jimf909 Samba Member
Posted: Sat Mar 17, 2018 3:14 am Post subject: Re: Compression test results |
It’s good to hear that you found someone who knows how to do a compression test and the news was good!
Here’s one solution for the firewall adapter, unfortunately it’s out of stock. As mentioned, another solution is to run a fuel hose through the firewall after putting a grommet in the firewall hole.
http://www.van-cafe.com/fuel-line-firewall-adapter
The injector fuel hoses should be replaced to mitigate risk of failure that could lead to a catastrophic fire.
The above is an example of work that needs to be done to make the van reliable but once done will result in a van that you can drive and drive. If you’re paying a mechanic it will take quite a few hours and parts (by the way, it looks like a oks like your mechanic is reasonable). Last Friday I drove my van 950 miles (Seattle to Pinnacles National Park) in 17 hours. Many others have similar stories of solid, reliable service. It just takes a regimen of addressing all of the deferred maintenance and puttting it on a maintenance schedule.
Ask your mechanic for a quote on systems (cooling? suspension? brake lines? etc) he would overhaul before taking the van on a two week camping trip. When you have those costs in mind you can consider your options (keep the Vanagon, buy a reliable car plus a camp trailer or van, etc, etc).
Enjoy! _________________ - Jim
Abscate wrote: |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
SteveMc Samba Member
Joined: December 19, 2013 Posts: 210 Location: Alberta, Canada
Posted: Sat Mar 17, 2018 7:57 am Post subject: Re: Compression test results |
IOSilver wrote: |
I see a metal firewall adaptor at VanCafe but they are currently out of stock.
What are some of the other vendors you mentioned who sell these?
Could you possibly supply a link where I might order one?
Thanks very much!
Foreign Auto & Supply has a beautiful firewall adaptor and they are in stock.
http://www.foreignautosupply.com/parts-accessories/53-fastt-replacement-fuel-spigot/#.Wq0rrlrF2hA _________________ 1986 Transporter Single Cab Syncro |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4026 Location: Redwood City, California
Posted: Sat Mar 17, 2018 8:28 am Post subject: Re: Compression test results |
"vanagonnewandusedparts.com"
This is the guy that makes the fuel line nipple that VAn Cafe and other people sell.
I would buy this over the alloy one Myself, I like everyone else here just run a hose and be done with it.
I personally would not drive a van with old injector hoses very far. This is a an easy job and I think your mechanic is being lazy. Once you have the the injector rail off which is only one 6mm bolt and 2 hose clamps and electrical connector you then take a pointed X acto blade and cut through the hose all the way through the hose and under the bell. Once cut you rip it out with a pair of pliers and slip the new hose on with a little WD40 as a lubricant.
You could buy some used injectors off of Samba and practice doing this your self at home, it is not difficult and they will not leak. Mechanics like big easy jobs they can spend little time on.
I can't believe that they didnt change the rest of the hoses as well, you wouldn't expect to use a Garden hose for 30 plus years , there must be someone in town that is not afraid of a little hard work. If you were closer i'd drag you into my driveway and help you do it. You don't need some Special kit, it's just hose and clamps. All of these kits start life as hose on a spool and clamps from a box.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
IOSilver Samba Member
Joined: September 11, 2010 Posts: 185 Location: Clovis, Ca.
Posted: Sat Mar 17, 2018 1:50 pm Post subject: Re: Compression test results |
Thanks for posting links to the firewall adapter! Much appreciated.
I don't think my mechanic is lazy. I think he's busy. That place is jam packed every time I go in there & the phones never stop ringing. They have been extremely patient & generous with their time towards me nonetheless.
& I think they've done an outstanding job so far. I called them just last week inquiring about diagnostics & within a few days I had the van back with all these repairs done. These guys really know what they are doing!
The mechanic encountered some problems during the repairs but took it upon himself to fix/replace things on the fly while still keeping the price within the repair quote he gave me.
When I went to pick up, he led me to the van & showed me everything he had done & explained why, patiently answering any questions I had + all was clearly detailed on the invoice which they also went over with me. Very fast & professional. I couldn't be happier with the service & level of attention.
I don't want to push my good luck by making demands on them because I know I found a good thing with this shop.
I think their prices are reasonable & I DO trust them.
The mechanics listen to my concerns, give me complete answers & offer solutions which is exactly what I need if I'm going to hang onto the Westy.
So, If they want extra money for the adapter install & I can help by obtaining the part I'm ok with that.
As far as the injector hoses.
I watched a video & I don't see why I couldn't do the job myself. Seriously, it looks pretty easy & I also watched how to replace the fuel rails.
But.. If my mechanic has reservations about doing it I'd like to find out why that is exactly before proceeding.
