ConcreteAce Samba Member
Joined: May 19, 2005 Posts: 856 Location: Spring, Texas
Posted: Sun Mar 04, 2018 4:14 pm Post subject: WW Okrasa motor install Info needed |
I am on the final stages of my 36 build using the WW Okrasa kit. I am wondering since you have to install the cylinder tin and the manifold at the same time will I need to install the long block into the car, or will the manifolds clear so that I can have my motor assembled less the carbs before installing in the car? Thanks _________________ Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'68 Turbo Diesel Baja
'64 Ghia Vert
'61 Baja Build |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Sun Mar 04, 2018 5:10 pm Post subject: Re: WW Okrasa motor install Info needed |
manifolds on. Every thing except the carbs installed. You have to twist the engine a little to clear the sides but there is enough wiggle room to do this. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
aircooled60 Samba Member
Joined: August 10, 2005 Posts: 10 Location: San Diego
Posted: Mon Mar 05, 2018 4:40 pm Post subject: Re: WW Okrasa motor install Info needed |
Rick is correct, manifolds on and I have done it more than once with the drivers side carb on and giving the motor a twist till everything clears.
Rob D. _________________ 57 Oval, 69.5 mm Stroker, w/ W.W. Okrasa Kit (WW36 Bonneville Record Holder),
57 Oval Ragtop w/ WW Okrasa Kit,
66 Ghia Project
2 '68 Honda CL90 Pit Bikes |
hutmo Samba Member
Joined: February 05, 2002 Posts: 37 Location: Pittsburgh, PA
Posted: Mon Mar 05, 2018 8:48 pm Post subject: Re: WW Okrasa motor install Info needed |
Can I remove the driver side carb instead?
Chris _________________ What if the Hokey Pokey really is what it is all about?
Samba Member #1115
Joined Feb 6, 2002 |
Posted: Wed Mar 07, 2018 12:37 pm Post subject: Re: WW Okrasa motor install Info needed |
Removing the drivers side might be better. You would be twisting the motor counter clockwise, which would move the generator away from the apron. I don't know if it makes any difference. The only reason I took only 1 carb off is it was the 1st time installing the dual carb motor and I already had the carbs and linkage all installed and adjusted before I knew it would't fit..... _________________ 57 Oval, 69.5 mm Stroker, w/ W.W. Okrasa Kit (WW36 Bonneville Record Holder),
66 Ghia Project
