Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Wed Jan 12, 2022 3:27 pm Post subject: Re: Building a bus for travel in Europe "euroBus" |
Don't be silly, Dave. Mice get the same size passports as everyone else. Then they make nests out of the paper. _________________ '86 Syncro Westy SVX |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22648 Location: NYC/Upstate/ROW
Posted: Thu Jan 13, 2022 12:36 am Post subject: Re: Building a bus for travel in Europe "euroBus" |
That’s why cars get cats… _________________ .ssS! |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32592 Location: Reading Pennsylvania
Posted: Thu Jan 13, 2022 1:21 am Post subject: Re: Building a bus for travel in Europe "euroBus" |
Don’t forget that gear shift linkage box ( remember the great video?)
https://www.youtube.com/watch?v=bdgTZKyqMkI _________________ .ssS!
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
DuncanS Samba Member
Posted: Thu Jan 13, 2022 9:00 am Post subject: Re: Building a bus for travel in Europe "euroBus" |
Never have had any mice...............that I know about.................yet. When the weather warms, I'll do the front air intake and the shift lever.
When the heater box is taken apart to replace the blower, then I'll know if there were mice. Never had any smell.
Duncan |
PDXnatv Samba Member
Joined: December 13, 2016 Posts: 42 Location: Portland
Posted: Wed Apr 06, 2022 2:55 pm Post subject: Re: Building a bus for travel in Europe "euroBus" |
Has anyone considered using 3M Thinsulate instead of the prodex? Seems like prodex is useless unless it has air on either side of it. So once it's covered by a fabric or carpeting what's the point in using it at all? |
J Charlton Samba Member
Joined: August 24, 2007 Posts: 1546 Location: The True North Strong and Free
Posted: Sun Sep 11, 2022 4:14 am Post subject: Re: Building a bus for travel in Europe "euroBus" |
PDXnatv wrote: |
Prodex "works" by being an Infrared reflective barrier. it reflects IR whether covered or not. The closed cell foam inside the IR outer layers limits thermal transmission. It is the IR reflective property that does the most to keep warm or keep cool _________________ NAHT hightop availability May 18 2023 -
Bend Oregon - for Oregon, California- (7 tot , 3 available), Kennewick Wa (6 tot, 1 available), Small Car Performance Fife Wa. (7 tot 4 avail ), Fairbanks Alaska (1 tot 0 avail)
Future availability TBD : Springfield Mass. Staunton Va, Florida, Colorado, Grand Junction Co., SLC probably late 2024 |
Posted: Sun Sep 11, 2022 4:55 am Post subject: Re: Building a bus for travel in Europe "euroBus" |
J Charlton wrote: |
PDXnatv wrote: |
Prodex "works" by being an Infrared reflective barrier. it reflects IR whether covered or not. The closed cell foam inside the IR outer layers limits thermal transmission. It is the IR reflective property that does the most to keep warm or keep cool |
I insulated my concrete block garage with 1" Poly-iso glued to the block inside, it is amazing how that thin barrier has changed the garage climate!
I know it is rigid but it is also surprisingly flexible and does not support combustion. The 1/2" is quite flexible and you can layer it. _________________ Stop Dead Photo Links how to post photos
Ghia
Vanagon
Beetle
Corwyn Samba Member
Joined: December 29, 2009 Posts: 2237 Location: Olympia, Washington
Corwyn Samba Member
Posted: Wed Nov 02, 2022 9:14 pm Post subject: Re: Building a bus for travel in Europe "euroBus" |
Using it at the mains connection to my onboard 110/120v battery charger. _________________ '90 White Westy ("The Longship")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~ |
4Gears4Tires Samba Member
Posted: Wed Apr 05, 2023 1:20 pm Post subject: Re: Building a bus for travel in Europe "euroBus" |
That clamp is a nice solution. My cluster is broken too. I'll have to look into that or a similar solution. _________________ '87 Syncro