(Do you really think I need to send the injectors off to be rebuilt? Reason I ask is they seem to be working fine right now..)
I think when I take the adapter in for him to install will be a good time to breach the subject again. The last thing I want to do is be a nag.
This is a very busy shop & I need to be respectful of their time/schedule.
All of your help & advice here has been invaluable as well
& yes, I was greeted by Daizee when I 1st joined the forums & we exchanged some fun, friendly banter. She was really helpful & encouraging too.
I think she's a lot more adventuresome than I, travelling all over the place in her van for months at a time. Great stories, great lady!
Thanks so much for all the help & info..
Cyndi
Posted: Sat Mar 17, 2018 2:02 pm Post subject: Re: Compression test results |
No you don't necessarily need to have your injectors rebuilt, I suggested that as a way to get someone to do the hoses for you. When you pull the injectors though, do look at the tips to see if they are melted, if so then go ahead and send them in.
You could do the adapter yourself as well. That does take some dexterity to get to the forward side. From the technical point of view it is not difficult as all. |
Posted: Sat Mar 17, 2018 2:33 pm Post subject: Re: Compression test results |
Thanks for the advice,
I went to the site you recommended for the injector rebuild & the prices are really reasonable. If they look melted on the ends I'll definately send them in there & have them done. .
I don't feel comfortable jacking up the van in my garage & crawling underneath to connect the far side of the hose to the adapter which is why I'll probably pay to have that part done.
I could drive two wheels onto the curb in front of my house & get underneath it that way though (I reattached a skid-plate on my Celica this way)
But yeah, looks like just 2 bolts & reattaching hoses to the adapter fittings on either side of the firewall. I found instructions here on how to do the front side from the engine compartment by going between two hoses.
If there's enough room without jacking for me to squeeze underneath I may try it.
Thanks a lot for your help |
Posted: Sat Mar 17, 2018 6:01 pm Post subject: Re: Compression test results |
So, do you recommend I not smoke during this operation?
Maybe I ought to leave it to the professionals, lol |
Posted: Sat Mar 17, 2018 7:19 pm Post subject: Re: Compression test results |
Reading your posts, IO, suggests that you won’t have any problems using this as a camping rig for as long as you choose.
Well done. _________________ - Jim
Abscate wrote: |
16CVs Samba Member
Posted: Sat Mar 17, 2018 10:40 pm Post subject: Re: Compression test results |
I still say to buy a set of used injectors from the classifieds, they range from $10 to $50.00 Each. Buy them and try replacing the lines while you have nothing to lose. No down down time and an easy and fun experiment. Replacing only some of the fuel lines is just looking for the weakest link, I hope you don't find it.
If you did this yourself and then politely showed your mechanic how easy it is to do, he may just thank you.
If you do not want to spend the money for a little experiment, give me your address and I'll send you a spare set I have, along with some replacement hose.
I have nothing to win here. Just trying to keep the breed going and Dispell the myth that those short injector hoses are diffucult to replace and not worth the time.
My offer is solid and I'll even pick up the postgage costs. If not go and but a Eurovan and really cry when you see what it costs to put a Transmission in it, if you can even find a mechanic who wants to work on it.
Nuff said.
Posted: Sun Mar 18, 2018 3:07 pm Post subject: Re: Compression test results |
Thanks all!
Re: the plastic firewall adapter replace:
Well, I just slid underneath the Westy & can see the plastic firewall adapter from there with new hose & clamps on either side so that's good! Hoses are new & I just need to replace the firewall adapter. I will order a metal one (thx very much for the link!)
I think I can easily do the far side of the firewall from underneath the van without jacking, but the screw on the front side clamp is facing upwards & the adapter fitting bolts are tough to reach from below so I'd need do that side from above by going between the 2 hoses in the engine compartment.
Still, I think it's possible for me to do & I'm willing to try it to save $115.
Re: Having the injectors rebuilt: I'm considering doing this. I don't actually know how old the injectors are. The mechanic just said "They're old" but I know he didn't take them out & examine them. He also said "It's obvious someone's been in here replacing parts & doing work'. Yes, some parts have been replaced along with tuneups done regularly over the years (I wish I had complete service records & full history of everything that's been replaced & when. I only have records/receipts from '09 onward & a few from before for parts my husband had ordered)
Re: the 4 short injector hoses:
I actually think I can do this too. I'll disconnect the newly replaced long hoses at the rail ends, remove the brackets & pull the rails/injectors completely out so I can carefully dismantle & reassemble on a workbench before reinstalling.
I just need to obtain some replacement hose, injector seals & hose clamps. If I have to order the entire fuel replacement kit from GoWesty to get those, I will.
