Wolfsbane Samba Member
Posted: Sun Mar 04, 2018 6:59 pm Post subject: Opinions on the B5/B5.5 Passat |
Opinions on the B5/B5.5 Passat? Manual transmission. Sedan, not wagon.
The 1.8T turbo versus 2.8VR6. Those were the most common US engines. I've heard the VR6 made the car a bit nose heavy.
Ideally about 1999 onwards. Obviously the North American versions.
I'm a sporty driver. Not total maniac level. But have on occasion disregarded signs on the side of the road with numbers on them. Enjoy a twisty road. |
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Sun Mar 04, 2018 7:47 pm Post subject: Re: Opinions on the B5/B5.5 Passat |
I have an 01 A4...essentially the same car. 1.8t with a 5 speed. as long as I don't get cleaned up in an accident....I will keep it forever 2.8's are fucking pigs. I bought mine CPO in 03-04. 130K on it now, bought it with 40K
stay away from automatics and 2.8's and they will go forever _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Sun Mar 04, 2018 8:33 pm Post subject: Re: Opinions on the B5/B5.5 Passat |
First, the 2.8 is not a VR motor, it is a 30valve 90* V-6, not fast but it is smooth.
They are nice sedans, comfy and competent. The outer CV boots are a normal wear item, they wear out much faster than the same on a Jetta, but if caught can be replaced and no harm. Front suspension has multiple of ball joints, so those wear out over time.
A4 is the same car, just the body is wrapped tighter, thus looks more sporting.
A 1.8T car will be easier add HP as all it takes is a chip tune, there aren't really any performance parts for the for the 2.8. I suppose you could swap in a 3.03.2 or better yet a 2.7T. |
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Mon Mar 05, 2018 8:50 am Post subject: Re: Opinions on the B5/B5.5 Passat |
The B5/B5.5 chassis was quite possibly the best highway chassis ever designed by VAG. The V6 is a great engine, but there's not really any tuning support. The 1.8t was a great engine also but was plagued by carbon buildup clogging oil pump pickup tubes due to manufacturer suggested extended oil service intervals, high internal temperatures & people that didn't use the specified synthetic oils. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon Mar 05, 2018 8:53 am Post subject: Re: Opinions on the B5/B5.5 Passat |
ps2375 wrote: |
The A6 is also the same chassis, just a bit bigger. Believe it or not, the same windshield fits the A4, A6, & the Passat. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
ps2375 Samba Member
Posted: Mon Mar 05, 2018 12:17 pm Post subject: Re: Opinions on the B5/B5.5 Passat |
TDCTDI wrote: |
ps2375 wrote: |
The A6 is also the same chassis, just a bit bigger. Believe it or not, the same windshield fits the A4, A6, & the Passat. |
Ha! I had no idea. |
rustfree1967bug Samba Member
Joined: November 16, 2006 Posts: 3436 Location: minnesota
Posted: Tue Mar 06, 2018 1:30 pm Post subject: Re: Opinions on the B5/B5.5 Passat |
Pretty good cars overall, i know the b5's tend to have issues with the abs module going bad. If it were me I'd probably go for the 1.8t. I have personal experience with a 1.8t in a 2003 jetta at 265k original turbo and everything and it's still going strong. Just make sure you use synthetic oil and change it every 5k. _________________ '70 ghia
'69 ghia
'65 singlecab
'66 sunroof beetle
'74 bus
'67 so-42
IDA's...well... they talk dirty -MURZI |
ps2375 Samba Member
Posted: Tue Mar 06, 2018 2:21 pm Post subject: Re: Opinions on the B5/B5.5 Passat |
rustfree1967bug wrote: |
Pretty good cars overall, i know the b5's tend to have issues with the abs module going bad. |
A fairly easy and inexpensive repair, just take the brain off and sent it out for repair. From what I've been told, just some very fine wire(s) that break due to vibration and no support.
And the first mod I'd add to the 1.8T even if I wasn't going for more power would be an oil cooler with a thermostatic sandwich plate. The stock "cooler" is only good for warming the oil, imho. |
Sqrbckguy38 Samba Member
Joined: December 21, 2004 Posts: 415 Location: Tooele, ut
Posted: Wed Mar 06, 2019 5:57 pm Post subject: Re: Opinions on the B5/B5.5 Passat |
So, what about the W8 version of the Passat? I'm interested in buying one, that runs pretty well, but want to know what I'm getting into. Any particular issues I should look for, anything I should look at before I buy it? I'm going this Saturday to look at it. _________________ It's not the fall that hurts, it's the sudden stop at the bottom.
