Electrical troubleshooting
Forum Index -> Eurovan Share: Facebook Twitter
Roostert55
Roostert55 is offline
PostPosted: Mon Mar 05, 2018 9:00 am    Post subject: Electrical troubleshooting Reply with quote
I bought a 1995 European Camper (Winnebago). On arrival the aux. battery was dead as a doornail. I put a new battery in, the main fuse is in the "out" position but with a tester it is conducting power through it. I do not have power (with the battery) to the water pump and the "levels" test lights no not come on with either shore power or battery. I have used the selection switch for plug to bat with no luck. The interior light do work, the flouescants that is and the other "van" lights.
Not sure where I should look first. I am getting power at least to the maine flew but after that I'm not sure where to test - the power converter? Is there a way to see if it's any good?
Andy
markcm2
markcm2 is offline
PostPosted: Mon Mar 05, 2018 12:08 pm    Post subject: Re: Electrical troubleshooting Reply with quote
I only have the weekender but I believe there is a fuse or two near the rear aux battery, under the seat at the forward panal. Maybe you have some fuses under there?
Reply to topic    Forum Index -> Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