There's just no letting this go. The hoses from the injectors to the rails look shot! They're old, brittle, shrunken & it's amazing they haven't failed already.
Stacy, Thank you very much for your generous offer to mail me hose & injectors to practice on! Very kind of you to offer to do this for me!
I think instead I'm going to obtain all the replacement parts I need, dive in & just do it all for real. I have video & printed instructions w/pictures & have compared them to what I'm seeing on the Westy & think I understand the process now.
I'm no mechanic by any stretch of the imagination, but I have a good set of tools, am patient & am not afraid to get my hands dirty. Hopefully it's as simple as it looks, lol
Can't tell you how much I appreciate all your invaluable help & advice..
You guys are truly awesome
Cyndi |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
Posted: Sun Mar 18, 2018 4:10 pm Post subject: Re: Compression test results |
IOSilver wrote: |
Cyndi |
With the will to try and the attitude to learn you will be amazed at how much you can do on your own. There are plenty of folks here generous with their knowledge.
Everyone starts somewhere, even master mechanics.... _________________ Dave O
The Western Syncro build
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sun Mar 18, 2018 4:29 pm Post subject: Re: Compression test results |
IOSilver wrote: |
Re: the 4 short injector hoses: I'll ... remove the brackets & pull the rails/injectors...' |
FWIW: Be VERY careful with the small bolt holding the injector bracket...notorious for being
seized, head snapping off & you end up with another little issue to deal with...
Familiarize yourself with a good penetrating oil (Kroil, Liquid Wrench, PB Blaster) & starting
SEVERAL DAYS ahead of time, apply penetrating oil & use any reasonably sized hammer to
"taptaptaptaptap" many many times on the bolt head. Do this 1 or 2 times daily for several
days to help ensure the bolt will release from the intake runner mount, otherwise you'll have
another project on your hands (ask me how I know)...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
16CVs Samba Member
Posted: Sun Mar 18, 2018 4:45 pm Post subject: Re: Compression test results |
I agree with what the Big D said about the bolt. I just did the injector hoses on my Somewhat rusty van form Wisconsin and I soaked them a couple of times weeks ahead. So far all of the hardware has come off fairly well. If yours is a California van I wouldn't worry too much.
Take note of the orientation of the injectors in their holders before you take them off of the rail. I would not be too worried about the seals unles they are hard and brittle or non existent I would re use them. As far as the hose justy look at the hose that your Mechanic used and walk into a parts store and ask for a foot of that.
As far as the bulkhead fitting goes, it screws to the firewall and once you remove the screws you'll be able to access both sides and get to the clamps.
Send some pictures if you are not sure.
Posted: Sun Mar 18, 2018 5:18 pm Post subject: Re: Compression test results |
Ooh, I'm glad you told me about this because I hadn't really considered it.
It IS a California van, but I wouldn't be surprised if the bolts are seized up because who knows how long they've been on there.
Making a trip to Home Depot soon & they carry PB Blaster. I'll pick some up & start working the bolts.. Thanks for the tip!
I'll take a closer look at the injector seals too. It's nice to know I may be able to reuse the ones I have & just buy the hose & clamps locally. Saves $$!
Appreciate the advice!
Thanks
Cyndi |
16CVs Samba Member
Posted: Sun Mar 18, 2018 5:50 pm Post subject: Re: Compression test results |
You do not need any clamps. The injector has a ferrel on it and a bell on the outside that locks the hose in place. Don't over think this, just do it exactly VW did.
Get your self some Nitrile gloves and maybe some safety glasses as there will be a some pressure when you remove the lines. There is a small bleeder valve at the junction that will open the sytem and take the pressure off the lines. You sould also get a catch basin of some sort and the fuel in the lines will drian wjile you're doing this. You could get some golf tees, but you will not lose much fuel as long as you keep the lines above the level of the fuel tank.
Here is a play by play for changing the hoses once removed from the rails. Not how they sit in the holder(a quick pic). Get your X acto knife witgh a sharp pointed blade and cut it all th eway through at the end. spray it with some WD40 or Equiv to help break the staic bond it has. Grab the end with a pair of pliers and twist it and pull and it'll come right out. Cut your new hose to the same length and spray it again with the WD and push it onto the injector. After the 4th one you'll be a pro.
Posted: Sun Mar 18, 2018 6:29 pm Post subject: Re: Compression test results |
16CV's wrote: |
You do not need any clamps. The injector has a ferrel on it and a bell on the outside that locks the hose in place. Don't over think this, just do it exactly VW did. |
If you can come up with the same hose that VW used originally then this would be a good enough idea, don't think I would be willing to try it with some generic 30r9 or 30r14 hose. |