69 Square needs love, even after 15 years
70 Fasty former dd, now my daughter's
67 Beetle, Opal |
Posted: Wed Mar 06, 2019 7:00 pm Post subject: Re: Opinions on the B5/B5.5 Passat |
lolololol
timing chains, plastic cooling pipes that grenade, super expensive parts everywhere...
if the car were free, it's still too expensive. seriously...if it were a 1500 car I got a year out of I would peel the plates off right where it puked and walk away _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Thu Mar 07, 2019 6:33 am Post subject: Re: Opinions on the B5/B5.5 Passat |
That engine is an Albatross from hell, made for maybe two years only with absolutely NO aftermarket support & are now old enough that the dealer parts department starts laughing at the mere mention of it. The minimum entry fee for any repair is $1,000. Cant get it inspected because of a check engine light on for a thermostat? Electronic thermostat, $700 for the part, another $300 for labor. And WTF is up with a timing belt just to drive the oil pump?!?
HOWEVER! Some silly bastards welded the center diff & turbocharged one & turned it into a drift car.
https://youtu.be/ZkhYNdPKkPw
https://youtu.be/92MMp7OejGQ _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Thu Mar 07, 2019 6:50 am Post subject: Re: Opinions on the B5/B5.5 Passat |
So it's not really worth it then. I've worked on plenty of 1.8t engines that grenade due to low oil, which I was happy my wife's car had the 2.8 V6. Good thing I guess I don't have to do emissions or inspections where I live.
And Mitsubishi 4cyl engines use the timing chain to drive balance shafts and the oil pump, people still like them. Is this second a particular problem cold though? _________________ It's not the fall that hurts, it's the sudden stop at the bottom.
67 Beetle, Opal |
Posted: Thu Mar 07, 2019 9:34 am Post subject: Re: Opinions on the B5/B5.5 Passat |
Sqrbckguy38 wrote: |
So it's not really worth it then? |
no. almost any major service requires an engine drop. any high end euro stuff is becoming disposable....or super cheap for owner #2 or #3 to purchase because the cost of keeping them going is simply staggering
if you're going for that platform I would go 1.8t. even though it's old technology by todays standards it's pretty bulletproof (or can be made that way)
honestly you'd be money ahead to buy a 1.8t (with a stick) and build a 200+hp version (easily achievable) and have a fun dead nuts reliable car.
my stock 1.8t has had a APR stage 1 tune in it for about 60k now. when the time comes, I will repower it...the car owes me nothing. heated seats, a/c, auto dimming mirrors...what else do I need?
reasonable economy too. I get a solid 32mpg on the highway, was getting about 34+ before the ethanol. _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Thu Mar 07, 2019 12:46 pm Post subject: Re: Opinions on the B5/B5.5 Passat |
The only reason that the 1.8t engines had oiling issues was because the manufacturer extended oil services out to 7,000 to 10,000 mile intervals. When new owners took their cars in for the services, most of the dealers (Or cheap ass owners) were dumping conventional oil back in them instead of the required synthetic. The 1.8t runs so hot internally that conventional burns like fry oil in an overheated pan. This carbon eventually breaks loose & clogs the oil pump pick-up tube screen, ESPECIALLY when that upselling 5 minute oil change jockey convinces you to "Do an oil flush" & then the engine starves of oil & wipes out the engine. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Wed Mar 13, 2019 4:57 pm Post subject: Re: Opinions on the B5/B5.5 Passat |
Well, so, I bought it anyways. I really like it so far, it's a lot of fun to drive, and was taken care pretty well, had a bunch of receipts from the dealer it was serviced. Was traded in, and sat for too long for the other dealer to sell it. So I got it from a smaller dealer associated with the main dealer.
I like it so far, and here's hoping it stays a great car. _________________ It's not the fall that hurts, it's the sudden stop at the bottom.
67 Beetle, Opal |
Posted: Thu Mar 14, 2019 5:20 am Post subject: Re: Opinions on the B5/B5.5 Passat |
I hope you didn’t pay much for it.
Here’s one with 23,000 miles on it for $6,500.
https://raleigh.craigslist.org/cto/d/clayton-volkswagen-passat-4-motion-w/6839962226.html _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Thu Mar 14, 2019 8:10 am Post subject: Re: Opinions on the B5/B5.5 Passat |
a fool and his money will soon be parted.
you're like my wife. ask for advice, hate the answer and do the opposite of what was advised...by 2 European Techs even...
should have just saved the time and said do what you want..you're going to anyway _________________
Jake Raby wrote: |
Brian wrote: |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Thu Mar 14, 2019 5:44 pm Post subject: Re: Opinions on the B5/B5.5 Passat |
There are not many of those cars, but I have a client with a W8 and he would beg to differ. They spent thousands of dollars to keep it on the road while he was in college. |
