: |
Thought you did your own work, there, pally. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
gt1953 Samba Member
Posted: Thu Oct 18, 2018 6:38 am Post subject: Re: Why was it parked? 1972 Type 3 Variant squareback |
RAIDER SS I have sourced springs since the photo was taken...I am aware of the full wide open throttle.
Resurrecting this has been a learning experience for an upright engine guy. Always willing to listen to suggestions on how to make it correct and better. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
