dobryan Samba Member
Joined: March 24, 2006 Posts: 16501 Location: Brookeville, MD
Posted: Mon Jun 14, 2021 12:23 pm Post subject: Re: Building a bus for travel in Europe "euroBus" |
Lately I have noticed that the euroBus has a dull clunk up front, not hard though, when I back up at full steering lock. I have looked and cannot find anything rubbing and it is definitely from the front end and every wheel rotation. This was there with the Nokians so it is not the new tires per se.
I had a thought that maybe it was the front wheel bearing so I jacked up the passenger front and there was a little more play at 12/6 than I would want, but nothing egregious.
I pulled the bearing cap off and very slightly tightened the bearing to the proper play.
Then I thought well maybe I should check the driver's side too of course.
The drivers side had about the same play (neither side had been adjusted after the bearings were installed a few thousand miles ago) so I pulled that bearing cap..... and out came a sea foam blue goo.... the grease that I have been using is a dark blue. No bueno.
I removed the brake disc with the bearings and noticed that when I pulled off the disc the inner bearing seal was hung up on the spindle... hmmmm. Looks like the seal lip had gotten damaged when I installed it the first time and was letting water past and into the bearings which made a nice frothy mix. I cleaned everything up, repacked the bearings twice, installed a new seal and all seems well. The spindle surface looked fine as did the bearings.
It was lucky that I did this maintenance now or I'd have prematurely failed wheel bearings somewhere in Europe in the future.
Oh... I never did solve that clunk. I'll just not back up at full lock... that will solve it. _________________ Dave O
The Western Syncro build
Posted: Mon Jun 14, 2021 1:26 pm Post subject: Re: Building a bus for travel in Europe "euroBus" |
The dash blower fan occasionally makes a squeak when running so it was time to lube it. The Mullendore port operation is excellent under this situation.
Two good squirts of TriFlow directly on the bearing while running on low and the fan motor is very happy... and so am I.
I was one cell off on my holes so the far right hole was not used. Shine the headlamp through the middle hole and look up at the end of the bearing from the left hole. Use TriFlow with a long tube (heat shrink tubing two together) up in the left hole and set it right up near the end of the bearing you can see. It takes a few trial looks to get the right angle to see the end of the bearing.
Seal the holes up with aluminum HVAC tape. Bob's your uncle.
narendra.vw Samba Member
Joined: February 07, 2013 Posts: 440 Location: Bangalore India
Posted: Tue Jun 15, 2021 6:44 am Post subject: Re: Building a bus for travel in Europe "euroBus" |
dobryan wrote: |
The complete a/c system has been sold and will live on in another bus.
$35,530
-$700 a/c sold
$34,830 total |
I wished it happened in my country. Full set would have been mine. I had spoiled front ac duct. I got one through The samba classifields. Later my friend brought it for me when he visited my Country.
I also appreciate you keep cost of your project. I did not. I got scared. |
Posted: Tue Jun 15, 2021 7:07 am Post subject: Re: Building a bus for travel in Europe "euroBus" |
narendra.vw wrote: |
I was/am too.
I'll never keep track like this on any of my other cars (except the 1977 911 I am restoring but that is for insurance purposes). I am shocked at how much $$$ it adds up to. My initial estimate will be low by $10,000 - $15,000. And of course my labor is free... _________________ Dave O
Alaskaberrys Samba Member
Joined: June 19, 2016 Posts: 1001 Location: SE Alaska
Posted: Tue Jun 15, 2021 10:45 am Post subject: Re: Building a bus for travel in Europe "euroBus" |
dobryan wrote: |
I was/am too.
I'll never keep track like this on any of my other cars (except the 1977 911 I am restoring but that is for insurance purposes). I am shocked at how much $$$ it adds up to. My initial estimate will be low by $10,000 - $15,000. And of course my labor is free... |
Even more so in that you seem fairly sensible in your spending (comparing to myself 😬) no fancy bumpers, seats - all pretty straight forward necessities. This will be a fantastic thread for the newb vanagon owner with large ambitions. A bit of a reality check. “Read before clicking the ‘buy now’ button” _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
'91 T3 Syncro Doka, Escorial Green 1.9L TD AAZ “Gremian” (to provoke, irritate, exasperate, vex...) |
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Tue Jun 15, 2021 8:21 pm Post subject: Re: Building a bus for travel in Europe "euroBus" |
I am also thankful for Dave's running total. The pennies do really add up and being practical (lubing that blower motor instead of replacing it) is a way of life we should all follow. Must be something about the engineer's mindset! _________________ '86 Syncro Westy SVX |
jimf909 Samba Member
Posted: Tue Jun 22, 2021 8:53 am Post subject: Re: Building a bus for travel in Europe "euroBus" |
Great information throughout this thread. Thanks.
Do you also subscribe to the multiple-multimeters school of measuring electricity? I see four meters in this photo. It looks like my garage when I'm diagnosing electrical issues.
_________________ - Jim
Abscate wrote: |
Posted: Tue Jun 22, 2021 9:09 am Post subject: Re: Building a bus for travel in Europe "euroBus" |
jimf909 wrote: |
I was curious how they'd stack up against each other. Pleasantly surprised they were all about exactly the same. Only a variation of one number in the last digit at the max. _________________ Dave O
Posted: Tue Jun 22, 2021 9:56 am Post subject: Re: Building a bus for travel in Europe "euroBus" |
Beautifully done! Great setup, very nicely constructed.
(translation= dammit Dave!! Now I want one ) _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
Posted: Tue Jun 22, 2021 10:44 am Post subject: Re: Building a bus for travel in Europe "euroBus" |
Nice work, Dave. I especially like the high-current terminals that Overkill has added to the Xiaoxiang BMS and the heavy gauge cables you have used. Very clever use of the cutting board "handles" too!
And now embarrassing question - - are you just gonna let that Bluetooth dongle dangle? _________________ '86 Syncro Westy SVX |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2795 Location: North Carolina
dabaron Samba Member
Joined: June 21, 2018 Posts: 2559 Location: Philly, mang
Posted: Tue Jul 13, 2021 8:22 am Post subject: Re: Building a bus for travel in Europe "euroBus" |
well that's pretty damn smart. i guess i didn't melt your brain completely this past weekend _________________ 1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5076 Location: denver
Posted: Tue Jul 13, 2021 8:23 am Post subject: Re: Building a bus for travel in Europe "euroBus" |
That's a brilliant idea, Dave!
Stealing it. _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
